Home » Archived » M2M (model-to-model transformation) » Losing atributes after transformation
Losing atributes after transformation [message #654771] Thu, 17 February 2011 03:26 Go to next message
Oscar Andres Fajardo F. is currently offline Oscar Andres Fajardo F.Friend
I'm having trouble finding out how to don't lose the attributes of my generated elements.
I'm new to QVT operational, I'm trying to remake a script I did in QVT relations with mediniQVT but I feel this is not so going good...
I'm no good programmer at all, and all I did in the code was using my imagination, hope I'm not doing huge mistakes...the thing is that some of the generated elements (operative units and products by now)are losing their names and other attributes and I don't understand why
Here's the code in QVTo:::
modeltype MAS uses 'http://MAS/1.0';
modeltype PNS uses 'http://PNS/1.0';
transformation MAS2PNS(in mas:MAS, out pns:PNS);
main()
mas.rootObjects()[MAS::MASModel] -> map MASmodel2PNSmodel();
mapping MAS::MASModel::MASmodel2PNSmodel() : PNS::PNSModel
result.Elements += self.Elements.map MASNE2PNSNE(result);
mapping MAS::MASNamedElement::MASNE2PNSNE(p: PNS::PNSModel)
disjuncts MASElement::MASElement2PNSElement//, MASRelation::MASRelations2PNSRelation
mapping MAS::MASElement::MASElement2PNSElement(p: PNS::PNSModel)
disjuncts MAS::Agent::Agent2PNSElement, MAS::Goal::Goal2PNSElements
mapping MAS::MASRelation::MASRelations2PNSRelation(p: PNS::PNSModel)
self.map MASRelation2PNSRelation(p);
mapping MAS::MASRelation::MASRelation2PNSRelation(p: PNS::PNSModel): PNS::PNSRelation
result.name := self.name;
result.PNS := p;
mapping MAS::Agent::Agent2PNSElement(p: PNS::PNSModel)
when{self.oclIsTypeOf(Agent)}
self.map Agent2RawMaterial(p);
mapping MAS::Agent::Agent2RawMaterial(p: PNS::PNSModel) : PNS::RawMaterial
result.PNS := p;
result.price:= 1.0;
result.maxFlow := 10000.0;
abstract mapping MAS::Goal::Goal2PNSElements(p: PNS::PNSModel)
self.map Goal2IntermediateMaterial(p);
self.map Goal2OperationalUnit(p);
self.map Goal2Product(p);
mapping MAS::Goal::Goal2IntermediateMaterial(p: PNS::PNSModel) :PNS::IntermediateMaterial
result.name :=self.name;
result.PNS := p;
mapping MAS::Goal::Goal2OperationalUnit(p: PNS::PNSModel) : PNS::OperationalUnit
result.name = 'op_'+self.name;
result.PNS := p;
result.lowerBound = 10000.0;
result.upperBound = 10000.0;
mapping MAS::Goal::Goal2Product(p: PNS::PNSModel) : PNS::Product
result.name=self.name+'_oaf';
result.PNS := p;
result.price = 1.0;
result.reqFlow = 0.0;
result.maxFlow = 10000.0;
Plz help! °_°
*_*
If my original code helps, here it is...
transformation MAS2PNS(MAS:MAS,PNS:PNS)
top relation MASModel2PNSModel
checkonly domain MAS mm:MAS::MASModel
enforce domain PNS pm:PNS::PNSModel
top relation Agent2RawMaterial
en : String;
checkonly domain MAS a:MAS::Agent
MAS = mm : MAS::MASModel{},
name = en
enforce domain PNS rm:PNS::RawMaterial
--Creo el Raw Material
PNS =pm : PNS::PNSModel{},
name = en,
price = 1.0,
maxFlow = 10000.0
when
MASModel2PNSModel(mm,pm);
top relation Goal2PNSElements
gn:String;
checkonly domain MAS g:MAS::Goal
name = gn
enforce domain PNS pm : PNS::PNSModel
--Creo el Intermediate Material
Elements = im:PNS::IntermediateMaterial
PNS = pm,
name = gn
--Creo el Product
Elements = p:PNS::Product
name=gn+'_oaf',
price = 1.0,
reqFlow = 0.0,
maxFlow = 10000.0
--Creo el Operational Unit
Elements = ou:PNS::OperationalUnit
name = 'op_'+gn,
lowerBound = 10000.0,
--Creo las relaciones que conectaran los Intermediate Materials con las Operational Units
Elements = rio:PNS::PNSRelation
PNS = pm,
name = gn+'_rel_opUnit'+gn,
source = im,
target = ou,
rate = 1.0
--Creo las relaciones que conectaran las Operational Units con los Products
Elements = rof:PNS::PNSRelation
PNS = pm,
name = 'opUnit_'+gn+'_rel_'+gn+'_oaf',
source = ou,
target = p,
rate = 1.0
when
Thank you very much!!!
Your help would be very appreciated...
