RSE won't let me open remote files any more [message #660630] |
Sun, 20 March 2011 13:13 |
Eric Messages: 17 Registered: March 2011 |
Hi All,
this is my last attempt to finally get the issue fixed.
I have spend all the weekend now to find a solution but unfortunately, I'm still lost and cannot use RSE any more.
I'm using Eclipse Helios PDT on a Vista 32bit installation. It was working without any problems until some days ago but now, I cannot use it any more as everytime I try to open a remote file through RSE, I get the following error:
RSEF1002 Operation failed. File system input or output error - Message reported from file system: The system cannot find the specified path
I'm asking myself whether there's any possibility of finding out which path cannot be found? The log file only says the following:
eclipse.buildId=M20110210-1200
java.version=1.6.0_24
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=de_DE
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.rse.ui 4 0 2011-03-20 14:01:41.686
!MESSAGE RSEF1002
My Eclipse.ini file contains the following:
-startup
plugins/org.eclipse.equinox.launcher_1.1.1.R36x_v20101122_1400.jar
--launcher.library
plugins/org.eclipse.equinox.launcher.win32.win32.x86_1.1.2.R36x_v20101222
-showsplash
org.eclipse.platform
--launcher.XXMaxPermSize
256m
--launcher.defaultAction
openFile
-vm
C:/Program Files/Java/jdk1.6.0_24/bin/javaw.exe
-product
org.eclipse.epp.package.php.product
openFile
256M
-vmargs
-Dosgi.requiredJavaVersion=1.5
-Xms40m
-Xmx384m
I'm really helpless but it is really important to me that I can use Eclipse for my daily work again! Do I miss any prerequisites, .dll files, Environment Variables or anything else?
As already said, it was working fine until some days ago so I have no explaination why it suddenly stopped working. Could it be a problem with my system itself? I have a second machine running XP and Eclipse is working like a charm there.
Also, it doesn't matter which kind of remote system I try to use (whether it's FTP or SSH) and what OS the remote system has (Windows or Linux) - I'm always presented with the same error.
Please help me in fixing this issue.
Thank you so much in advance!
[Updated on: Sun, 20 March 2011 15:00] Report message to a moderator
Re: RSE won't let me open remote files any more [message #660646 is a reply to message #660643] |
Sun, 20 March 2011 15:45 |
Hi Martin,
thank you for suggestion! I really appreciate it!
Unfortunately, even after following your instructions and deleting all my connections except for one, the problem still persists.
I can't even open local files! The error message I get is the following (when trying to open an example file, e.g. install.log):
RSEF1002 - Operation failed. File system input or output error
Message reported from file system: C:\eclipse workspace\RemoteSystemsTempFiles\LOCALHOST\c\Users\Asus\install.log (The system cannot find the specified path)
I really believe that this is a problem with my system missing some prerequisites. Unfortunately, I still dont know how to proceed now. It is really important to me to get Eclipse up and running again as I'm using it for my daily work. I would even spend money for a working Eclipse installation in the meanwhile!
Best,
Eric
[Updated on: Sun, 20 March 2011 15:46] Report message to a moderator
Re: RSE won't let me open remote files any more [message #660667 is a reply to message #660646] |
Sun, 20 March 2011 21:43 |
Hi Martin,
I have found a temporary work-around: creating the folders manually on my local PC solves the problem.
Opening the file example.com/subdir/file.htm directly through RSE doesn't work. After creating the directory + subdirectory manually in my workspace (C:\workspace\RemoteSystemsTempFiles\example.com\subdir), opening + editing works like a charm.
Also, Eclipse isn't able to create multiple directories at once.
After performing the steps above, you can open any files within the "root" + the "subdir" directory. What you cannot do is opening files in deeper subdirectories (e.g. example.com/subdir/subdir2/subdir3/file.htm) right-away.
You will always have to either create the folder structure manually first ( C:\workspace\RemoteSystemsTempFiles\ecample.com\subdir\subdi r2\subdir3) or first go into the subdir2 directory, open a file within it so that the subdir2 folder is created in your workspace and then proceed to subdir3 and open a file again in order to proceed into even deeper subdirectories.
It is a really strange problem but I think it could be a Java problem of not being able to create multiple folders at once despite of correct permissions (even tried "Full Access" for "Everyone" onto the Eclipse directory itself + subfolders and the workspace directory + subfolders!) and disabled UAC.
Is there any temporary work-around for this so that I can work with Eclipse just as usual? Otherwise I will always need to follow the steps described above which can become complicated, especially when working in multiple subdirectories.
Any help is greatly apprecited!
Thank you in advance!
PS: Creating a completely fresh workspace doesn't work either - the problems described above persist.
[Updated on: Sun, 20 March 2011 22:12] Report message to a moderator
FUDForum. Page generated in 0.03851 seconds
