ClassCastException on.DynamicEObjectImpl [message #655572] |
Mon, 21 February 2011 19:24  |
El Arbi Aboussoror Messages: 90 Registered: June 2010 |
Member |
I have the follwing error when trying to cast an EObject to one of my generated EMF model element. This is the complete error trace:
Quote: |
!SESSION 2011-02-21 20:14:21.108 -----------------------------------------------
eclipse.buildId=M20100909-0800
java.version=1.6.0_23
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=fr_FR
Framework arguments: -product org.eclipse.platform.ide
Command-line arguments: -product org.eclipse.platform.ide -data D:\workspaces\wp_irit_ifgui/../runtime-EclipseApplication -dev file:D:/workspaces/wp_irit_ifgui/.metadata/.plugins/org.ecli pse.pde.core/Eclipse Application/dev.properties -os win32 -ws win32 -arch x86_64 -consoleLog
!ENTRY org.eclipse.emf.ecore 2 0 2011-02-21 20:14:26.753
!MESSAGE Both 'org.eclipse.gmf.bridge.trace' and 'org.eclipse.xpand.incremental' register an extension parser for 'trace'
sEltVar: IN!var
instance_var: IN!server_var
!ENTRY org.eclipse.ui.workbench 4 0 2011-02-21 20:14:27.445
!MESSAGE Unable to create view ID fr.irit.ifclipse.views.IFConfigurationView: org.eclipse.emf.ecore.impl.DynamicEObjectImpl cannot be cast to fr.irit.ifclipse.metamodel.IFConfig.IFConfig
!STACK 0
java.lang.ClassCastException: org.eclipse.emf.ecore.impl.DynamicEObjectImpl cannot be cast to fr.irit.ifclipse.metamodel.IFConfig.IFConfig
at fr.irit.ifclipse.views.IFConfigurationView$ViewContentProvid er.initialize(IFConfigurationView.java:233)
at fr.irit.ifclipse.views.IFConfigurationView$ViewContentProvid er.getElements(IFConfigurationView.java:158)
at org.eclipse.jface.viewers.StructuredViewer.getRawChildren(St ructuredViewer.java:989)
at org.eclipse.jface.viewers.ColumnViewer.getRawChildren(Column Viewer.java:703)
at org.eclipse.jface.viewers.AbstractTreeViewer.getRawChildren( AbstractTreeViewer.java:1332)
at org.eclipse.jface.viewers.TreeViewer.getRawChildren(TreeView er.java:391)
at org.eclipse.jface.viewers.StructuredViewer.getFilteredChildr en(StructuredViewer.java:896)
at org.eclipse.jface.viewers.AbstractTreeViewer.getSortedChildr en(AbstractTreeViewer.java:601)
at org.eclipse.jface.viewers.AbstractTreeViewer$1.run(AbstractT reeViewer.java:801)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:70)
at org.eclipse.jface.viewers.AbstractTreeViewer.createChildren( AbstractTreeViewer.java:778)
at org.eclipse.jface.viewers.TreeViewer.createChildren(TreeView er.java:644)
at org.eclipse.jface.viewers.AbstractTreeViewer.createChildren( AbstractTreeViewer.java:749)
at org.eclipse.jface.viewers.AbstractTreeViewer.internalInitial izeTree(AbstractTreeViewer.java:1492)
at org.eclipse.jface.viewers.TreeViewer.internalInitializeTree( TreeViewer.java:833)
at org.eclipse.jface.viewers.AbstractTreeViewer$5.run(AbstractT reeViewer.java:1476)
at org.eclipse.jface.viewers.StructuredViewer.preservingSelecti on(StructuredViewer.java:1422)
at org.eclipse.jface.viewers.TreeViewer.preservingSelection(Tre eViewer.java:403)
at org.eclipse.jface.viewers.StructuredViewer.preservingSelecti on(StructuredViewer.java:1383)
at org.eclipse.jface.viewers.AbstractTreeViewer.inputChanged(Ab stractTreeViewer.java:1469)
at org.eclipse.jface.viewers.ContentViewer.setInput(ContentView er.java:274)
at org.eclipse.jface.viewers.StructuredViewer.setInput(Structur edViewer.java:1664)
at fr.irit.ifclipse.views.IFConfigurationView.createPartControl (IFConfigurationView.java:303)
at org.eclipse.ui.internal.ViewReference.createPartHelper(ViewR eference.java:375)
at org.eclipse.ui.internal.ViewReference.createPart(ViewReferen ce.java:229)
at org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:595)
at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:31 3)
