Re: Preventing SQL Injection [message #656889 is a reply to message #656884] |
Mon, 28 February 2011 21:55 |
Josh,
Why not just check for the all before you append it to the sql in script?
Jason
On 2/28/2011 4:35 PM, Josh wrote:
> Typically I use query parameters in my BIRT data sets to avoid SQL
> injection attacks:-
> select *
> from user
> where organization_id = ?
> However, using the above example, if I need to allow 'All' organizations
> as a possible selection from the user, I (poorly) handle it like this:-
> select *
> from user
> and I add the where clause manually in the event handler if the user
> actually selects an Organization.
> dataSet.setQueryText(dataSet.getQueryText() +
> myWhereClauseIncludingUserEnteredData);
> This leaves my reports vulnerable to injection attacks. Any suggestions
> on how to handle the 'All' option without the security risk of the
> injection attack?
Re: Preventing SQL Injection [message #657087 is a reply to message #656892] |
Tue, 01 March 2011 15:11 |
Is the all in a report parameter? If so just check its value in the
dataset beforeOpen script before you modify the sql. You can check it
by using params["myparameter"].value
Jason
On 2/28/2011 5:23 PM, Josh wrote:
> Yes I do do that (I was just trying to keep my examples brief). It's
> when the user selects a specific organization that I have to append the
> SQL. But because the where clause is optional (because of the
> possibility of 'All' being selected) I cannot use a query parameter.
Re: Preventing SQL Injection [message #657197 is a reply to message #657187] |
Tue, 01 March 2011 21:52 |
I do not think it is better, but you could create 2 datasets, one with a
query parameter and one without and in the beforeFactory set the dataset
for the table that uses it.
Jason
On 3/1/2011 4:18 PM, Josh wrote:
> Yes, I am doing that. I think you're missing the point. What I'm saying
> is:-
> *Having the 'All' option means I have to programatically concatenate the
> SQL.
> *Concatenating the SQL = injection vulnerability.
> **Is there a better way to handle this?
Re: Preventing SQL Injection [message #657363 is a reply to message #656884] |
Wed, 02 March 2011 14:58 |
I reference the parameter twice, and code the WHERE clause as
"WHERE stringfield = ? or ? = 'ALL'"
If the parameter is numeric, I generally use zero as the ALL equivalent.
As long as the parameter is single-select, that seems to work well for me.
FUDForum. Page generated in 0.03544 seconds
