Home » Archived » AM3 » Injection and EMF generated API
Injection and EMF generated API [message #655816] |
Tue, 22 February 2011 17:20 |
El Arbi Aboussoror Messages: 90 Registered: June 2010 |
Member |
Hello
I'm facing a problem when I try to use a EMF resource after an injection.
I have writen an injector from XML to my metamodel. But when I try to access the resource the model objects are DynamicEObjectImpl even if the generated EMF code is available ! I get the following error:
!MESSAGE Unable to create view ID fr.irit.ifclipse.views.IFConfigurationView: org.eclipse.emf.ecore.impl.DynamicEObjectImpl cannot be cast to fr.irit.ifclipse.metamodel.IFConfig.IFConfig
I have posted in the EMF forum, but since I'm using the AM3 XMLInjector, may be you can help me.
my post on EMF forum: http://www.eclipse.org/forums/index.php?t=rview&goto=655 772#msg_655772
And this is the code of the injector:
package fr.irit.ifclipse.xml.injector;
import java.io.IOException;
import java.io.InputStream;
import java.io.PipedInputStream;
import java.io.PipedOutputStream;
import java.net.URL;
import java.util.Collections;
import java.util.HashMap;
import java.util.Map;
import org.eclipse.emf.common.util.URI;
import org.eclipse.emf.ecore.resource.Resource;
import org.eclipse.m2m.atl.core.ATLCoreException;
import org.eclipse.m2m.atl.core.emf.EMFExtractor;
import org.eclipse.m2m.atl.core.emf.EMFInjector;
import org.eclipse.m2m.atl.core.emf.EMFModel;
import org.eclipse.m2m.atl.core.emf.EMFModelFactory;
import org.eclipse.m2m.atl.core.emf.EMFReferenceModel;
import org.eclipse.m2m.atl.drivers.emf4atl.ASMEMFModel;
import org.eclipse.m2m.atl.drivers.emf4atl.AtlEMFModelHandler;
import org.eclipse.m2m.atl.engine.vm.AtlLauncher;
import org.eclipse.m2m.atl.engine.vm.AtlModelHandler;
import org.eclipse.m2m.atl.engine.vm.ModelLoader;
import org.eclipse.m2m.atl.projectors.xml.XMLInjector;
public class IFConfigurationXMLInjectorImpl implements
IFConfigurationXMLInjector {
private static final String IF_CONFIGURATION_ECORE_PATH = "fr.irit.ifclipse.metamodel/src/fr/irit/ifclipse/metamodel/metamodel/IFConfiguration.ecore";
private static final String XML_ECORE_PATH = "org.eclipse.m2m.atl.projectors.xml/src/org/eclipse/m2m/atl/projectors/xml/resources/XML.ecore";
private AtlEMFModelHandler modelHandler;
private ModelLoader modelLoader;
private ASMEMFModel XMLMetamodel;
private ASMEMFModel IFConfigurationMetamodel;
private URI XML_ecoreURI;
private URI IFConfiguration_ecoreURI;
private URL XML2IFConfiguration_PATH;
* inject an XML inputstream into an IFConfiguration resource
public Resource inject(InputStream sourceXML) {
// load the MetaM and M
createResources();
Resource result = null;
EMFInjector emfInjector = new EMFInjector();
try {
// create an EMFModel instance of XML
EMFReferenceModel XMLReferenceModel = (EMFReferenceModel) (new EMFModelFactory())
.newReferenceModel();
emfInjector.inject(XMLReferenceModel, XML_ecoreURI.toString());
EMFModel sourceXMLEMFModel = (EMFModel) (new EMFModelFactory())
.newModel(XMLReferenceModel);
// inject the inputstream in the XML EMFModel
XMLInjector xmlInjector = new XMLInjector();
xmlInjector.inject(sourceXMLEMFModel, sourceXML, null);
// transform the XML EMFModel to IFConfig EMFModel using
// XML2IFConfig.asm
result = xml2ifConfigTrafo(sourceXMLEMFModel);
} catch (ATLCoreException e) {
e.printStackTrace();
return result;
private void createResources() {
modelHandler = (AtlEMFModelHandler) AtlModelHandler
.getDefault(AtlModelHandler.AMH_EMF);
modelLoader = modelHandler.createModelLoader();
XML_ecoreURI = URI.createPlatformPluginURI(XML_ECORE_PATH, true);
IFConfiguration_ecoreURI = URI.createPlatformPluginURI(
