Re: masterdetails update treeviewer [message #657917 is a reply to message #657905] |
Fri, 04 March 2011 15:20 |
Ed Merks Messages: 33113 Registered: July 2009 |
Where to you set the selection? I see you creating a TreeSelection, and
see you notifying that the selection has changed, but I don't see you
actually setting this to be the selection of an actual tree view. Have
you used the debugger to see what happens when you call
"selectionChanged"?
j.dufour wrote:
> Sorry, I must not understand your answer correctly.
> With the work about treepath, I think I set a new item to see it in
> the treeview, and when I raised the event, I think it must be refresh
> the treeview to see my new choice, but it doen't work ==> the
> selection is again the old selection.
Ed Merks
FUDForum. Page generated in 0.02592 seconds
