Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » EEF liveEditingDomain issue
EEF liveEditingDomain issue [message #654978] Thu, 17 February 2011 20:52 Go to next message
Miles Parker is currently offline Miles ParkerFriend
When I edit from within a custom EMF Editor page my generated EEF works fine. But when I try to edit from a properties view, I get the error below because liveEditingDomain is null. Am I perhaps doing something wrong in the setup or configuration?
at org.eclipse.emf.eef.runtime.impl.components.StandardProperti esEditionComponent.firePropertiesChanged(StandardPropertiesE ditionComponent.java:184)
at com.butterflyzer.parts.forms.LeafTermPropertiesEditionPartFo rm$2.focusLost(LeafTermPropertiesEditionPartForm.java:137)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:143)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4054)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1435)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1458)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1439)
at org.eclipse.swt.widgets.Control.sendFocusEvent(Control.java: 3244)
at org.eclipse.swt.widgets.Display.checkFocus(Display.java:645)
at org.eclipse.swt.widgets.Shell.makeFirstResponder(Shell.java: 1217)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:5500 )
Re: EEF liveEditingDomain issue [message #654979 is a reply to message #654978] Thu, 17 February 2011 20:55 Go to previous messageGo to next message
Also, is there any way to not use the tabbed property sheet or at least hide the tabs? I'm trying to gain back valuable screen real estate. Smile
Miles Parker wrote on Thu, 17 February 2011 15:52
Re: EEF liveEditingDomain issue [message #655069 is a reply to message #654978] Fri, 18 February 2011 08:59 Go to previous messageGo to next message
Goulwen Le Fur is currently offline Goulwen Le FurFriend
Hi Miles,
It means that the EditingDomain you're using is null. The method to find
the EditingDomain is :
org.eclipse.emf.eef.runtime.ui.utils.EditingUtils.getResourc eSetFromEditor(IWorkbenchPart)
Can you check the behaviour of this method in your case ?
Goulwen
Le 17/02/2011 21:52, Miles Parker a écrit :
> ner.java:143)
Re: EEF liveEditingDomain issue [message #655070 is a reply to message #654979] Fri, 18 February 2011 09:01 Go to previous message
Not sure to understand Miles but you can set an PropertiesEditingViewer
in any JFace part you want ;)
Goulwen
> hide the tabs? I'm trying to gain back valuable screen real estate. :)
Previous Topic:[Henshin] Loading a model from an Xtext resource
Next Topic:[EEF] Caching model artifacts?
Current Time: Sat Nov 28 06:03:06 GMT 2020
Powered by FUDForum. Page generated in 0.01525 seconds
