Error reading configuration: Unable to create lock manager [message #657458] |
Wed, 02 March 2011 20:26 |
I set my config string to
//Configure the Engine and start the Platform
config = new EngineConfig( );
config.setEngineHome( "/mydir/birt-runtime-2_6_1/ReportEngine" );
config.setLogConfig(null, Level.FINE);
Platform.startup(config);
The line Platform.startup(config) is the line that creates the error:
!ENTRY org.eclipse.osgi 4 0 2011-03-02 19:49:39.336
!MESSAGE Error reading configuration: Unable to create lock manager.
!STACK 0
java.io.IOException: Unable to create lock manager.
at org.eclipse.osgi.storagemanager.StorageManager.open(StorageM anager.java:687)
at org.eclipse.osgi.internal.baseadaptor.BaseStorage.initFileMa nager(BaseStorage.java:213)
at org.eclipse.osgi.internal.baseadaptor.BaseStorage.initialize (BaseStorage.java:147)
at org.eclipse.osgi.baseadaptor.BaseAdaptor.initializeStorage(B aseAdaptor.java:114)
at org.eclipse.osgi.framework.internal.core.Framework.initializ e(Framework.java:185)
at org.eclipse.osgi.framework.internal.core.Framework.<init>(Framework.java:157)
at org.eclipse.core.runtime.adaptor.EclipseStarter.startup(Ecli pseStarter.java:286)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
at org.eclipse.birt.core.framework.osgi.OSGILauncher.doStartup( OSGILauncher.java:191)
at org.eclipse.birt.core.framework.osgi.OSGILauncher.access$0(O SGILauncher.java:94)
at org.eclipse.birt.core.framework.osgi.OSGILauncher$1.run(OSGI Launcher.java:79)
at org.eclipse.birt.core.framework.osgi.OSGILauncher.startup(OS GILauncher.java:75)
at org.eclipse.birt.core.framework.Platform.startup(Platform.ja va:80)
at ExecuteModifiedReport.runReport(ExecuteModifiedReport.java:6 1)
at ExecuteModifiedReport.main(ExecuteModifiedReport.java:250)
What could the problem be? Any help is much appreciated as I've spent a good bit of time trying to figure this out.
Re: Error reading configuration: Unable to create lock manager [message #657460 is a reply to message #657458] |
Wed, 02 March 2011 20:33 |
I assume this is on a linux/unix machine? If so does the process have
write permission on the
/mydir/birt-runtime-2_6_1/ReportEngine/configuration directory?
Jason
On 3/2/2011 3:26 PM, azuniga wrote:
> I set my config string to //Configure the Engine and start the Platform
> !STACK 0
> anager.java:687)
> at
> ssorImpl.java:39)
> at java.lang.reflect.Method.invoke(Method.java:597)
> Launcher.java:79)
> at java.security.AccessController.doPrivileged(Native Method)
> GILauncher.java:75)
Re: Error reading configuration: Unable to create lock manager [message #657686 is a reply to message #657460] |
Thu, 03 March 2011 16:10 |
Jason, thanks for the quick response. as you suspected there weren't write permissions in the configuration folder and so I changed it to 777 and I don't receive that error anymore. However, my project cannot load the JDBC driver class: oracle.jdbc.driver.OracleDriver. Am I right to think that I should place the oracle.jdbc.driver.OracleDriver in the eclipse_all-in-one_with_BIRT/eclipse/plugins/org.eclipse.bir t.report.data.oda.jdbc_2.6.0.v20100524/drivers/ file? If so, I already have in there the ojdbc14.jar and i thought this was the driver. I have 2 projects, 1 that is designed using the report designer view and produces my .rptdesign. This project works fine and connects to the database and performs the queries and returns good results and my charts and graphs. I've got my Data Source set up and my data sets set up. However, my 2nd project I am trying to take this same .rptdesign and programmatically run it, using the already set up data source and data set, and this is where i am encountering problems.
