Home » Archived » AM3 » Injection and EMF generated API
Injection and EMF generated API [message #655816] Tue, 22 February 2011 17:20 Go to next message
El Arbi Aboussoror is currently offline El Arbi AboussororFriend
Member
Hello
I'm facing a problem when I try to use a EMF resource after an injection.
I have writen an injector from XML to my metamodel. But when I try to access the resource the model objects are DynamicEObjectImpl even if the generated EMF code is available ! I get the following error:
!MESSAGE Unable to create view ID fr.irit.ifclipse.views.IFConfigurationView: org.eclipse.emf.ecore.impl.DynamicEObjectImpl cannot be cast to fr.irit.ifclipse.metamodel.IFConfig.IFConfig
I have posted in the EMF forum, but since I'm using the AM3 XMLInjector, may be you can help me.
my post on EMF forum: http://www.eclipse.org/forums/index.php?t=rview&goto=655 772#msg_655772
And this is the code of the injector:
package fr.irit.ifclipse.xml.injector;
import java.io.IOException;
import java.io.InputStream;
import java.io.PipedInputStream;
import java.io.PipedOutputStream;
import java.net.URL;
import java.util.Collections;
import java.util.HashMap;
import java.util.Map;
import org.eclipse.emf.common.util.URI;
import org.eclipse.emf.ecore.resource.Resource;
import org.eclipse.m2m.atl.core.ATLCoreException;
import org.eclipse.m2m.atl.core.emf.EMFExtractor;
import org.eclipse.m2m.atl.core.emf.EMFInjector;
import org.eclipse.m2m.atl.core.emf.EMFModel;
import org.eclipse.m2m.atl.core.emf.EMFModelFactory;
import org.eclipse.m2m.atl.core.emf.EMFReferenceModel;
import org.eclipse.m2m.atl.drivers.emf4atl.ASMEMFModel;
import org.eclipse.m2m.atl.drivers.emf4atl.AtlEMFModelHandler;
import org.eclipse.m2m.atl.engine.vm.AtlLauncher;
import org.eclipse.m2m.atl.engine.vm.AtlModelHandler;
import org.eclipse.m2m.atl.engine.vm.ModelLoader;
import org.eclipse.m2m.atl.projectors.xml.XMLInjector;
public class IFConfigurationXMLInjectorImpl implements
		IFConfigurationXMLInjector {
	private static final String IF_CONFIGURATION_ECORE_PATH = "fr.irit.ifclipse.metamodel/src/fr/irit/ifclipse/metamodel/metamodel/IFConfiguration.ecore";
	private static final String XML_ECORE_PATH = "org.eclipse.m2m.atl.projectors.xml/src/org/eclipse/m2m/atl/projectors/xml/resources/XML.ecore";
	private AtlEMFModelHandler modelHandler;
	private ModelLoader modelLoader;
	private ASMEMFModel XMLMetamodel;
	private ASMEMFModel IFConfigurationMetamodel;
	private URI XML_ecoreURI;
	private URI IFConfiguration_ecoreURI;
	private URL XML2IFConfiguration_PATH;
	 * inject an XML inputstream into an IFConfiguration resource
	public Resource inject(InputStream sourceXML) {
		// load the MetaM and M
		createResources();
		Resource result = null;
		EMFInjector emfInjector = new EMFInjector();
		try {
			// create an EMFModel instance of XML
			EMFReferenceModel XMLReferenceModel = (EMFReferenceModel) (new EMFModelFactory())
					.newReferenceModel();
			emfInjector.inject(XMLReferenceModel, XML_ecoreURI.toString());
			EMFModel sourceXMLEMFModel = (EMFModel) (new EMFModelFactory())
					.newModel(XMLReferenceModel);
			// inject the inputstream in the XML EMFModel
			XMLInjector xmlInjector = new XMLInjector();
			xmlInjector.inject(sourceXMLEMFModel, sourceXML, null);
			// transform the XML EMFModel to IFConfig EMFModel using
			// XML2IFConfig.asm
			result = xml2ifConfigTrafo(sourceXMLEMFModel);
		} catch (ATLCoreException e) {
			e.printStackTrace();
		return result;
	private void createResources() {
		modelHandler = (AtlEMFModelHandler) AtlModelHandler
				.getDefault(AtlModelHandler.AMH_EMF);
		modelLoader = modelHandler.createModelLoader();
		XML_ecoreURI = URI.createPlatformPluginURI(XML_ECORE_PATH, true);
		IFConfiguration_ecoreURI = URI.createPlatformPluginURI(
				IF_CONFIGURATION_ECORE_PATH, true);
		XML2IFConfiguration_PATH = IFConfigurationXMLInjectorImpl.class
				.getResource("resources/XML2IFConfig.asm");
	private Resource xml2ifConfigTrafo(final EMFModel sourceXMLEMFModel) {
		Map<String, Object> models = new HashMap<String, Object>();
		initMetamodels(models);
		// get/create models
		try {
			// TODO: transform the 2 EMFModels into ASMEMFModels
			final PipedOutputStream outputStream = new PipedOutputStream();
			PipedInputStream inputStream = new PipedInputStream(outputStream);
			new Thread(new Runnable() {
				public void run() {
					try {
						(new EMFExtractor()).extract(sourceXMLEMFModel,
								outputStream, null);
					try {
						outputStream.close();
					} catch (IOException e) {
			}).start();
			ASMEMFModel XMLInputModel = (ASMEMFModel) modelLoader.loadModel(
					"IN", XMLMetamodel, inputStream);
			inputStream.close();
			URI saveURI = URI
					.createFileURI("d:/workspaces/wp_irit_ifgui/fr.irit.ifclipse/src/fr/irit/ifclipse/xml/savedXML.xml.xmi");
