JavaServer Faces 2.0 facet [message #656800] |
Mon, 28 February 2011 16:21 |
(Sorry for hijacking another thread to ask this, I've canceled that
message; here's the formal question on its own thread:)
I find myself unable to modify a Dynamic Web Project's Preferences ->
Project Facets -> JavaServer Faces to 2.0 from 1.2 and I can't find
anything too useful out in webland to help me do this for Helios.
Would someone enlighten me?
Russ Bateman
Re: JavaServer Faces 2.0 facet [message #656874 is a reply to message #656852] |
Mon, 28 February 2011 20:22 |
> Changing jsf facet version on an existing project is not
> supported, unfortunately. See https://bugs.eclipse.org/bugs/show_bug.cgi?id=201792
> You can still do so by manually editing an xml file in .settings folder,
> but you can't do so via UI.
Yury,
How does it get set (to 2.0) in the first place? I don't know how to do
that. There used to be additional entries for the first page of the new
Dynamic Web Project wizard's Configuration drop-down.
Thanks for your answer(s).
Russ
Re: JavaServer Faces 2.0 facet [message #657188 is a reply to message #657178] |
Tue, 01 March 2011 21:01 |
> It can be set when the project is created, same way it always worked.
> There should be "JavaServer Faces 2.0" configuration in the drop down,
> assuming you have web 3.0 level selected.
Wow, I feel like I'm brand new to this stuff.
Looking at two workspaces on my host, I see that new Dynamic Web Project
has a Dynamic web module version of 3.0 (and Configuration JavaServer
Faces v2.0 Project possible) available and, another, only 2.5 (and
Configuration has only JavaServer Faces v1.2 Project).
How did I configure the one workspace to be limited to 2.5 and the other
to allow 3.0? I don't remember doing anything when I created the second
workspace (which happens to be the one I do my JSF work in) to limit this.
At what moment do I endow a workspace with Dynamic web module version
(3.0) and Configuration (JavaServer Faces v2.0 Project)?
I looked at all the Preferences and couldn't find anything to change.
Re: JavaServer Faces 2.0 facet [message #657221 is a reply to message #657190] |
Wed, 02 March 2011 00:29 |
> It can be limited to 2.5 if you have "Add to EAR" checked and the existing EAR
> is at 2.5 level. Or it could be limited to 2.5 if you are targeting a server runtime
> that only supports 2.5.
I see that Apache Tomcat v6.0's presence limits this while v7.0 does not.
Thanks.
FUDForum. Page generated in 0.04169 seconds
