problem accessing CVS repository on solaris 10 from eclipse client [message #655463] |
Mon, 21 February 2011 09:48 |
Paul Hanrahan Messages: 2 Registered: February 2011 |
just a further update
It seems on solaris 10, the SSH inplementation is Sun_SSH_1.1.3 whereas the old version was openssh based.
So does anybode know if it is possible to connect to a Sun SSH cvs repository from an eclipse client
Paul
hope someone can help, we have several eclipse java developers accessing a CVS repository on solaris. The connection is using ssh and all was working fine until solaris was upgraded to solaris 10. Since the upgrade, we cannot get eclipse to work with solaris. The solaris admin says the connections areaccepted, but we get an unknown response received from the server in eclipse. I have tried downloading the latest (eclipse helios 3.6.1)
We have tried to setup non-password based authentication (using just keys) and still no luck. Its definitely the SSH version on solaris because the solaris admin temporarly restored the old ssh version, eclipse worked again.
anybody else seen this problem
thanks
Paul
[Updated on: Mon, 21 February 2011 14:08] Report message to a moderator
FUDForum. Page generated in 0.03616 seconds
