Home » Eclipse Projects » Remote Application Platform (RAP) » Problem with RAP+BIRT target platform(Build errors after adding BIRT to the target platform)
Problem with RAP+BIRT target platform [message #656171] Thu, 24 February 2011 12:41 Go to next message
Paul Ramsden is currently offline Paul RamsdenFriend
Member
I am trying to add BIRT to my RAP application but am getting build errors once I add BIRT to the target platform configuration.
I have a RAP application using the standard RAP 1.3 Target from the Eclispe+RAP download and this builds and runs fine.
I downloaded the RAP 1.3 und the BIRT 2.6 runtimes and saved them to D:\TARGETS
I created a new target definition and added D:\TARGETS\RAP13. The project build is ok.
I edited the target definition and added D:\TARGETS\BIRT26. The build has many errors.
What I see is that the target definition editor deselects duplicate bundles automatically leaving just one bundle of a pair selected. It seems that the errors are caused by excactly these bundles not being found. I tried selecting the just the other bundle in each pair but I have the impression that the selection is automatically reverted when the config is saved.
Am I doing something wrong here? What can I do to narrow down the problem?
thanks!
Re: Problem with RAP+BIRT target platform [message #656178 is a reply to message #656171] Thu, 24 February 2011 13:00 Go to previous messageGo to next message
Ivan Furnadjiev is currently offline Ivan FurnadjievFriend
are you aware of this wiki page
http://wiki.eclipse.org/RAP/BIRT_Integration ?
This is a quotation from the "Target" chapter:
"When merging the two runtimes together, we should be sure that *no
bundle* is available *twice* as this results in same strange errors
during runtime. So first step is to remove all the duplicate bundles."
HTH,
Ivan
> D:\TARGETS
> has many errors.
> problem?
> thanks!
Re: Problem with RAP+BIRT target platform [message #656189 is a reply to message #656178] Thu, 24 February 2011 13:41 Go to previous messageGo to next message
Member
Ivan,
yes, I was following that page.
As I mentioned in my question, the target editor seems to be deselecting the duplicates automatically so I don't think that I have any duplicates. However, the symptoms are that the duplicated bundles don't seem to be present *at all*.
Paul
Re: Problem with RAP+BIRT target platform [message #656193 is a reply to message #656189] Thu, 24 February 2011 14:05 Go to previous messageGo to next message
Hi Paul,
try to compose you target platform manually without a duplicates bundles.
Best,
Ivan
On 2/24/2011 3:41 PM, paulr wrote:
> Ivan,
> Paul
Re: Problem with RAP+BIRT target platform [message #657597 is a reply to message #656193] Thu, 03 March 2011 12:37 Go to previous message
Member
Hi Ivan
ok, copied the RAP & BIRT manually as you suggested and it works fine.
NOTE the birt.api bundle needs to be deselected as it was causing a problem with com.ibm.icu.text.
Paul
Previous Topic:[DateTime] Selection event lost
Next Topic:Runtime issue on rendering images in table?
Current Time: Tue Apr 16 15:09:56 GMT 2024
Powered by FUDForum. Page generated in 0.48367 seconds