at org.eclipse.ui.internal.ViewPane.setVisible(ViewPane.java:52 9)
at org.eclipse.ui.internal.presentations.PresentablePart.setVis ible(PresentablePart.java:180)
at org.eclipse.ui.internal.presentations.util.PresentablePartFo lder.select(PresentablePartFolder.java:270)
at org.eclipse.ui.internal.presentations.util.LeftToRightTabOrd er.select(LeftToRightTabOrder.java:65)
at org.eclipse.ui.internal.presentations.util.TabbedStackPresen tation.selectPart(TabbedStackPresentation.java:473)
at org.eclipse.ui.internal.PartStack.refreshPresentationSelecti on(PartStack.java:1254)
at org.eclipse.ui.internal.PartStack.createControl(PartStack.ja va:666)
at org.eclipse.ui.internal.PartStack.createControl(PartStack.ja va:574)
at org.eclipse.ui.internal.PartSashContainer.createControl(Part SashContainer.java:568)
at org.eclipse.ui.internal.PerspectiveHelper.activate(Perspecti veHelper.java:272)
at org.eclipse.ui.internal.Perspective.onActivate(Perspective.j ava:981)
at org.eclipse.ui.internal.WorkbenchPage.onActivate(WorkbenchPa ge.java:2632)
at org.eclipse.ui.internal.WorkbenchWindow$27.run(WorkbenchWind ow.java:2986)
at org.eclipse.ui.internal.WorkbenchWindow.setActivePage(Workbe nchWindow.java:2967)
at org.eclipse.ui.internal.WorkbenchWindow$21.runWithException( WorkbenchWindow.java:2284)
at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run (StartupThreading.java:31)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:134)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:4041)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3660)
at org.eclipse.ui.application.WorkbenchAdvisor.openWindows(Work benchAdvisor.java:803)
at org.eclipse.ui.internal.Workbench$31.runWithException(Workbe nch.java:1567)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2548)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:24 38)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:671)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:664)
at org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:115)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:196)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:369)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 619)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
at org.eclipse.equinox.launcher.Main.main(Main.java:1383)
And this is the code (the problem is in the 'initialize' method when I try to cast the eObject "IFConfig config = (IFConfig) eObject;"):
class ViewContentProvider implements IStructuredContentProvider,
ITreeContentProvider {
private TreeParent invisibleRoot;
private IFConfigurationXMLInjectorImpl ifConfigXMLInjector;
public void inputChanged(Viewer v, Object oldInput, Object newInput) {
public void dispose() {
public Object[] getElements(Object parent) {
if (parent.equals(getViewSite())) {
if (invisibleRoot == null)
initialize();
return getChildren(invisibleRoot);
return getChildren(parent);
public Object getParent(Object child) {
if (child instanceof TreeObject) {
return ((TreeObject) child).getParent();
return null;
public Object[] getChildren(Object parent) {
if (parent instanceof TreeParent) {
return ((TreeParent) parent).getChildren();
return new Object[0];
public boolean hasChildren(Object parent) {
return ((TreeParent) parent).hasChildren();
return false;
private void initialize() {
// TODO: get the tree parent from emf model element of type
// IFInstance
ResourceSet resourceSet = new ResourceSetImpl();
// Register the appropriate resource factory to handle all file
// extensions.
resourceSet
.getResourceFactoryRegistry()
.getExtensionToFactoryMap()
.put(Resource.Factory.Registry.DEFAULT_EXTENSION,
new XMIResourceFactoryImpl());
// Register the package to ensure it is available during loading.
