Home » Modeling » M2T (model-to-text transformation) » [xpand/xtend] xtend expression retuns a string between square brakets(xtend invocation retuns a string between square brakets)
[xpand/xtend] xtend expression retuns a string between square brakets [message #656993] Tue, 01 March 2011 10:06 Go to next message
Elisa Herrmann is currently offline Elisa HerrmannFriend
I have an xtend expression that is supposed to returns: String but it returns [String].
This is the xtend expression
import NETSTMM;
String datatypeconv(NETSTMM::Languages l,NETSTMM::DataTypeKind partype ):
if l.toString().trim()=='vbnet' then
	{if (partype!=null) then
		switch (partype.toString()) {
		case 'DateTime':'Date'
		case 'int':'Integer'
		case 'Bool':'Boolean'
		case 'decimal':'Decimal'
		default: partype.toString().trim()
	else
		"String"
else
	switch (partype.toString().trim()) {
	case 'Date':'DateTime'
	case 'String':'string'
	case 'Integer':'int'
this is the xpand template to call it
ByVal «M.NMthHasPar.PName» As «datatypeconv(M.NMBelongsMC.MCBelongsPr.PrLanguage,M.NMthHasPar.first().PType)» _
and this is the result
ByVal Param1 As [String], _
but I need it to retuns
ByVal Param1 As String, _
Any ideas?
Elisa
Re: [xpand/xtend] xtend expression retuns a string between square brakets [message #657005 is a reply to message #656993] Tue, 01 March 2011 10:53 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
hi,
the {} operator creates a List
{"a"} gets [a] if you call to String on it / it is printed in the template.
so with
if l.toString().trim()=='vbnet' then {
} else
you construct a list in the if case.
~Christian
Twitter : @chrdietrich
[Updated on: Tue, 01 March 2011 11:00]
Report message to a moderator
Re: [xpand/xtend] xtend expression retuns a string between square brakets [message #657034 is a reply to message #657005] Tue, 01 March 2011 12:14 Go to previous message
Thanks Christian,
I have exechanged the "{}" for the "( )" and It works!
Elisa
Previous Topic:executeworkflow leading to out of memory error
Next Topic:[Acceleo 3] Overriding Templates
Current Time: Tue Apr 16 22:06:01 GMT 2024
Powered by FUDForum. Page generated in 0.34918 seconds
