Home » Eclipse Projects » DTP » DTP for non JDBC dbs(Can DTP be used to connect to databases other than JDBC ?)
DTP for non JDBC dbs [message #661093] Wed, 23 March 2011 07:08 Go to next message
Swati Sapar is currently offline Swati SaparFriend
[Updated on: Wed, 23 March 2011 07:08]
Report message to a moderator
Re: DTP for non JDBC dbs [message #661996 is a reply to message #661093] Mon, 28 March 2011 19:50 Go to previous messageGo to next message
Brian Fitzpatrick is currently offline Brian FitzpatrickFriend
If you look at the ODA profiles, they use the Connectivity framework and DTP to connect to things like XML files. If you're looking for connecting to ODBC drivers, you can try to use the JDBC-ODBC bridge, but we've had mixed results with it over the years.
What specifically are you looking for?
--Fitz
Re: DTP for non JDBC dbs [message #662215 is a reply to message #661093] Tue, 29 March 2011 18:25 Go to previous messageGo to next message
ODA uses DTP for other data sources. And many years ago we had the ODBC-JDBC bridge working for ODBC-enabled databases at Sybase. That work never made it to DTP unfortunately, but I know it is possible.
What non-JBDC dbs are you looking at supporting?
Re: DTP for non JDBC dbs [message #695489 is a reply to message #662215] Mon, 11 July 2011 21:31 Go to previous message
Thank you for the reply Brian.
As of now I am not looking for a specific ODBC database connection.
I shall update here if I have more specific questions.
Previous Topic:Network proxy settings and DTP Connections?
Next Topic:Open SQLEditor programmatically causes NPE
Current Time: Thu Nov 26 01:54:35 GMT 2020
Powered by FUDForum. Page generated in 0.02055 seconds
