Home » Eclipse Projects » P2 » p2.mirror and site.xm
p2.mirror and site.xm [message #660503] Fri, 18 March 2011 16:59 Go to next message
Stephane Bouchet is currently offline Stephane BouchetFriend
hi,
we are providing an update site that contains both site.xml and p2
artifacts stuff ( artifatcs.jar and contents.jar ), so our update site
can be cunsumed by any eclipse versions.
this is working well, but facing a little problem.
when trying to mirror this update site using p2.mirror and eclipse 3.6 ,
it seems the site.xml is fetched first and p2 recreates metadata from
it. as a results, i get some artifact.reference pointing to original
update site.
if i remove the site.xml, p2 gets correctly the metadata.
my question is : does p2 looks for a site.xml before doing anything ?
how do i tell p2.mirror not using site.xml in its miror process ?
Stéphane Bouchet, OBEO
Re: p2.mirror and site.xm [message #841549 is a reply to message #660503] Wed, 11 April 2012 13:03 Go to previous messageGo to next message
Gonzague Reydet is currently offline Gonzague ReydetFriend
Hey Stéphane,
Did you find any solution for this issue?
We are facing the same problem trying to install artifacts located on a mirrored repository that references the original location.
Gonzague
Re: p2.mirror and site.xm [message #848393 is a reply to message #841549] Wed, 18 April 2012 07:22 Go to previous message
hi gonzague,
nope, i didn't find any solution for now, but i might look at the
p2.index file
http://wiki.eclipse.org/Equinox/p2/p2_index
Le 11/04/2012 15:03, Gonzague Reydet a écrit :
> Hey Stéphane,
> Cheers,
> Gonzague
Previous Topic:issue to generate some plugins in P2 format with a headless build.
Next Topic:Configure a p2 update repository programmatically
Current Time: Sun Jan 26 11:46:47 GMT 2025
Powered by FUDForum. Page generated in 0.03662 seconds
