Re: [Bindings] Removing a key-binding [message #654800 is a reply to message #654712] |
Thu, 17 February 2011 08:41 |
Daniel Krügler Messages: 853 Registered: July 2009 |
On 2011-02-16 19:54, Paul Webster wrote:
> You cannot mark a command that way, but you can delete a specific
> keybinding in a specific context:
> copy out the Collapse All keybinding, and simply remove the commandId
> ... that will wipe out that binding.
OK, that worked, thanks!
> But with a delete marker at the same level provided by a plugin.xml
> (considered SYSTEM) only users would be able to bind that key sequence
> to something more useful (with a few minor exceptions)
I have problems to follow you here, could you elaborate, please?
1) Is the "delete marker" the above mentioned keybinding registration
that omits the commandId?
2) I don't understand, in which sense "SYSTEM" and "users" are entering
the game here.
Do you want to describe that by doing above effective removal of the
key-binding "M1+M2+NUMPAD_DIVIDE" I can never reassign this binding to
another command?
Thanks & Greetings from Bremen,
- Daniel Krügler
FUDForum. Page generated in 0.03570 seconds
