Home » Modeling » M2T (model-to-text transformation) » Bug in my code or in OCL
Bug in my code or in OCL [message #658220] Mon, 07 March 2011 13:14 Go to next message
Wilbert Alberts is currently offline Wilbert AlbertsFriend
I'm trying to generate some code for a c like language. It contains pieces like:
typedef struct
  BAR b;
} FOO;
typdef struct
  int i;
} BAR;
However, in this case the order of the typedefs matters. So the typedef of BAR should precede the one of FOO.
So I need to order a collection of types in my model. I decided to first generate a set of all types present in my model. Then, I'll put them in the right order based on a recursive function which looks like:
[query public sortTypes(done: Sequence(PG_Type), tobedone: Set(PG_Type)) : Sequence(PG_Type) =
if tobedone->isEmpty() then done
else
   let bottom  : Set(PG_Type) = tobedone->select(t| done->includesAll(subTypes(t))),
       newdone : Sequence(PG_Type) = done->union(bottom->asSequence()),
       newtobe : Set(PG_Type) = tobedone-bottom
   in
       sortTypes(newdone, newtobe)
endif
When I run this code, I get an error in the log stating:
Evaluation failed with an exception: org.eclipse.ocl.util.BagImpl cannot be cast to java.util.Set
As far as I can see, the typecast is done in the calculation of newtobe. However, I'm not an expert in OCL and I'm curious about the return types of the various expressions.
Any clues?
Greetings,
Wilbert.
[Updated on: Mon, 07 March 2011 13:29]
Report message to a moderator
Re: Bug in my code or in OCL [message #658224 is a reply to message #658220] Mon, 07 March 2011 13:31 Go to previous messageGo to next message
Hi Wilbert
There seems to be only one conversion to Set in your code and that is in
the call that you haven't shown. I suspect that you input argument is a
Bag a Set. (I seem to recall an earlier thread where Acceleo's query
argument checking was not as tight as it might be.)
Incidentally, have you considered the sortedBy iteration.
Ed Willink
On 07/03/2011 13:14, Wilbert Alberts wrote:
> pieces like:
> typedef struct
> BAR b;
> } FOO;
> typdef struct
> int i;
> } BAR;
> else
> in
> endif
> When I run this code, I get an error in the log stating: Evaluation
> to java.util.Set
> Any clues?
> Greetings,
> Wilbert.
Re: Bug in my code or in OCL [message #658228 is a reply to message #658224] Mon, 07 March 2011 13:58 Go to previous message
Hi Edward,
Thanks for taking a look at it.
In the meanwhile, the problem is gone (or masked) after changing
		newtobe : Set(PG_Type) = tobedone - bottom
into
		newtobe : Set(PG_Type) = (tobedone->asSet()) - (bottom->asSet())
As to your remark, the invocation of sortTypes is:
sortTypes(Sequence{}, deepTypess(ts))
where deepTypess is defined to return a Set(PG_Type)
I could show the full code to you but I'm afraid it might take too much time to justify the effort.
Would you be interested? As for me, the immediate urge is gone but I must admit that I remain a little suspicious.
Greetings,
wilbert.
Previous Topic:Best practice to test M2T transformation
Next Topic:[Xtend2] Migration Scenarios?
Current Time: Wed May 12 23:29:37 GMT 2021
Powered by FUDForum. Page generated in 0.01822 seconds
