Home » Modeling » EMF » Defining ECore operations that return EList(problem with the returning type because EList is unmodificable)
Defining ECore operations that return EList [message #659673] |
Tue, 15 March 2011 08:21 |
Carlos Messages: 1 Registered: March 2011 |
Junior Member |
Hi.
I want to define an operation on a particular element of my ecore metamodel, and the returning type must be a list of elements.
In the ecore editor, I select EEList<?> as the returning type but my problem is that I can't create that kind of lists, neither make a cast from ArrayList to EList.
If I had to return eContents from an EObject, I have be able to return an EList, but in my case, I have to return a list of element built by me.
(At the moment, I have got a non smart solution based on not to declare the returning type in the ecore editor, and after that I set ArrayList<?> as the returnint type in the signature of the implemented method.
Please, have you got any suggestion in order to get something smarter?
Thanks in advance.
Regards.
Carlos.
Re: Defining ECore operations that return EList [message #659714 is a reply to message #659673] |
Tue, 15 March 2011 09:57 |
Originally posted by: koen.yskout.cs.kuleuven.be
Carlos,
You can set the EType to the type of the objects in the list, and set
the upper bound to -1.
Kind regards,
Koen
On 15/03/11 09:22, Carlos wrote:
> Hi.
> method.
> Thanks in advance.
> Regards.
> Carlos.
Re: Defining ECore operations that return EList [message #659750 is a reply to message #659714] |
Tue, 15 March 2011 13:45 |
Hm, it looks like I completely misinterpreted your question :)
Using BasicEList, as Hallvard suggested, is probably the way to go.
On 15/03/11 10:57, Koen Yskout wrote:
> Carlos,
> Kind regards,
> Koen
>> Hi.
>> method.
>> Thanks in advance.
>> Regards.
>> Carlos.
Current Time: Thu Apr 25 07:42:36 GMT 2024
Powered by FUDForum. Page generated in 0.03252 seconds
