Re: [QVTO] CST, Pretty Printer [message #659920 is a reply to message #658048] |
Wed, 16 March 2011 06:59 |
Al Messages: 8 Registered: August 2010 |
I ended up writing one. It's pretty inchoate, but serves it's purpose for me.Hope it can help others too
modeltype QVT uses qvtoperational::expressions('http://www.eclipse.org/QVT/1.0.0/Operational');
modeltype ImpOCL uses ImperativeOCL('http://www.eclipse.org/qvt/1.0/ImperativeOCL');
modeltype OCL uses 'http://www.eclipse.org/ocl/1.1.0/OCL';
modeltype ECORE uses 'http://www.eclipse.org/emf/2002/Ecore';
transformation QvtPrettyPrinter(in qvtSrc : QVT);
property _tab_ : String = ' ';
main() {
var s := qvtSrc.rootObjects()[OperationalTransformation]->asOrderedSet()->first();
log(s.print(0));
helper printTabs(tabs : Integer) : String {
var i := 0;
var code := '';
while (i < tabs) {
code := code + _tab_;
i := i + 1;
return code;
helper printArgs(list : OrderedSet(ecore::EObject)) : String {
if (list->isEmpty()) then
return ""
endif;
var code : String := list->first().print(0);
var rest := list->subOrderedSet(2, list->size());
rest->forEach(expr) {
code := code + ', ' + expr.print(0);
return code;
helper printArgs(list : OrderedSet(ecore::EModelElement)) : String {
return ""
endif;
return code;
helper printArgs(list : OrderedSet(ocl::utilities::ASTNode)) : String {
return ""
endif;
return code;
helper printExpressions(exprList : OrderedSet(ocl::ecore::OCLExpression), tabs : Integer) : String {
var code : String;
exprList->forEach(expr) {
code := code + printTabs(tabs) + expr.print(tabs) + ';\n';
return code;
helper ecore::EObject::print(tabs : Integer) : String {
var nameFeature := self.eClass().getEStructuralFeature('name');
return self.eGet(nameFeature).oclAsType(String);
helper ecore::EStructuralFeature::print(tabs : Integer) : String {
var code : String := self.name;
return code;
helper ecore::EModelElement::print(tabs : Integer) : String {
assert(true);
return "";
helper ocl::utilities::ASTNode::print(tabs : Integer) : String {
assert(true);
return "";
helper OperationalTransformation::print(tabs : Integer) : String {
var code : String := "";
self.usedModelType->forEach(mt) {
code := code + printTabs(tabs) + mt.print(0);
code := code + '\n' + printTabs(tabs) + 'transformation ' + self.name + '(';
code := code + printArgs(self.modelParameter);
code := code + ');\n';
self.configProperty->forEach(p) {
code := code + '\nconfiguration property ' + p.name + ' : ' + p.eType.name + ';\n';
var set := self.eAllStructuralFeatures - self.configProperty;
set->forEach(p|p.oclIsKindOf(EAttribute)) {
var pa := p.oclAsType(EAttribute);
code := code + '\nproperty ' + pa.name + ' : ' + pa.eType.name;
code := code + ' = ' + pa.eAnnotations.contents->first().oclAsType(ocl::ecore::OCLExpression).print(0) + ';\n';
code := code + '\n' + self.entry.print(tabs);
self.eOperations->forEach(op | op.oclIsKindOf(MappingOperation)) {
code := code + '\n' + op.oclAsType(MappingOperation).print(tabs);
self.eOperations->forEach(op | op.oclIsKindOf(Helper)) {
code := code + '\n' + op.oclAsType(Helper).print(tabs);
return code;
helper ModelType::print(tabs : Integer) : String {
var code : String := 'modeltype ' + self.name;
if (self.conformanceKind != null) then {
code := code + ' "' + self.conformanceKind + '"';
endif;
code := code + ' uses ';
var package := self._metamodel->first();
var meta : String := package.name;
package := package.eSuperPackage;
while (package != null) {
meta := package.name + '::' + meta;
code := code + meta + '(' + self._metamodel->first().nsURI.quotify('\'') + ');' + '\n';
return code;
helper ModelParameter::print(tabs : Integer) : String {
var code : String := self.kind.repr() + ' ' + self.name + ': ' + self.eType.name;
return code;
helper VarParameter::print(tabs : Integer) : String {
var code : String := self.name + ' : ' + self.eType.name;
return code;
helper EntryOperation::print(tabs : Integer) : String {
var code : String = printTabs(tabs) + 'main() {\n';
code := code + self.body.print(tabs + 1) + printTabs(tabs) + '}\n';
return code;
helper Helper::print(tabs : Integer) : String {
var code : String = printTabs(tabs) + 'helper ';
if (self.context != null) then {
code := code + self.context.eType.name + '::';
endif;
code := code + self.name;
code := code + '(' + printArgs(self.eParameters) + ')';
code := code + ' : ' + printArgs(self._result) + ' {\n';
code := code + self.body.print(tabs + 1);
code := code + printTabs(tabs) + '}\n';
return code;
helper MappingParameter::print(tabs : Integer) : String {
return code;
helper MappingOperation::print(tabs : Integer) : String {
var code : String = printTabs(tabs) + 'mapping ' + self.context.eType.name + '::' + self.name;
