Auto Completion Classes for XSD [message #655371] |
Sun, 20 February 2011 03:48 |
zifiribir Messages: 1 Registered: February 2011 |
I want to create an xml editor that has xml schema code completion property. However, it will be independent from Eclipse. How can I detach the classes for code completion? Or are there any external classes for this?
Can you help me?
I found this packages/classes:
org.eclipse.wst.xml.core.internal.contentmodel.modelqueryimp l(ModelQueryExtensionManager)
org.eclipse.wst.xsd.ui.internal.text (XSDModelQueryExtension)
org.eclipse.wst.xsd.ui.internal.util.(TypesHelper)
[Updated on: Sun, 20 February 2011 03:52] Report message to a moderator
Re: Auto Completion Classes for XSD [message #655631 is a reply to message #655371] |
Tue, 22 February 2011 03:21 |
Ed Merks Messages: 33140 Registered: July 2009 |
Please ask about wst on the WTP newsgroup/forum.
zifiribir@gmail.com wrote:
> Hello,
> I want to create an xml editor that have xml schema code completion
> dispatch the classes for code completion? Or are there any external
> classes for this?
> Can you help me?
Ed Merks
FUDForum. Page generated in 0.02567 seconds
