Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [EEF] NPE when selecting to add a relation
Re: [EEF] NPE when selecting to add a relation [message #657224 is a reply to message #657201] |
Wed, 02 March 2011 01:37 |
Alain Picard Messages: 266 Registered: July 2009 |
On 3/1/2011 5:35 PM, Ed Merks wrote:
Ed,
The example is a simple modification of the model1.ecore from CDO again,
just with the offending Map$Entry removed.
I just found a very interesting thing. In
org.eclipse.emf.eef.runtime.ui.widgets.settings.AdvancedEEFE ditorContentProvider.getElements
we have:
public Object[] getElements(Object object) {
if (object instanceof EEFEditorSettings) {
EList<Resource> resources =
((EEFEditorSettings)object).getSource().eResource().getResou rceSet().getResources();
resources.retainAll(this.choiceOfValues);
return resources.toArray();
return super.getElements(object);
what happens is that if I click the + button on a widget implemented
with AdvancedReferencesTable when there is no reference content that
exist, the getElements() method is called a first time and there is no
error, but resources is set to an empty list. Then when it calls
resources.retainAll with an empty choice a values, the retainAll ends up
calling remove, which calls inverseRemove which ends with:
return resource.basicSetResourceSet(null, notifications); resetting the
Resourceset value to null.
Then on the following calls, the resourceset is null and voila, an NPE.
HTH,
Alain
> Alain,
> I imagine they'll likely need a test case for this if you want to report
> it as a bug. In the mean time, you could determine the URI of that
> resource, who's creating a resource URI, and why it's not created as
> part of a resource set. It's quite unusual to have "free floating"
> resources...
> Alain Picard wrote:
>> On 3/1/2011 11:01 AM, Ed Merks wrote:
>>> Alain,
>>> It's a little odd that you'd have a resource that isn't in a resource
>>> set. How does that happen?
>> Not sure but it does. :)
>> Alain
>>> Alain Picard wrote:
>>>> I am getting an NPE when selecting to add a relation
>>>> The stack trace is:
>>>> java.lang.NullPointerException at
>>>> org.eclipse.emf.eef.runtime.ui.widgets.settings.AdvancedEEFE ditorContentProvider.getElements(AdvancedEEFEditorContentPro vider.java:65)
>>>> org.eclipse.jface.viewers.StructuredViewer.getRawChildren(St ructuredViewer.java:989)
>>>> org.eclipse.jface.viewers.ColumnViewer.getRawChildren(Column Viewer.java:703)
>>>> org.eclipse.jface.viewers.AbstractTreeViewer.getRawChildren( AbstractTreeViewer.java:1332)
>>>> org.eclipse.jface.viewers.TreeViewer.getRawChildren(TreeView er.java:391)
>>>> which point to this line of code:
>>>> and it happens because the getResourceSet() portion is returning null.
>>>> If I create at least one entry matching the relation the error goes
>>>> away and I see the dialog allowing me to select from the Model
>>>> Resource or All Resource.
>>>> Thanks
>>>> Alain
Re: [EEF] NPE when selecting to add a relation [message #657234 is a reply to message #657224] |
Wed, 02 March 2011 03:59 |
Ed Merks Messages: 33140 Registered: July 2009 |
Alain,
Comments below.
> Ed,
> again, just with the offending Map$Entry removed.
> we have:
Modifying the resource set itself as part of producing a view for it
seems totally bad! This code should make a copy of the list of resources...
> up calling remove, which calls inverseRemove which ends with:
> the Resourceset value to null.
> HTH,
> Alain
>> Alain,
>> resources...
>>>> Alain,
>>> Alain
>>>>> The stack trace is:
>>>>> null.
>>>>> Thanks
>>>>> Alain
Ed Merks
Re: [EEF] NPE when selecting to add a relation [message #658194 is a reply to message #657234] |
Mon, 07 March 2011 11:21 |
Goulwen Le Fur Messages: 125 Registered: July 2009 |
It's an important bug. I fix it in the next EEF 0.9 RC.
Goulwen Le Fur - goulwen.lefur@obeo.fr
Le 02/03/2011 04:59, Ed Merks a écrit :
> Alain,
> Comments below.
>> Ed,
>> we have:
>> HTH,
>> Alain
>>> Alain,
>>> resources...
>>>>> Alain,
>>>> Alain
>>>>>> The stack trace is:
>>>>>> null.
>>>>>> Thanks
>>>>>> Alain
Current Time: Thu Apr 25 00:51:39 GMT 2024
Powered by FUDForum. Page generated in 0.03427 seconds
