Home » Eclipse Projects » EGit / JGit » Howto commit the deletion of a project
Howto commit the deletion of a project [message #655162] Fri, 18 February 2011 14:20 Go to next message
Kay Huber is currently offline Kay HuberFriend
Member
This question is actually split into two parts: A silly and not quite as silly one:
* Silly silly: If I create a few projects, share (and commit) them in git and then delete them all, how can I commit the "empty" workspace afterwards in egit?
* "just" silly: Same question as above but for one project only: How can I commit the deletion of a project (assuming that the project is the highest instance I can "see" in eclipse' workspace)
Kay
Re: Howto commit the deletion of a project [message #655382 is a reply to message #655162] Sun, 20 February 2011 09:36 Go to previous messageGo to next message
Robin Rosenberg is currently offline Robin RosenbergFriend
> silly one:
> afterwards in egit?
> Regards
> Kay
Same answer for both. There is a bug report for that at
https://bugs.eclipse.org/bugs/show_bug.cgi?id=337577
-- robin
Re: Howto commit the deletion of a project [message #655386 is a reply to message #655382] Sun, 20 February 2011 10:15 Go to previous messageGo to next message
Member
Yes, after asking the question here, I tried around a little more in eclipse but did not find a solution. Thus, I created the bug but didn't mention it here, sorry.
Btw: As a workaround I commit with command line git for now, which of course works fine.
Kay
Re: Howto commit the deletion of a project [message #656129 is a reply to message #655386] Thu, 24 February 2011 10:08 Go to previous message
Matthias Sohn is currently offline Matthias SohnFriend
Currently the only way is to import the root of the repository as a "General Project" - but that's probably not what you want Sad
Previous Topic: team->share project->git NoWorkTreeException
Next Topic:Confused about Team Share with no former git repo
Current Time: Mon Jun 01 20:44:07 GMT 2020
Powered by FUDForum. Page generated in 0.02150 seconds
