Home » Modeling » GMF (Graphical Modeling Framework) » Changing Palette Icons programmatically
Changing Palette Icons programmatically [message #658462] Tue, 08 March 2011 10:40 Go to next message
I want to use two different styles of icons in my gmf palette. So I need to change the icon of a tool during runtime depending on the user settings (preference page). Is there a way to do this?
Thanks in advance
Re: Changing Palette Icons programmatically [message #658636 is a reply to message #658462] Wed, 09 March 2011 05:56 Go to previous messageGo to next message
On 08-03-11 16:40, comander@flippancy.de wrote:
Yes, this should be possible.
You could consider reloading your palette with different tool entries,
when the preference changes. (See how it's initally loaded in your
DiagramEditor class, method createPaletteRoot(PaletteRoot
existingPaletteRoot)
You would create a customized ToolEntry (Which extends PaletteEntry) and
override getSmallIcon() / getLargeIcon().
ToolEntry classes are return from the generated paletteFactory.
Have fun!
Christophe
Re: Changing Palette Icons programmatically [message #661098 is a reply to message #658636] Wed, 23 March 2011 03:39 Go to previous messageGo to next message
Thanks for the hint.
I managed to find the related source code but unfortunatly I don't know how to change it, since my code is generated with GMF and is regenerated regulary. So I thought I can use an extension somewhere to override the existing code but that wasn't successful either. Do you have an idea how to change the generated code for a palette entries?
Thank you very much indeed!
Cheers
Dave
Re: Changing Palette Icons programmatically [message #661106 is a reply to message #661098] Wed, 23 March 2011 04:06 Go to previous messageGo to next message
Hi Dave,
Comments below.
> Cheers
> Dave
You have third options :
- Use the palette provider extension point, see
http://help.eclipse.org/helios/index.jsp?topic=/org.eclipse. gmf.doc/tutorials/diagram/paletteConfigurationTutorial.html
- Modify the templates, see
http://www.bonitasoft.org/blog/eclipse/customize-your-gmf-ed itor-by-customizing-templates/
- Mark the method you modified as not generated (or the method when your
instantiate your own custom implementation of PaletteFactory)
Mariot
Mariot Chauvin @ Obeo
Blog : http://mariot-thoughts.blogspot.com
Twitter :http://twitter.com/mchv
Professional support : http://obeo.fr/pages/maintenance-and-support/
Re: Changing Palette Icons programmatically [message #661213 is a reply to message #661098] Wed, 23 March 2011 11:14 Go to previous messageGo to next message
inlined....
I am not sure why you want to override the palettefactory. What you
really want (At least, if I understand from the original post), is to
subscribe to preference changes, and then reload the palette right? So
from the palette factory, you simply re-use the parts which make sense
like this:
I found this comment in the EditingDomain.setPaletteRoot(..)
* Sets the PalatteRoot for this EditDomain. If the EditDomain already
knows
* about a PaletteViewer, this root will be set into the palette viewer
* also. Loads the default Tool after the root has been set.
* <p>
* It is recommended that the palette root not be set multiple times. Some
* components (such as the PaletteCustomizerDialog for the PaletteViewer)
* might still hold on to the old root. If the input has changed or
needs to
* be refreshed, just remove all the children from the root and add the new
* ones.
* @param root
* the palette's root
so, obviously not a good idea to reset the root.
You would need to play (Add/remove) with this:
this.getEditDomain().getPaletteViewer().getPaletteRoot().get Children()
Please let us know the result!
> Cheers
> Dave
Re: Changing Palette Icons programmatically [message #661238 is a reply to message #661213] Wed, 23 March 2011 12:19 Go to previous messageGo to next message
Hi guys
thanks for all your ideas.
Since I only want to change the shape and color of an icon I don't want to change the whole palette implementation.
As Mariot suggested I used the PaletteFactory.xpt and extended some functions a bit. I basically addd a function call, which returns the currently selected icon theme in the preference page.
So during code generation this function call gets also genereted in the java files and I only need to add one dependency to the package which contains the function call implementation.
