Home » Modeling » EMF » EMF generated projects don't compile
Re: EMF generated projects don't compile [message #660344 is a reply to message #660333] |
Fri, 18 March 2011 02:56 |
Ed Merks Messages: 33140 Registered: July 2009 |
Michael,
EMF didn't change in 3.6.2. I've not heard of anyone else having this
problem. It seems like a glaring issue, not a subtle one, so I'd expect
all to notice it immediately. Unless of course it's specific to your
setup...
Are you saying the imports are absent from the .java files? Or they're
there, but they don't resolve because the dependency on org.eclipse.swt
is not properly resolved?
Michael Moser wrote:
> I have a, say, "example" project that contains a .genmodel file that validates without errors nor warnings.
> When I select the topmost element and select "Generate All" I get an "example.edit" project that compiles fine plus a
> "example.editor" project that has >200 errors and doesn't compile, apparently mostly due to one or more missing imports of
> org.eclipse.swt.X (where X is "SWT", "event", "layout" and "widgets"). How do I convince EMF to generate projects that *do* compile?
> This is on Helios v3.6.2 (Build id: M20110210-1200) on top of Windows 7.
> Michael
Ed Merks
Re: EMF generated projects don't compile [message #660365 is a reply to message #660344] |
Fri, 18 March 2011 06:10 |
Ed Willink Messages: 7655 Registered: July 2009 |
Hi Michael
EMF has incremental merged generation for Java files but leaves a
pre-existing MANIFEST.MF unchanged.
Is it possible that an early generation attempt or manual intervention
created an inadequate MANIFEST.MF?
I suggest that you delete your editor project so that EMF can generate
afresh.
Ed Willink
On 18/03/2011 02:56, Ed Merks wrote:
> Michael,
> this problem. It seems like a glaring issue, not a subtle one, so I'd
> expect all to notice it immediately. Unless of course it's specific
> to your setup...
> they're there, but they don't resolve because the dependency on
> org.eclipse.swt is not properly resolved?
>> compile?
>> Michael
Re: EMF generated projects don't compile [message #660450 is a reply to message #660434] |
Fri, 18 March 2011 13:30 |
--------------000206050509060609090807
Michael,
Perhaps SWT isn't in your target platform? It is possible to add SWT as
a direct dependency in your manifest? You shouldn't need it because the
EMF's bundles re-export it, but it will be a good test to try.
> eOn Thu, 17 Mar 2011 19:56:44 -0700, Ed Merks <Ed.Merks@gmail.com> wrote:
>> Michael,
>> setup...
> I deleted the MANIFEST as well as the generated model code, i.e. I restarted from a clean slate and empty project just keeping the
> .ecore and the .genmodel file and then issued a "Generate All".
> The result is
> the src tree in the example project - compiles
> example.edit project - compiles
> example.editor project - does not compile - see below
> example.test project - compiles
> The example.editor project contains four files
> package example.presentation:
> ExampeModelActionBarContributor
> ExampleModelEditor
> WebPullModelEditorPlugin
> WebPullModelModelWizard
> Except for the ...Plugin file all other files show compile errors and have issue with their import statements
> import org.eclipse.swt.<X>;
> and of course there are errors in all lines that reference any SWT class or item.
> The top line of those files also has a marker that reads e.g.:
> Multiple markers at this line
> - The type org.eclipse.swt.widgets.Tree cannot be resolved. It is indirectly referenced from required .class files
> - The type org.eclipse.swt.events.ControlAdapter cannot be resolved. It is indirectly referenced from
> - The type org.eclipse.swt.widgets.Table cannot be resolved. It is indirectly referenced from required .class files
> - The type org.eclipse.swt.widgets.Menu cannot be resolved. It is indirectly referenced from required .class files
> - The type org.eclipse.swt.dnd.DragSourceListener cannot be resolved. It is indirectly referenced from
> - The type org.eclipse.swt.widgets.List cannot be resolved. It is indirectly referenced from required .class files
> - The type org.eclipse.swt.dnd.DropTargetAdapter cannot be resolved. It is indirectly referenced from
> - The type org.eclipse.swt.custom.TreeEditor cannot be resolved. It is indirectly referenced from required .class
> files
> - The type org.eclipse.swt.dnd.DropTargetListener cannot be resolved. It is indirectly referenced from
> - The type org.eclipse.swt.dnd.ByteArrayTransfer cannot be resolved. It is indirectly referenced from
> - The type org.eclipse.swt.dnd.Transfer cannot be resolved. It is indirectly referenced from required .class files
> - The type org.eclipse.swt.graphics.Point cannot be resolved. It is indirectly referenced from required .class files
> - The type org.eclipse.swt.custom.CTabFolder cannot be resolved. It is indirectly referenced from required .class
> files
> What the heck am I missing?
> Michael
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Michael,<br>
<br>
as a direct dependency in your manifest? You shouldn't need it because
the EMF's bundles re-export it, but it will be a good test to try.<br>
<br>
<br>
<blockquote cite="mid:lri6o6t9u0ecsdb4vs04d9mqni3qvsq8pt@4ax.com"
type="cite">
<pre wrap="">eOn Thu, 17 Mar 2011 19:56:44 -0700, Ed Merks <a class="moz-txt-link-rfc2396E" href="mailto:Ed.Merks@gmail.com"><Ed.Merks@gmail.com></a> wrote:
</pre>
<blockquote type="cite">
<pre wrap="">Michael,
setup...
</pre>
</blockquote>
<pre wrap=""><!---->
..ecore and the .genmodel file and then issued a "Generate All".
The result is
ExampleModelEditor
files
files
Michael
</pre>
</blockquote>
</body>
</html>
--------------000206050509060609090807--
Ed Merks
Current Time: Tue Apr 23 08:26:25 GMT 2024
Powered by FUDForum. Page generated in 0.03598 seconds
