standaloneUpdate -search "connection error" [message #657791] |
Fri, 04 March 2011 04:48 |
Originally posted by: lab2k1.gmail.c0m
I am running a fresh v3.6.2 and toying with the update manager.
The documented command for "searching a remote site, listing
all available features for install"
java -jar plugins/org.eclipse.equinox.launcher_<version>.jar
-application org.eclipse.update.core.standaloneUpdate
-command search -from remote_site_url
fails for remote_site_url = http://download.eclipse.org/releases/helios/
with "Connection error / Command failed". The equivalent comand
eclipsec.exe -application org.eclipse.update.core.standaloneUpdate
-command search -from http://download.eclipse.org/releases/helios/
fails with the same error. Verified to happen on a couple different
machines. Both can "see" the remote site fine, and the packages are
listed correctly in eclipse's "install new" dialog, so it doesn't look
like a 'net problem, or dns etc.
The exact same commands work as expected with a local mirror
when replacing the remote_site_url = file:c/eclipse/repo/helios.
I have tried all variations of quotes or no quotes around the url, and
trailing slash or not - still no luck. Any ideas much appreciated about
how to fix it, or at least what to look for.
Liviu
FUDForum. Page generated in 0.03659 seconds
