Home » Eclipse Projects » Remote Application Platform (RAP) » Problem when RAP application deployed
Problem when RAP application deployed [message #661301] Thu, 24 March 2011 05:39 Go to next message
Swap  is currently offline Swap Friend
Member
My RAP application contains a dialog. This dialog constitutes a treeviewer & PropertySheetPage area.
PropertySheetPage changes as per selection of node in treeviewer. By default, first node is selected & page is populated in page area.
These are working fine in eclipse environment. But when I deployed it in JBOSS, on selection of node i treeViewer, it encounters problem & page is not loaded.
Can anybody help me, why is it so? What should be done ?
Re: Problem when RAP application deployed [message #661546 is a reply to message #661301] Fri, 25 March 2011 09:10 Go to previous messageGo to next message
Member
As mentioned above, everything is working fine in eclipse browser but not in Firefox or IE.
Why it is so? Can anybody tell me?
Re: Problem when RAP application deployed [message #662582 is a reply to message #661301] Thu, 31 March 2011 08:31 Go to previous messageGo to next message
Holger Staudacher is currently offline Holger StaudacherFriend
I recommend to user the "WAR product Tooling". It creates a war file
for you based on a launch configuration.
The tooling can be installed using the indigo p2 repository:
http://download.eclipse.org/releases/indigo/
Hope this helps.
Regards Holger
> page is not loaded.
Holger Staudacher | EclipseSource Karlsruhe
Need professional support for RAP and RCP?
Go to: http://eclipsesource.com/support
Twitter : @hstaudacher
Blog : http://eclipsesource.com/blogs/tag/rap/
Re: Problem when RAP application deployed [message #662624 is a reply to message #662582] Thu, 31 March 2011 10:36 Go to previous message
Member
thanks a lot !!
Previous Topic:A lot of update flicker in IE
Next Topic:Job
Current Time: Thu Dec 02 17:22:53 GMT 2021
Powered by FUDForum. Page generated in 0.02289 seconds
