Home » Modeling » EMF » Altering XMLResource to create inter-EObject links bottom-up
Altering XMLResource to create inter-EObject links bottom-up [message #656003] Wed, 23 February 2011 17:25 Go to next message
Ben Tenne is currently offline Ben TenneFriend
Member
If I have a model where A contains B and B has a name, then I might end up with XML like this:
<A>
    <B>
        <name>Keith</name>
    </B>
</A>
Deserialization creates objects from this, as follows:
1. Create A
2. Create B
3. Assign B to A
4. Set B.name
Is there any easy way I could reverse the order of steps 3 and 4? i.e. Have all inter-EObject links deferred and created bottom-up once all objects have been created and had their attributes populated?
Why do I ask? When I assign one EObject to another (e.g. B to A), I want set-by-value semantics, so I've got custom code in my A.setB(...) method that copies B and assigns the copy instead. Of course, that means step 4, above, is then operating on an instance of B that is not the one that's been added to A.
Thanks for any suggestions.
Ben.
Re: Altering XMLResource to create inter-EObject links bottom-up [message #656010 is a reply to message #656003] Wed, 23 February 2011 17:55 Go to previous messageGo to next message
Ben,
Comments below.
Ben Tenne wrote:
> <A>
> <B>
> <name>Keith</name>
> </B>
> </A>
> 1. Create A
> 2. Create B
> 3. Assign B to A
> 4. Set B.name
No.
Sounds like bad news to me. The framework will not expect this
behavior. It's likely to make undo not work well in the editor, for example.
Another example where the framework will not work well.
Best not try to work against the grain but rather with it.
> Cheers,
> Ben.
Ed Merks
Re: Altering XMLResource to create inter-EObject links bottom-up [message #656109 is a reply to message #656010] Thu, 24 February 2011 09:30 Go to previous messageGo to next message
Member
Thanks for the advice, Ed.
I have a related question. We've also customized the setter behaviour for EAttributes backed by XMLGregorianCalendar. This is given that assignments to EAttributes are generally considered to be by-value, but XMLGregorianCalendar is the exception to the rule, in that it has mutators such as setYear(...). In such setters, I add code at the start, something like: newValue=(XMLGregorianCalendar)newValue.clone();
Would you imagine this causing any problems for the framework?
Re: Altering XMLResource to create inter-EObject links bottom-up [message #656127 is a reply to message #656010] Thu, 24 February 2011 10:07 Go to previous messageGo to next message
Member
Ben.
Re: Altering XMLResource to create inter-EObject links bottom-up [message #656231 is a reply to message #656127] Thu, 24 February 2011 16:09 Go to previous message
Ben,
No, that should be fine. As long as the value is .equals.
> Ben.
Ed Merks
Previous Topic:query2 problem
Next Topic:ClassCastException on.DynamicEObjectImpl
Current Time: Mon May 17 13:42:00 GMT 2021
Powered by FUDForum. Page generated in 0.01921 seconds
