Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Getting the active cell of a table
Getting the active cell of a table [message #655521] Mon, 21 February 2011 14:45 Go to next message
David  Pérez is currently offline David PérezFriend
I wonder how to get the active cell of a Table.
It's easy to get the active row, but not the active column. Embarrassed
I'm not talking about the current cell editor, I'm interested about the current column, even if I'm not editing a cell.
Thanks in advance for any help.
David
Re: Getting the active cell of a table [message #656253 is a reply to message #655521] Thu, 24 February 2011 17:26 Go to previous messageGo to next message
I think there is no API for this, and have to write low level code specific to the platform. Confused
It would be good to add this API to the next SWT release.
What do you think?
Should I open a new issue in BugZilla?
David
Re: Getting the active cell of a table [message #656354 is a reply to message #656253] Fri, 25 February 2011 09:30 Go to previous messageGo to next message
Lakshmi ShanmugamFriend
Could you describe what API you are looking for?
Using a point within the Table, we can find the TableItem and column index using the existing APIs.
For example:---
TableItem item = table.getItem (point);
for (int i=0; i<table.getColumnCount (); i++) {
Rectangle rect = item.getBounds (i);
if (rect.contains (point)) {
columnIndex = i;
Does this work for your case?
Lakshmi P Shanmugam
Re: Getting the active cell of a table [message #656366 is a reply to message #656354] Fri, 25 February 2011 09:54 Go to previous messageGo to next message
Thomas Schindl is currently offline Thomas SchindlFriend
JFace has introduced the concept of ViewerCell in 3.3 which uses exactly
this API.
Tom
Am 25.02.11 10:30, schrieb Lakshmi Shanmugam:
> For example:---
> columnIndex = i;
> } Does this work for your case?
Re: Getting the active cell of a table [message #656386 is a reply to message #656366] Fri, 25 February 2011 11:54 Go to previous messageGo to next message
Hi Lakshmi,
I already know that API.
What I need is knowing the highlighted cell, the one where the cursor is, not the cell that lies under a given Point.
I think there is currently no way of knowing it.
Re: Getting the active cell of a table [message #656390 is a reply to message #656386] Fri, 25 February 2011 12:07 Go to previous message
SWT-Table has no concept of Cells because the underlying native control
doesn't have one.
If you need a grid like control to I'd suggest to use Nebula-Grid.
Tom
Am 25.02.11 12:54, schrieb David Pérez:
> Hi Lakshmi,
> Quote:
Previous Topic:Running a SWT app in a different OS
Next Topic:Text widget with CTRL+F search functionality
Current Time: Thu Jun 04 09:32:02 GMT 2020
Powered by FUDForum. Page generated in 0.01799 seconds