The following items have errors:
Chart (id = 45):
+ An exception occurred during processing. Please see the following message for details:
Cannot open the connection for the driver: org.eclipse.birt.report.data.oda.jdbc.
org.eclipse.birt.report.data.oda.jdbc.JDBCException: Cannot load JDBC Driver class: oracle.jdbc.driver.OracleDriver.
exception.error ( 1 time(s) )
detail : org.eclipse.birt.report.engine.api.EngineException: An exception occurred during processing. Please see the following message for details:
at org.eclipse.birt.report.engine.executor.ExtendedGenerateExec utor.execute(ExtendedGenerateExecutor.java:70)
at org.eclipse.birt.report.engine.executor.ExtendedItemExecutor .execute(ExtendedItemExecutor.java:62)
at org.eclipse.birt.report.engine.internal.executor.dup.Suppres sDuplicateItemExecutor.execute(SuppressDuplicateItemExecutor .java:43)
at org.eclipse.birt.report.engine.internal.executor.wrap.Wrappe dReportItemExecutor.execute(WrappedReportItemExecutor.java:4 6)
at org.eclipse.birt.report.engine.internal.executor.l18n.Locali zedReportItemExecutor.execute(LocalizedReportItemExecutor.ja va:34)
at org.eclipse.birt.report.engine.layout.html.HTMLBlockStacking LM.layoutNodes(HTMLBlockStackingLM.java:65)
at org.eclipse.birt.report.engine.layout.html.HTMLPageLM.layout (HTMLPageLM.java:90)
at org.eclipse.birt.report.engine.layout.html.HTMLReportLayoutE ngine.layout(HTMLReportLayoutEngine.java:99)
at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doR un(RunAndRenderTask.java:180)
at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.run (RunAndRenderTask.java:77)
at ExecuteModifiedReport.runReport(ExecuteModifiedReport.java:1 25)
at ExecuteModifiedReport.main(ExecuteModifiedReport.java:252)
Caused by: org.eclipse.birt.report.data.adapter.api.AdapterException: An exception occurred during processing. Please see the following message for details:
at org.eclipse.birt.report.data.adapter.impl.DataRequestSession Impl.execute(DataRequestSessionImpl.java:637)
at org.eclipse.birt.report.engine.data.dte.DteDataEngine.doExec uteQuery(DteDataEngine.java:152)
at org.eclipse.birt.report.engine.data.dte.AbstractDataEngine.e xecute(AbstractDataEngine.java:265)
at org.eclipse.birt.report.engine.executor.ExtendedGenerateExec utor.executeQueries(ExtendedGenerateExecutor.java:205)
at org.eclipse.birt.report.engine.executor.ExtendedGenerateExec utor.execute(ExtendedGenerateExecutor.java:65)
... 11 more
Caused by: org.eclipse.birt.data.engine.odaconsumer.OdaDataException: Cannot open the connection for the driver: org.eclipse.birt.report.data.oda.jdbc.
at org.eclipse.birt.data.engine.odaconsumer.ExceptionHandler.ne wException(ExceptionHandler.java:54)
at org.eclipse.birt.data.engine.odaconsumer.ConnectionManager.o penConnection(ConnectionManager.java:177)
at org.eclipse.birt.data.engine.executor.DataSource.newConnecti on(DataSource.java:222)
at org.eclipse.birt.data.engine.executor.DataSource.open(DataSo urce.java:210)
at org.eclipse.birt.data.engine.impl.DataSourceRuntime.openOdiD ataSource(DataSourceRuntime.java:208)
at org.eclipse.birt.data.engine.impl.QueryExecutor.openDataSour ce(QueryExecutor.java:406)
at org.eclipse.birt.data.engine.impl.QueryExecutor.prepareExecu tion(QueryExecutor.java:316)
at org.eclipse.birt.data.engine.impl.PreparedQuery.doPrepare(Pr eparedQuery.java:448)
at org.eclipse.birt.data.engine.impl.PreparedDataSourceQuery.pr oduceQueryResults(PreparedDataSourceQuery.java:190)
at org.eclipse.birt.data.engine.impl.PreparedDataSourceQuery.ex ecute(PreparedDataSourceQuery.java:178)
at org.eclipse.birt.data.engine.impl.PreparedOdaDSQuery.execute (PreparedOdaDSQuery.java:145)
at org.eclipse.birt.report.data.adapter.impl.DataRequestSession Impl.execute(DataRequestSessionImpl.java:617)
... 15 more
Caused by: org.eclipse.birt.report.data.oda.jdbc.JDBCException: Cannot load JDBC Driver class: oracle.jdbc.driver.OracleDriver.