code := code + ' : ' + printArgs(self._result);
if (self._when->notEmpty()) then {
code := code + '\n' + printTabs(tabs) + 'when { ' + self._when->first().print(0);
var rest := self._when->asSequence()->subSequence(2, self._when->size());
code := code + '; ' + expr.print(0);
code := code + ' }';
endif;
code := code + '\n' + printTabs(tabs) + '{\n';
return code;
helper OperationBody::print(tabs : Integer) : String {
var code : String := printExpressions(self.content, tabs);
return code;
helper MappingBody::print(tabs : Integer) : String {
var code : String;
var needsPopulation := self.initSection->notEmpty();
if self.initSection->notEmpty() then {
code := printTabs(tabs) + 'init {\n';
code := code + printExpressions(self.initSection, tabs + 1);
endif;
if needsPopulation then {
code := code + printTabs(tabs) + 'population {\n';
code := code + printExpressions(self.content, tabs + 1);
else {
code := code + printExpressions(self.content, tabs);
endif;
if self.endSection->notEmpty() then {
code := code + printTabs(tabs) + 'end {\n';
code := code + printExpressions(self.endSection,tabs + 1);
endif;
return code;
helper MappingCallExp::print(tabs : Integer) : String {
var code : String := self.source.print(0) + '.' + 'map ';
code := code + self.referredOperation.print(0) + '(' + printArgs(self.argument) + ')';
return code;
helper ImperativeIterateExp::print(tabs : Integer) : String {
var code : String := self.source.print(0) + '->' +
self.name +
var iter := self.iterator->first().repr();
code := code + iter;
var iter := self.iterator->first().oclAsType(ocl::ecore::Variable);
code := code + iter.name + ' : ' + iter.eType.name;
self.iterator->subOrderedSet(2,self.iterator->size())->forEach(it) {
iter := it.oclAsType(ocl::ecore::Variable);
code := code + ', ' + iter.name + iter.eType.name;
if (self.body != null) then
code := code + '|' + self.body.print(0)
endif;
if (self.condition != null) then
code := code + '|' + self.condition.print(0)
endif;
code := code + ')';
return code;
helper ImperativeLoopExp::print(tabs : Integer) : String {
self.name +
if (self.condition != null) then {
endif;
code := code + ')';
if (self.body != null) then {
code := code + self.body.print(tabs);
endif;
return code;
helper ObjectExp::print(tabs : Integer) : String {
var code : String := 'object ' + self.referredObject.name;
code := code + ' : ' + self.eType.name + ' {\n';
code := code + printTabs(tabs) + '}';
return code;
helper SwitchExp::print(tabs : Integer) : String {
var code : String := 'switch {\n';
code := code + printExpressions(self.alternativePart, tabs + 1);
if (self.elsePart != null) then {
code := code + '\n' + printTabs(tabs + 1) + 'else ' + self.elsePart.print(tabs + 1);
endif;
code := code + '\n' + printTabs(tabs) + '}';
return code;
helper AltExp::print(tabs : Integer) : String {
var code : String := 'case ' + ' (' + self.condition.print(0) + ')\n';
code := code + printTabs(tabs) + self.body.print(tabs);
return code;
helper AssertExp::print(tabs : Integer) : String {
var code : String := 'assert(' + self.assertion.print(0) + ')';
return code;
helper AssignExp::print(tabs : Integer) : String {
var code : String := self.left.print(0);
code := code + ' := ';
self.value->forEach(expr) {
code := code + expr.print(0);
return code;
helper BlockExp::print(tabs : Integer) : String {
var code : String := '{\n';
code := code + printExpressions(self.body,tabs + 1);
return code
helper BreakExp::print(tabs : Integer) : String {
var code : String := 'break';
return code;
helper CatchExp::print(tabs : Integer) : String {
var code : String := 'catch';
return code;
helper ComputeExp::print(tabs : Integer) : String {
var code : String := 'compute(' + self.returnedElement.repr() + ') ';
return code;
helper ContinueExp::print(tabs : Integer) : String {
var code : String := 'continue';
return code;
helper ForExp::print(tabs : Integer) : String {
return code;
helper InstantiationExp::print(tabs : Integer) : String {
var code : String := 'InstantiationExpNotImpl';
return code;
helper DictLiteralPart::print(tabs : Integer) : String {
var code : String := self.key.print(tabs) + ' = ' + self.value.print(tabs);
return code;
helper DictLiteralExp::print(tabs : Integer) : String {
var code : String := 'Dict { ';
code := code + printArgs(self.part->asOrderedSet());
return code;
helper ListLiteralExp::print(tabs : Integer) : String {
var code : String := 'ListLiteralExpNotImpl';
return code;
helper LogExp::print(tabs : Integer) : String {
var code : String := 'log(' + printArgs(self.argument) + ')';
return code;
helper RaiseExp::print(tabs : Integer) : String {
var code : String := 'raise';
return code;
helper ReturnExp::print(tabs : Integer) : String {
