Re: EObject to String for bigger models [message #659083 is a reply to message #659081] |
Thu, 10 March 2011 22:14 |
Ed Merks Messages: 33140 Registered: July 2009 |
Otto,
Comments below.
Otto von Wesendonk wrote:
> in order to serialize eobjects to strings, I copy the eobject, add it
> to a new, "virtual" resource and then save it using a StringWriter as
> outputstream. Since the models are getting bigger now, this approach
> is becoming a bottleneck.
> I was wondering how hard it would be to short-circuit the XMLSaveImpl
> class in order to serialize the original eobject without having to
> copying it or it loosing its resource and so on. Which steps would be
> necessary and is this a good idea anyway?
Using this option with the resource that really contains some ancestor.
* Write only the subtree starting at the specified list of EObjects,
* which must be objects contained by the resource.
String OPTION_ROOT_OBJECTS = "ROOT_OBJECTS";
> The eobjects which are serialized are in a self-contained tree. (They
> are saved in multiple resources using cross-resource containment
> links, but I don't think this matters, since they are fully loaded to
> RAM at time of serialization anyway).
> Any hints or ideas?
> Thanks in advance,
> Otto
Ed Merks
Re: EObject to String for bigger models [message #659099 is a reply to message #659094] |
Fri, 11 March 2011 00:23 |
Otto,
So you need something that doesn't reflect the real (complete) state of
the objects. That's not so easy. You'd need to specialize XMLSaveImpl
for stuff like that.
> Hi Ed,
> thanks for your super fast reply. I saw you mentioning this option
> before but didn't recognize that it would help me.
> My model is spread over several resources. I used this option on the
> resource containing the root object of the subtree i wanted to
> serialize to string, but the final string then contained cross
> references to the children in other resources. I need the serialized
> string to be self-contained. How can I solve this issue?
> Thanks again,
> Otto
Ed Merks
FUDForum. Page generated in 2.96471 seconds
