Home » Archived » XML Schema Definition (XSD) » Is it possible to manually specify schema to use for XML for wst xml editor?
Is it possible to manually specify schema to use for XML for wst xml editor? [message #659838] Tue, 15 March 2011 18:35 Go to next message
Max Mising name is currently offline Max Mising nameFriend
Member
Basically I have an application that allows for editing of xml files. These xml files are generated using jaxb. We have a schema file that was generated from the jaxb context that we can use for content assistance but the only way I can get it to work is to manually add an attribute in the root element that specifies the location of the xsd to use. So our xml when generated looks like this:
<rootTag>
       <someObject xsi:type="objectTypeA" attributA="something">
                <someOtherElemet attributeB="anything"/>
       </someObject>
 </rootTag>
By default edting this xml file, I get no content assistance, but if I change it to this in the editor, I get content assistance.
<rootTag xsi:noNamespaceSchemaLocation="/some/path/to/schema.xsd">
       </someObject>
 </rootTag>
Does anyone know of any settings where I can specify the default noNamespaceSchemaLocation to use?
Max
Re: Is it possible to manually specify schema to use for XML for wst xml editor? [message #659853 is a reply to message #659838] Tue, 15 March 2011 19:16 Go to previous message
Max,
I think WTP has some type of registry in which you can specify which
namespaces map to which schema location. If you can't find it in the
preferences, please ask about in on the WTP newsgroup/forum.
> <rootTag>
> </someObject>
> </rootTag>
> </someObject>
> </rootTag>
> Thanks
> Max
Ed Merks
Previous Topic:XSD Graphic editor
Next Topic:Can we use list of user data structure as an element
Current Time: Fri Feb 07 06:17:48 GMT 2025
Powered by FUDForum. Page generated in 0.03134 seconds
