Re: For Preview, Internal browser is not available - how to set [message #659231 is a reply to message #659108] |
Fri, 11 March 2011 15:32 |
Anandan,
Can you try to start eclipse with the -clean option? Also look at the
window-preferences->Report Design->Preview options. There is a check
box to always use an external browser.
You may also want to search your workspace for a .log file that should
have a stack trace in it when you get the error.
Jason
On 3/11/2011 12:06 AM, Anandan Subramani wrote:
> I downloaded "birt-report-designer-all-in-one-linux-gtk-2_5_2.tar.gz" to
> my CentOS 4.3 and untarred to get the eclipse (Galileo) platform. As I
> had eclipse 3.1 version, just moved away that and started using this
> elipse for BIRT.
> Currently learning to generate reports. After designing few reports, I
> could preview them using my mozilla firefox browser, and an error
> message "Internal browser is not available" is always shown in eclipse
> preview window. I didn;t give much importance to that. Now I'm facing a
> problem - when reports with user filtering is designed - clicking
> preview button displays the error
> "Unhandled event loop exception
> No more handles [Unknown Mozilla path (MOZILLA_FIVE_HOME not set)]"
> I tried to resolve this issue - but to no solution. Still the "Internal
> browser is not available" error appears. I think if I could resolve this
> "Internal browser is not available" error, the above exception won't
> appear.
> I am looking forward for possible solution to resolve the above issues.
> Please provide any help.
> Thanks Anandan.V.S.
Re: For Preview, Internal browser is not available - how to set [message #659558 is a reply to message #659338] |
Mon, 14 March 2011 15:12 |
I assume you tried the clean option?
Jason
On 3/12/2011 8:30 AM, Anandan Subramani wrote:
> Jason,
> Thank you. I could see the .log file in my workspace but it does not
> give any information more than that I mentioned -
> !ENTRY org.eclipse.ui 4 0 2011-03-11 11:56:01.531
> !MESSAGE Unhandled event loop exception
> !STACK 0
> org.eclipse.swt.SWTError: No more handles [Unknown Mozilla path
> at org.eclipse.swt.SWT.error(SWT.java:3910)
> at org.eclipse.swt.browser.Mozilla.create(Mozilla.java:485)
> at org.eclipse.swt.browser.Browser.<init>(Browser.java:119)
> When I set MOZILLA_FIVE_HOME to export
> MOZILLA_FIVE_HOME=/usr/lib/firefox-3.0.1/
> it reported swt.jar was not available. I copied swt.jar to the above
> directory, then
> eclipse started to crash.
> Now instead of previewing, I do the following: Run -> View Report -> In
> Web Viewer
> I get the Report parameter window properly to give the values and get
> the report rightly.
FUDForum. Page generated in 0.03909 seconds
