Home » Archived » Buckminster » [git-reader] Materializing components from different sub-paths of the same repository
[git-reader] Materializing components from different sub-paths of the same repository [message #654845] |
Thu, 17 February 2011 12:21 |
Daniel Weber Messages: 51 Registered: July 2009 |
Member |
I am trying to set up a cquery + rmap for etrice. Since plugins are
located in different subdirectories in the repository, I created
separate searchPaths, like this:
<rm:searchPath name="etrice.examples">
<rm:provider componentTypes="osgi.bundle" readerType="git">
<rm:uri format="{0}/org.eclipse.etrice,examples/{1}">
<bc:propertyRef key="workspace.root" />
<bc:propertyRef key="buckminster.component" />
</rm:uri>
<rm:property key="git.remote.uri" value="${etrice.git.repo}"/>
</rm:provider>
</rm:searchPath>
<rm:searchPath name="etrice.modellib">
<rm:uri format="{0}/org.eclipse.etrice,modellib/{1}">
</rm:uri>
</rm:provider>
</rm:searchPath>
And then defined corresponding locators. So far so good, but when trying
to resolve a cquery using this rmap, I run into errors like this:
> ERROR [0002] : No suitable provider for component org.eclipse.etrice.generator:osgi.bundle was found in resourceMap file:/D:/git/org.eclipse.etrice.releng.feature/etrice-git.rm ap
> ERROR [0002] : No suitable provider for component org.eclipse.etrice.generator:osgi.bundle was found in searchPath etrice.plugins
> ERROR [0002] : Rejecting provider git({0}/org.eclipse.etrice,plugins/{1}[C:/Users/Daniel/works pace/default/org.eclipse.etrice,plugins/org.eclipse.etrice.g enerator]): No component match was found
> ERROR java.io.IOException: Cannot lock file C:\Users\Daniel\workspace\default\org.eclipse.etrice\.git\co nfig
> E [0002] : Rejecting provider git({0}/org.eclipse.etrice,tests/{1}[C:/Users/Daniel/workspa ce/default/org.eclipse.etrice,tests/org.eclipse.etrice.gener ator.tests]): No component match was found: java.io.IOException: Cannot lock file C:\Users\Daniel\workspace\default\org.eclipse.etrice\.git\co nfig
> ERROR [0002] : No suitable provider for component org.eclipse.etrice.ui.behavior:osgi.bundle was found in resourceMap file:/D:/git/org.eclipse.etrice.releng.feature/etrice-git.rm ap
> ERROR [0002] : No suitable provider for component org.eclipse.etrice.ui.behavior:osgi.bundle was found in searchPath etrice.plugins
> ERROR [0002] : Rejecting provider git({0}/org.eclipse.etrice,plugins/{1}[C:/Users/Daniel/works pace/default/org.eclipse.etrice,plugins/org.eclipse.etrice.u i.behavior]): No component match was found
Looks to me like buckminster is trying to lock the local repository
multiple times. The local clone was not present, I intended to let
buckminster take care of this. Does the git reader not support multiple
searchPaths using the same repository?
Here's the feature versions I used:
> Buckminster - Core 1.3.1.r11666 org.eclipse.buckminster.core.feature.feature.group
> Buckminster - Git Support 1.0.360.r11654 org.eclipse.buckminster.git.feature.feature.group
> Buckminster - PDE support 1.2.1.r11660 org.eclipse.buckminster.pde.feature.feature.group
> Eclipse EGit (Incubation) 0.10.1 org.eclipse.egit.feature.group
> Eclipse JGit (Incubation) 0.10.1 org.eclipse.jgit.feature.group
Any help would be appreciated.
Daniel
Re: [git-reader] Materializing components from different sub-paths of the same repository [message #654862 is a reply to message #654845] |
Thu, 17 February 2011 13:22 |
On 2011-02-17 13:21, Daniel Weber wrote:
> Looks to me like buckminster is trying to lock the local repository multiple times. The local clone was not present, I
> intended to let buckminster take care of this. Does the git reader not support multiple searchPaths using the same
> repository?
AFAIK, it has never been tested so there's a distinct possibility that it doesn't work just yet. Our git support is
still in it's infancy and it builds on egit/jgit which is still in incubation and moving forward rapidly. It's all for
the good but help finding bugs, attached samples that provoke errors, and of course patches fixing such errors ;-) is
greatly appreciated. Nothing mandatory of course, but the more the better.
Please enter a bugzilla for this and attach as much info as possible.
Thomas Hallgren
Re: [git-reader] Materializing components from different sub-paths of the same repository [message #654897 is a reply to message #654862] |
Thu, 17 February 2011 14:40 |
Carsten Reckord Messages: 139 Registered: July 2009 |
>> repository?
> Thomas Hallgren
I can confirm this. When initially resolving a query where the git
repository is not yet present locally, concurrency issues ensue.
I've avoided this so far by setting the parallel resolver threads to 1.
IIRC, the problem I identified in the past is that the first resolver thread
starts cloning the repository, then the second thread tries to resolve
something else from it, sees that there already is a repository (and doesn't
know about or gets blocked by the other resolver still cloning) and tries to
checkout from it.
Re: [git-reader] Materializing components from different sub-paths of the same repository [message #655400 is a reply to message #655210] |
Sun, 20 February 2011 15:06 |
On 18.02.2011 17:24, Daniel Weber wrote:
> That seems to be a valid workaround, worked for me, too. Thanks!
>> checkout from it.
> So has a bug been filed already?
No, I meant to file one and look into it further, too, but I haven't come
around to either yet. So feel free to go ahead and file one.
Current Time: Thu Apr 18 07:45:06 GMT 2024
Powered by FUDForum. Page generated in 0.02757 seconds