			Resource XMLExtent = XMLInputModel.getExtent();
			XMLExtent.setURI(saveURI);
			XMLExtent.save(Collections.EMPTY_MAP);
			ASMEMFModel IFConfigOutputModel = (ASMEMFModel) modelLoader
					.newModel("OUT", "", IFConfigurationMetamodel);
			// load models
			models.put("IN", XMLInputModel);
			models.put("OUT", IFConfigOutputModel);
			// launch
			AtlLauncher.getDefault().launch(this.XML2IFConfiguration_PATH,
					Collections.EMPTY_MAP, models, Collections.EMPTY_MAP,
					Collections.EMPTY_LIST, Collections.EMPTY_MAP);
			result = IFConfigOutputModel.getExtent();
			URI saveURI_IF = URI
					.createFileURI("d:/workspaces/wp_irit_ifgui/fr.irit.ifclipse/src/fr/irit/ifclipse/xml/savedIFConfig.ifconfig.xmi");
			result.setURI(saveURI_IF);
			result.save(Collections.EMPTY_MAP);
		return result;
	// loads the metamodels in a Map<String, Object>
	private void initMetamodels(Map<String, Object> models) {
		try {
			XMLMetamodel = (ASMEMFModel) modelLoader.loadModel("XML",
					modelLoader.getMOF(), XML_ecoreURI.toString());
			IFConfigurationMetamodel = (ASMEMFModel) modelLoader.loadModel(
					"IFConfiguration", modelLoader.getMOF(),
					IFConfiguration_ecoreURI.toString());
			models.put("XML", XMLMetamodel);
			models.put("IFConfiguration", IFConfigurationMetamodel);
	public Resource inject(Resource IFConfigResource, InputStream sourceXML,
			Map<String, Object> options) {
		return null;
Re: Injection and EMF generated API [message #655898 is a reply to message #655816] Wed, 23 February 2011 09:00 Go to previous messageGo to next message
Vincent MAHE is currently offline Vincent MAHEFriend
Le 22/02/2011 18:20, ElArbi a écrit :
> Hello
> " fr.irit.ifclipse.metamodel/src/fr/irit/ifclipse/metamodel/me tamodel/IFConfiguration.ecore ";
> " org.eclipse.m2m.atl.projectors.xml/src/org/eclipse/m2m/atl/p rojectors/xml/resources/XML.ecore ";
> @Override
> createResources();
> try {
> EMFModelFactory())
You must use the same EMF factory for all (meta)models implied in your
injection/transformation
> // XML2IFConfig.asm
> return result;
> try {
> public void run() {
> try {
> try {
> }).start();
> URI saveURI = URI
> .createFileURI(" d:/workspaces/wp_irit_ifgui/fr.irit.ifclipse/src/fr/irit/ifc lipse/xml/savedXML.xml.xmi ");
> // load models
> // launch
> AtlLauncher.getDefault().launch(this.XML2IFConfiguration_PAT H,
> .createFileURI(" d:/workspaces/wp_irit_ifgui/fr.irit.ifclipse/src/fr/irit/ifc lipse/xml/savedIFConfig.ifconfig.xmi ");
> return result;
> try {
> @Override
> return null;
Cordialement
Vincent MAHÉ
Ingénieur Expert - Projet IDM++ - Équipe AtlanMod
École des Mines de Nantes
La Chantrerie - 4, rue Alfred Kastler
B.P. 20722 - F-44307 NANTES Cedex 3
Tel: (33)2 51 85 81 00
Re: Injection and EMF generated API [message #655905 is a reply to message #655816] Wed, 23 February 2011 09:20 Go to previous messageGo to next message
Hugo Bruneliere is currently offline Hugo BruneliereFriend
Hi El Arbi,
Are you using the latest version of the XML injector available from the AM3 folder of the MoDisco project's SVN https://dev.eclipse.org/svnroot/modeling/org.eclipse.mdt.mod isco/incubation/trunk/am3/plugins/trunk/org.eclipse.m2m.atl. projectors.xml/ ?
Hugo
Hugo Bruneliere, PhD
NaoMod team (IMT Atlantique & LS2N-CNRS)
Nantes - France
Re: Injection and EMF generated API [message #655923 is a reply to message #655905] Wed, 23 February 2011 10:33 Go to previous messageGo to next message
Member
Hugo Bruneliere wrote on Wed, 23 February 2011 04:20
Hi El Arbi,
Hugo
Yes, the only modificaiton in trunk is that the XML.ecore and KM3 had moved from org.eclipse.m2m.atl.projectors.xml.resources to model package. Should I update ?
Re: Injection and EMF generated API [message #655925 is a reply to message #655898] Wed, 23 February 2011 10:35 Go to previous messageGo to next message
Member
I have done it but still have the same error Sad
Re: Injection and EMF generated API [message #656236 is a reply to message #655925] Thu, 24 February 2011 16:21 Go to previous message
Member
I finally found the problem (and a solution):
I was loading the package from it's serialized form => it's factory will instantiate the dynamic EObject implementation.
So using my package namespace URI instead solved the problem. I replaced the following code:
URI IFConfiguration_ecoreURI = URI.createPlatformPluginURI(IF_CONFIGURATION_ECORE_PATH, true);
with this one
URI IFConfiguration_NS_URI = URI.createURI("uri:http://irit.fr/ifconfiguration");
					IFConfiguration_NS_URI.toString());
And it works !
Thanks.
Previous Topic:ATL metamodel validated
Next Topic:Can't launch UML2OWL on ATL 3.1
Current Time: Sun Sep 19 09:23:37 GMT 2021
Powered by FUDForum. Page generated in 0.02487 seconds
