Re: p2 update site binary folder [message #657950 is a reply to message #657943] |
Fri, 04 March 2011 17:11 |
NOt sure how you came to that conclusion. The binary folder contains opaque files that are handles by p2. They shouldn't
have any extensions and they are not treated as folders.
- thomas
On 2011-03-04 18:01, Alex wrote:
> Hello,
> I am having problem with using update site for a product. Update site file tree looks like this:
> artifacts.jar
> binary [folder]
> content.jar
> features
> plugins
> Binary folder contains product executables for different platforms, but they don't have .jar extensions at the end and I
> guess treated as directories. As a result, when I try to update I get message that file could not be found.
> Here is the screenshot of binary directory http://i.imgur.com/jKvDm.png
> Thanks for your help,
> Alex
Re: p2 update site binary folder [message #657965 is a reply to message #657951] |
Fri, 04 March 2011 18:01 |
On 2011-03-04 18:26, Alex wrote:
> So why am I getting 404 on these files during update? And what does
> "opaque files that are handles by p2" mean?
It means that those files are managed internally by p2 and shouldn't be
accessed directly. If you get 404's during update, then I guess your p2
repository is corrupted somehow.
- thomas
Re: p2 update site binary folder [message #657977 is a reply to message #657965] |
Fri, 04 March 2011 19:04 |
Chauncey Xu Messages: 12 Registered: October 2010 |
Thomas Hallgren wrote on Fri, 04 March 2011 13:01 | On 2011-03-04 18:26, Alex wrote:
- thomas
Hi thomas, thanks for your reply. Alex helped me post this question.
I think the p2 repository itself is fine because i can use it as a local update site. It is only when it's used on a server that caused the referred connection problem. We have eliminated server or platform problems.
What other possibilities are there?
Thanks again.
[Updated on: Fri, 04 March 2011 19:05] Report message to a moderator
Re: p2 update site binary folder [message #657987 is a reply to message #657977] |
Fri, 04 March 2011 19:31 |
>> be accessed directly. If you get 404's during update, then I guess
>> your p2 repository is corrupted somehow.
>> - thomas
> update site. It is only when it's used on a server that it caused that
I don't know. A 404 means that your server claims that the file isn't
found. p2 will try to access the file using it's full name so it will
not need browse privileges. Do you get a 404 in a browser too if you try
and access the file from there?
- thomas
FUDForum. Page generated in 0.07492 seconds