PS: don't know how toattach files I will attach the plugins for the transformation as soon as I find out how this works...
(cant find the attach button xD )
Re: Losing atributes after transformation [message #654783 is a reply to message #654771] Thu, 17 February 2011 07:36 Go to previous messageGo to next message
Dennis Hendriks is currently offline Dennis HendriksFriend
Member
After a quick look, the first thing I saw (and this may be the whole
problem), is this mapping:
     result.PNS := p;
You use '=', instead of ':=', meaning result.name is compared to
'op_'+self.name, instead of assigned. The same things happens for
lowerBound and upperBound.
One other thing, you may omit the 'result.' prefix here.
If you change all this, one would get (for this mapping):
     name := 'op_' + self.name;
     PNS := p;
     lowerBound := 10000.0;
     upperBound := 10000.0;
Hope this helps.
Dennis
Oscar Andres Fajardo F. wrote:
> generated elements.
> main() {
> PNS::PNSRelation
> result.PNS := p;
> result.PNS := p;
> result.price:= 1.0;
> result.PNS := p;
> result.PNS := p;
> result.PNS := p;
> result.price = 1.0;
> Plz help! °_°
> *_*
> * */ transformation MAS2PNS(MAS:MAS,PNS:PNS)
> en : String;
> name = en
> name = en,
> price = 1.0,
> maxFlow = 10000.0
> when
> gn:String;
> name = gn
> PNS = pm,
> name = gn
> --Creo el Product
> name=gn+'_oaf',
> price = 1.0,
> reqFlow = 0.0,
> maxFlow = 10000.0
> name = 'op_'+gn,
> PNS = pm,
> source = im,
> target = ou,
> rate = 1.0
> PNS = pm,
> source = ou,
> target = p,
> rate = 1.0
> when
Re: Losing atributes after transformation [message #655297 is a reply to message #654783] Sat, 19 February 2011 02:50 Go to previous messageGo to next message
Thank you very much this totally helped me!!!
Got another question... Sorry Sad
If I execute the transformation repeatedly it doesnt replace the existing target model, instead places a "sibling" model...
Got any idea?
Red should replace Blue, instead it allocates right next to it... don't know why...at the end the code used right now.
Here's an example...
<xmi:XMI xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:PNS="http://PNS/1.0">
<PNS:PNSModel>
<Elements xsi:type="PNS:RawMaterial" name="a1" price="1.0" maxFlow="10000.0"/>
<Elements xsi:type="PNS:PNSRelation" rate="2.0" source="/0/@Elements.9" target="/0/@Elements.10"/>
</PNS:PNSModel>
<PNS:PNSModel>
<Elements xsi:type="PNS:RawMaterial" name="a2" price="1.0" maxFlow="10000.0"/>
<Elements xsi:type="PNS:PNSRelation" name="g2_rel_op_g2" rate="1.0" source="/1/@Elements.8" target="/1/@Elements.9"/>
<Elements xsi:type="PNS:PNSRelation" name="op_g2_rel_g2_oaf" rate="2.0" source="/1/@Elements.9" target="/1/@Elements.10"/>
</PNS:PNSModel>
main()
	result.PNS := p;
	result.PNS := p;
	result.price:= 1.0;
	var im : IntermediateMaterial;
	var ou : OperationalUnit;
	var pd: Product;
	im := self.map Goal2IntermediateMaterial(p);
	ou := self.map Goal2OperationalUnit(p);
	pd := self.map Goal2Product(p);
	map newRelation1(p,im,ou);
	map newRelation2(p,ou,pd);
mapping newRelation1(p: PNS::PNSModel, im:PNS::IntermediateMaterial,ou : PNS::OperationalUnit):PNS::PNSRelation
	result.PNS := p;
	result.name := im.name + '_rel_' + ou.name;
	result.source := im;
	result.target := ou;
	result.rate := 1.0;
mapping newRelation2(p: PNS::PNSModel, ou : PNS::OperationalUnit, pd : PNS::Product):PNS::PNSRelation
	result.PNS := p;
	result.name := ou.name + '_rel_'+pd.name;
	result.source := ou;
	result.target := pd;
	result.rate := 1.0;
	result.PNS := p;
	result.name := 'op_'+self.name;
	result.PNS := p;
	result.lowerBound := 10000.0;
	result.upperBound := 10000.0;
	result.name := self.name+'_oaf';
	result.PNS := p;
	result.price := 1.0;
	result.reqFlow := 0.0;
Re: Losing atributes after transformation [message #655306 is a reply to message #655297] Sat, 19 February 2011 06:26 Go to previous message
Seems it has somethig to do with: https://bugs.eclipse.org/bugs/show_bug.cgi?id=315007
Are there plans to correct this bug?
thank you
Previous Topic:problem with output SCA model file format
Next Topic:[ATL] Rule choose
Current Time: Tue Jun 02 03:06:07 GMT 2020
Powered by FUDForum. Page generated in 0.02451 seconds