Here the xpt excerpt:
«DEFINE setSmallImage(toolVarName : String, palette : gmfgen::Palette) FOR gmfgen::EntryBase-»
«IF null <> smallIconPath-»
«toolVarName».setSmallIcon(«palette.activatorFQN()».findImageDescriptor("«smallIconPath»"+AbstractImage.getColorSchemeFromSetting()+".png"));«EXPAND xpt::Common::nonNLS»
«ELSEIF not (Sequence { self })[gmfgen::ToolEntry].elements->isEmpty()-»
«LET self.oclAsType(gmfgen::ToolEntry) AS toolEntry-»
«toolVarName».setSmallIcon(«palette.diagram.getElementTypesQualifiedClassName()».getImageDescriptor(«EXPAND xpt::providers::ElementTypes::accessElementType FOR toolEntry.elements->first()»));
«ENDLET-»
«ENDIF-»
«ENDDEFINE»
AbstractImage.getColorSchemeFromSetting() returns a string with currently selected icon style.
The only disadvantage with this approach is that I have to restart my editor window to see the newly loaded images. Do you guys have an idea how to master this last task?
Thanks for all your help!
Dave
Re: Changing Palette Icons programmatically [message #661277 is a reply to message #661238] Wed, 23 March 2011 16:08 Go to previous messageGo to next message
inline....
On 23-03-11 17:20, Dave wrote:
> Hi guys
I just found below in PaletteViewer Class It already listens to the
preferences and update the parts by calling refreshAllEditParts()
So you could do the same in your prefernece listener. You can get access
to the PaletteRoot, through the Editor with
xxxDiagramEditor().getEditDomain().getPaletteViewer().getPal etteRoot()
You can get the editor, through the workbench... this will work for sure.
private class PreferenceListener implements PropertyChangeListener {
* @see
java.beans.PropertyChangeListener#propertyChange(java.beans. PropertyChangeEvent)
public void propertyChange(PropertyChangeEvent evt) {
String property = evt.getPropertyName();
EditPart root = getRootEditPart().getContents();
if (property.equals(PaletteViewerPreferences.PREFERENCE_FONT)) {
updateFont();
refreshAllEditParts(root);
} else if (property
.equals(PaletteViewerPreferences.PREFERENCE_LAYOUT)
|| property
.equals(PaletteViewerPreferences.PREFERENCE_AUTO_COLLAPSE)
|| property
.equals(DefaultPaletteViewerPreferences
.convertLayoutToPreferenceName(getPaletteViewerPreferences()
.getLayoutSetting()))) {
private void refreshAllEditParts(EditPart part) {
part.refresh();
List children = part.getChildren();
for (Iterator iter = children.iterator(); iter.hasNext();) {
EditPart child = (EditPart) iter.next();
refreshAllEditParts(child);
> «toolVarName».setSmallIcon(«palette.activatorFQN()».find ImageDescriptor( "«smallIconPath»"+AbstractImage.getColorSchemeFromSetting()+ ".png"));«EXPAND
> «toolVarName».setSmallIcon(«palette.diagram.getElementTyp esQualifiedClassName()».getImageDescriptor(«EXPAND
> «ENDLET-»
> «ENDIF-»
> «ENDDEFINE»
> Dave
Re: Changing Palette Icons programmatically [message #665857 is a reply to message #661277] Sun, 17 April 2011 05:56 Go to previous message
sorry for the continued delay in my message.
I was playing around with PaletteViewer and PaletteRoot and it seems the palette is refreshed but eclipse is using cached images. So there is no visible change. Can you confirm this?
Since I need to refresh the my editor edit part images as well I thought I can write a global class for doing that. When I close my editor and restart it again, I see the changed images in both palette and editor. Any ideas on how to accomplish that in a simple class programmatically?
Dave
Previous Topic:Draw on editor canvas
Next Topic:External labels on node - question on positioning
Current Time: Tue Nov 11 08:12:32 EST 2025
Powered by FUDForum. Page generated in 0.05603 seconds