var code : String := 'return ' + self.value.print(tabs);
return code;
helper TryExp::print(tabs : Integer) : String {
var code : String := 'try';
return code;
helper Typedef::print(tabs : Integer) : String {
var code : String := 'typedef';
return code;
helper UnlinkExp::print(tabs : Integer) : String {
var code : String := 'unlink';
return code;
helper UnpackExp::print(tabs : Integer) : String {
var code : String := 'unpack';
return code;
helper VariableInitExp::print(tabs : Integer) : String {
var code := 'var ' + self.referredVariable.name + ' : ' + self.referredVariable.eType.name;
if (self.referredVariable.initExpression != null) then {
var iexp := self.referredVariable.initExpression;
code := code + ' := ' + iexp.print(tabs);
endif;
return code;
helper WhileExp::print(tabs : Integer) : String {
var code : String := 'while (' + self.condition.print(0) + ') ';
return code;
helper ocl::ecore::VariableExp::print(tabs : Integer) : String {
var code := self.name;
return code;
helper ocl::expressions::VariableExp::print(tabs : Integer) : String {
var code := self.referredVariable.print(0);
return code;
helper ocl::ecore::Variable::print(tabs : Integer) : String {
return code;
helper ocl::expressions::Variable::print(tabs : Integer) : String {
var code : String;
return code;
helper ocl::expressions::PropertyCallExp::print(tabs : Integer) : String {
return null;
helper ocl::ecore::TypeExp::print(tabs : Integer) : String {
var code : String := self.referredType.print(0);
return code;
helper ocl::ecore::CollectionLiteralExp::print(tabs : Integer) : String {
var code := self.part->first().oclAsType(ocl::ecore::CollectionItem).item.print(0);
return code;
helper ocl::expressions::CollectionLiteralExp::print(tabs : Integer) : String {
return code;
helper ocl::expressions::StringLiteralExp::print(tabs : Integer) : String {
var code : String := '\'' + self.stringSymbol + '\'';
return code;
helper ocl::ecore::IntegerLiteralExp::print(tabs : Integer) : String {
var code : String := self.integerSymbol.toString();
return code;
helper ocl::expressions::IntegerLiteralExp::print(tabs : Integer) : String {
return code;
helper ocl::ecore::BooleanLiteralExp::print(tabs : Integer) : String {
var code : String := if self.booleanSymbol = true then
'true'
else
'false'
endif;
return code;
helper ocl::ecore::EnumLiteralExp::print(tabs : Integer) : String {
var code : String := self.eType.name + '::';
code := code + self.referredEnumLiteral.print(0);
return code;
helper ocl::expressions::BooleanLiteralExp::print(tabs : Integer) : String {
'true'
else
'false'
endif;
return code;
helper ocl::ecore::IteratorExp::print(tabs : Integer) : String {
self.name +
var iter := self.iterator->first().oclAsType(ocl::ecore::Variable).print(0);
// var iter := self.iterator->first().oclAsType(ocl::ecore::Variable);
// code := code + iter.name + ' : ' + iter.eType.name;
// self.iterator->subOrderedSet(2,self.iterator->size())->forEach(it) {
// iter := it.oclAsType(ocl::ecore::Variable);
// code := code + ', ' + iter.name + iter.eType.name;
endif;
code := code + ')';
return code;
helper ocl::ecore::StringLiteralExp::print(tabs : Integer) : String {
var code : String := self.stringSymbol.replace('\n','\\n').replace('\t','\\t').quotify('\'');
return code;
helper ocl::ecore::OperationCallExp::print(tabs : Integer) : String {
var code : String := self.source.print(0);
if (self.source.getType().oclIsKindOf(ocl::ecore::CollectionType)) then {
code := code + '->';
else {
code := code + '.';
endif;
code := code + self.referredOperation.oclAsType(ecore::EOperation).name + '(';
code := code + printArgs(self.argument) + ')';
return code;
helper ocl::ecore::PropertyCallExp::print(tabs : Integer) : String {
code := code + '.' + self.referredProperty.print(0);
//Sequence{self.referredProperty}->switch(p) {
// case (p.oclIsKindOf(EAttribute)) {code := code + '.' + self.referredProperty.oclAsType(EAttribute).name}
// case (p.oclIsKindOf(EReference)) {code := code + '.' + self.referredProperty.oclAsType(EReference).name}
// else {}
return code;
helper ocl::ecore::IfExp::print(tabs : Integer) : String {
var code : String := 'if ' + '(' + self.condition.print(0) + ')' + ' then ';
code := code + self.thenExpression.print(tabs) + '\n';
if self.elseExpression != null then {
code := code + printTabs(tabs) + 'else ' + self.elseExpression.print(tabs) + '\n';
endif;
code := code + printTabs(tabs) + 'endif';
return code;
helper ocl::ecore::OCLExpression::print(tabs : Integer) : String {
var code : String := self.repr();
return code;
helper ocl::expressions::OCLExpression::print(tabs : Integer) : String {
return code;
FUDForum. Page generated in 0.03307 seconds