IF_CONFIGURATION_ECORE_PATH, true);
XML2IFConfiguration_PATH = IFConfigurationXMLInjectorImpl.class
.getResource("resources/XML2IFConfig.asm");
private Resource xml2ifConfigTrafo(final EMFModel sourceXMLEMFModel) {
Map<String, Object> models = new HashMap<String, Object>();
initMetamodels(models);
// get/create models
try {
// TODO: transform the 2 EMFModels into ASMEMFModels
final PipedOutputStream outputStream = new PipedOutputStream();
PipedInputStream inputStream = new PipedInputStream(outputStream);
new Thread(new Runnable() {
public void run() {
try {
(new EMFExtractor()).extract(sourceXMLEMFModel,
outputStream, null);
try {
outputStream.close();
} catch (IOException e) {
}).start();
ASMEMFModel XMLInputModel = (ASMEMFModel) modelLoader.loadModel(
"IN", XMLMetamodel, inputStream);
inputStream.close();
URI saveURI = URI
.createFileURI("d:/workspaces/wp_irit_ifgui/fr.irit.ifclipse/src/fr/irit/ifclipse/xml/savedXML.xml.xmi");
Resource XMLExtent = XMLInputModel.getExtent();
XMLExtent.setURI(saveURI);
XMLExtent.save(Collections.EMPTY_MAP);
ASMEMFModel IFConfigOutputModel = (ASMEMFModel) modelLoader
.newModel("OUT", "", IFConfigurationMetamodel);
// load models
models.put("IN", XMLInputModel);
models.put("OUT", IFConfigOutputModel);
// launch
AtlLauncher.getDefault().launch(this.XML2IFConfiguration_PATH,
Collections.EMPTY_MAP, models, Collections.EMPTY_MAP,
Collections.EMPTY_LIST, Collections.EMPTY_MAP);
result = IFConfigOutputModel.getExtent();
URI saveURI_IF = URI
.createFileURI("d:/workspaces/wp_irit_ifgui/fr.irit.ifclipse/src/fr/irit/ifclipse/xml/savedIFConfig.ifconfig.xmi");
result.setURI(saveURI_IF);
result.save(Collections.EMPTY_MAP);
return result;
// loads the metamodels in a Map<String, Object>
private void initMetamodels(Map<String, Object> models) {
try {
XMLMetamodel = (ASMEMFModel) modelLoader.loadModel("XML",
modelLoader.getMOF(), XML_ecoreURI.toString());
IFConfigurationMetamodel = (ASMEMFModel) modelLoader.loadModel(
"IFConfiguration", modelLoader.getMOF(),
IFConfiguration_ecoreURI.toString());
models.put("XML", XMLMetamodel);
models.put("IFConfiguration", IFConfigurationMetamodel);
public Resource inject(Resource IFConfigResource, InputStream sourceXML,
Map<String, Object> options) {
return null;
Re: Injection and EMF generated API [message #655898 is a reply to message #655816] |
Wed, 23 February 2011 09:00 |
Vincent MAHE Messages: 129 Registered: July 2009 |
Le 22/02/2011 18:20, ElArbi a écrit :
> Hello
> " fr.irit.ifclipse.metamodel/src/fr/irit/ifclipse/metamodel/me tamodel/IFConfiguration.ecore ";
> " org.eclipse.m2m.atl.projectors.xml/src/org/eclipse/m2m/atl/p rojectors/xml/resources/XML.ecore ";
> @Override
> createResources();
> try {
> EMFModelFactory())
You must use the same EMF factory for all (meta)models implied in your
injection/transformation
> // XML2IFConfig.asm
> return result;
> try {
> public void run() {
> try {
> try {
> }).start();
> URI saveURI = URI
> .createFileURI(" d:/workspaces/wp_irit_ifgui/fr.irit.ifclipse/src/fr/irit/ifc lipse/xml/savedXML.xml.xmi ");
> // load models
> // launch
> AtlLauncher.getDefault().launch(this.XML2IFConfiguration_PAT H,
> .createFileURI(" d:/workspaces/wp_irit_ifgui/fr.irit.ifclipse/src/fr/irit/ifc lipse/xml/savedIFConfig.ifconfig.xmi ");
> return result;
> try {
> @Override
> return null;
Cordialement
Vincent MAHÉ
Ingénieur Expert - Projet IDM++ - Équipe AtlanMod
École des Mines de Nantes
La Chantrerie - 4, rue Alfred Kastler
B.P. 20722 - F-44307 NANTES Cedex 3
Tel: (33)2 51 85 81 00
Current Time: Thu Apr 25 14:35:25 GMT 2024
Powered by FUDForum. Page generated in 0.03353 seconds