Registry packageRegistry = resourceSet.getPackageRegistry();
packageRegistry.put(IFConfigPackage.eNS_URI,
IFConfigPackage.eINSTANCE);
URI uri = URI
.createFileURI("d:/workspaces/wp_irit_ifgui/fr.irit.ifclipse/src/fr/irit/ifclipse/xml/savedIFConfig2.ifconfig.xmi");
Resource resource = resourceSet.createResource(uri);
if (resource != null) {
URI sourceXML = URI
.createFileURI("d:/workspaces/wp_irit_ifgui/fr.irit.ifclipse/src/fr/irit/ifclipse/xml/step_1.xml");
try {
InputStream inputStrSourceXML = (new ExtensibleURIConverterImpl())
.createInputStream(sourceXML);
ifConfigXMLInjector = new IFConfigurationXMLInjectorImpl();
resource = ifConfigXMLInjector.inject(inputStrSourceXML);
resource.setURI(uri);
resource.save(Collections.EMPTY_MAP);
} catch (IOException e) {
System.out.println("injection problem !");
e.printStackTrace();
EList<EObject> contents = resource.getContents();
EObject eObject = contents.get(0);
if (eObject instanceof IFConfig)
System.out.println("it's an IFConfig");
TreeParent root = new TreeParent("Configuration: "
+ config.getName());
TreeParent p1 = new TreeParent("instances");
root.addChild(p1);
for (Instance instance : config.getInstances()) {
p1.addChild(new TreeObject(instance.getPid().getName()));
invisibleRoot = new TreeParent("");
invisibleRoot.addChild(root);
I think that the pacckage is not registred, but when I look to my metamodel plugin, the plugin.xml is the following:
<plugin>
<extension point="org.eclipse.emf.ecore.generated_package">
<package
uri="http://irit.fr/ifconfiguration"
class="fr.irit.ifclipse.metamodel.IFConfig.IFConfigPackage"
genModel="src/fr/irit/ifclipse/metamodel/metamodel/IFConfiguration.genmodel"/>
</extension>
</plugin>
And my view plugin has a dependency on this metamodel plugin, so I don't see the problem.
Any clue ?
Re: ClassCastException on.DynamicEObjectImpl [message #655588 is a reply to message #655572] |
Mon, 21 February 2011 20:00   |
Am 21.02.2011 20:24, schrieb ElArbi:
> Hello,
The model used is definitely not a generated model. Please check that your model plugins are properly deployed. Also check that the nsURIs in the plugin.xml files are complete and match the eNS_URI constants in the correcponding generated package interfaces (EMF does not regenerate/merge the plugin.xml after model changes).
Cheers
/Eike
http://www.esc-net.de
> Quote:
>> sEltVar: IN!var
>> !STACK 0
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at java.lang.reflect.Method.invoke(Method.java:597)
> initialize();
> return null;
> return false;
> // IFInstance
> // extensions.
> resourceSet
> URI uri = URI
> .createFileURI(" d:/workspaces/wp_irit_ifgui/fr.irit.ifclipse/src/fr/irit/ifc lipse/xml/savedIFConfig2.ifconfig.xmi ");
> URI sourceXML = URI
> .createFileURI(" d:/workspaces/wp_irit_ifgui/fr.irit.ifclipse/src/fr/irit/ifc lipse/xml/step_1.xml ");
> try {
> // EList<EObject> contents = resource.getContents();
> root.addChild(p1);
> <plugin>
> <package
> genModel=" src/fr/irit/ifclipse/metamodel/metamodel/IFConfiguration.gen model "/>
> </extension>
> </plugin>
> Any clue ?
Cheers
/Eike
FUDForum. Page generated in 0.02206 seconds
