Home » Modeling » Papyrus » Plugin pallete name.
Plugin pallete name. [message #654830] Thu, 17 February 2011 10:47 Go to next message
Wojciech Trocki is currently offline Wojciech TrockiFriend
Member
When creating palette using extension point we need to specify palette name.
After installation this name is not used and palette name equals plugin name.
Is this bug or feature? Any changes to fix this?
[Updated on: Thu, 17 February 2011 10:48]
Report message to a moderator
Re: Plugin pallete name. [message #655486 is a reply to message #654830] Mon, 21 February 2011 11:35 Go to previous messageGo to next message
Andres  is currently offline Andres Friend
Member
Hi, some month ago, we needed make a new type of editor with his own palette, and we had problems because the id of the diagram never change(and the name of custom pallete neither)...may be it is your problem...
If this is your problem look hear for the solution
http://www.eclipse.org/forums/index.php?t=msg&goto=63780 5&S=56925404f26e84968ddca16de00bee1e#msg_637805
I hope this help you
Andres
Re: Plugin pallete name. [message #656165 is a reply to message #655486] Thu, 24 February 2011 12:08 Go to previous message
Member
I try this solution. Thanks Smile
Previous Topic:Problem with Copy/Paste for elements with stereotype applied
Next Topic:icons for stereotype
Current Time: Sun Jan 17 16:24:05 GMT 2021
Powered by FUDForum. Page generated in 0.01878 seconds