at org.eclipse.birt.report.data.oda.jdbc.JDBCDriverManager.find Driver(JDBCDriverManager.java:760)
at org.eclipse.birt.report.data.oda.jdbc.JDBCDriverManager.regi sterDriver(JDBCDriverManager.java:879)
at org.eclipse.birt.report.data.oda.jdbc.JDBCDriverManager.load AndRegisterDriver(JDBCDriverManager.java:862)
at org.eclipse.birt.report.data.oda.jdbc.JDBCDriverManager.doCo nnect(JDBCDriverManager.java:246)
at org.eclipse.birt.report.data.oda.jdbc.JDBCDriverManager.getC onnection(JDBCDriverManager.java:212)
at org.eclipse.birt.report.data.oda.jdbc.Connection.connectByUr l(Connection.java:235)
at org.eclipse.birt.report.data.oda.jdbc.Connection.open(Connec tion.java:160)
at org.eclipse.datatools.connectivity.oda.consumer.helper.OdaCo nnection.open(OdaConnection.java:250)
at org.eclipse.birt.data.engine.odaconsumer.ConnectionManager.o penConnection(ConnectionManager.java:165)
... 25 more
Chart (id = 46):
... 11 more
... 15 more
... 25 more
Table (id = 4):
at org.eclipse.birt.report.engine.executor.ExecutionContext.add Exception(ExecutionContext.java:1195)
at org.eclipse.birt.report.engine.executor.ExecutionContext.add Exception(ExecutionContext.java:1174)
at org.eclipse.birt.report.engine.executor.QueryItemExecutor.ex ecuteQuery(QueryItemExecutor.java:96)
at org.eclipse.birt.report.engine.executor.TableItemExecutor.ex ecute(TableItemExecutor.java:62)
at org.eclipse.birt.report.engine.executor.ExecutionContext.exe cuteQuery(ExecutionContext.java:1876)
at org.eclipse.birt.report.engine.executor.QueryItemExecutor.ex ecuteQuery(QueryItemExecutor.java:80)
... 11 more
... 15 more
... 25 more
Table table:
+ A BIRT exception occurred: Error evaluating Javascript expression. Script engine error: ReferenceError: "dataSetRow" is not defined.
Script source: , line: 0, text:
dataSetRow["COUNTRY"]. See next exception for more information.
What could the issue be?
[Updated on: Thu, 03 March 2011 16:58] Report message to a moderator
Re: Error reading configuration: Unable to create lock manager [message #657709 is a reply to message #657686] |
Thu, 03 March 2011 16:42 |
Do you have the driver in the jdbc plugin's drivers directory?
Jason
> the JDBC driver class: oracle.jdbc.driver.OracleDriver. The following
> items have errors:
> Chart (id = 45):
> for details:
> for details:
> ... 11 more
> urce.java:210)
> ... 15 more
> tion.java:160)
> ... 25 more
> Chart (id = 46):
> for details:
> for details:
> ... 11 more
> urce.java:210)
> ... 15 more
> tion.java:160)
> ... 25 more
> Table (id = 4):
> for details:
> for details:
> ... 11 more
> urce.java:210)
> ... 15 more
> tion.java:160)
> ... 25 more
> Table table:
Re: Error reading configuration: Unable to create lock manager [message #657726 is a reply to message #657709] |
Thu, 03 March 2011 17:51 |
I edited the post but it seems like it was after you got the chance to respond. I placed the ojdbc14.jar in the eclipse_all-in-one_with_BIRT/eclipse/plugins/org.eclipse.bir t.report.data.oda.jdbc_2.6.0.v20100524/drivers/ file? is this the correct driver? I have 2 projects, 1 that is designed using the report designer view and produces my .rptdesign. This project works fine and connects to the database and performs the queries and returns good results and my charts and graphs. I've got my Data Source set up and my data sets set up. However, my 2nd project I am trying to take this same .rptdesign and programmatically run it, using the already set up data source and data set, and this is where i am encountering problems.
Re: Error reading configuration: Unable to create lock manager [message #657729 is a reply to message #657709] |
Thu, 03 March 2011 18:09 |
Alright, I ended up right clicking on the project>Run As>Run Configurations>Classpath and then adding the external jar: ojdbc14.jar to the bootstrap entries section and to the user entries section. It now works. Question is, will I have to do this for all the projects i create that will use an oracle database? Thanks for your help Jason.
-Alessandro
Re: Error reading configuration: Unable to create lock manager [message #657730 is a reply to message #657726] |
Thu, 03 March 2011 17:55 |
If this is where you have the runtime:
The driver needs to be in the jdbc plugin's driver directory under:
" /mydir/birt-runtime-2_6_1/ReportEngine/plugins/--jdbcplugin- -/drivers
directory.
Jason
Re: Error reading configuration: Unable to create lock manager [message #657737 is a reply to message #657729] |
Thu, 03 March 2011 18:19 |
If you put it in the runtime plugins directory you should not have to do
this.
Jason
> -Alessandro
FUDForum. Page generated in 0.04142 seconds
