Re: [EEF] Issue with Map$Entry [message #662169 is a reply to message #662106] |
Tue, 29 March 2011 15:31 |
Ed Merks Messages: 33137 Registered: July 2009 |
This is an EEF question? Teneo may not even support generation unless
you run as an Eclipse application...
mil123d wrote:
> Hello, I want all the steps to generate. ecore with teneo
> I did a project, but there are error
> could not found main class:org.eclipse.emf.teneo.jpa.GenerateORM
> progamm will exist
> and
> Usage: javaw [-options] class [args...]
> (to execute a class)
> or javaw [-options] -jar jarfile [args...]
> (to execute a jar file)
> where options include:
> -client to select the "client" VM
> -server to select the "server" VM
> -hotspot is a synonym for the "client" VM [deprecated]
> The default VM is client.
> -cp <class search path of directories and zip/jar
> files>
> -classpath <class search path of directories and zip/jar files>
> A ; separated list of directories, JAR archives,
> and ZIP archives to search for class files.
> -D<name>=<value>
> set a system property
> -verbose[:class|gc|jni]
> enable verbose output
> -version print product version and exit
> -version:<value>
> require the specified version to run
> -showversion print product version and continue
> -jre-restrict-search | -jre-no-restrict-search
> include/exclude user private JREs in the version search
> -? -help print this help message
> -X print help on non-standard options
> -ea[:<packagename>...|:<classname>]
> -enableassertions[:<packagename>...|:<classname>]
> enable assertions
> -da[:<packagename>...|:<classname>]
> -disableassertions[:<packagename>...|:<classname>]
> disable assertions
> -esa | -enablesystemassertions
> enable system assertions
> -dsa | -disablesystemassertions
> disable system assertions
> -agentlib:<libname>[=<options>]
> load native agent library <libname>, e.g.
> -agentlib:hprof
> see also, -agentlib:jdwp=help and -agentlib:hprof=help
> -agentpath:<pathname>[=<options>]
> load native agent library by full pathname
> -javaagent:<jarpath>[=<options>]
> load Java programming language agent, see
> java.lang.instrument
> -splash:<imagepath>
> show splash screen with specified image
> and
Ed Merks
FUDForum. Page generated in 0.03944 seconds
