Re: Helios: Unhandled event loop exception [message #655418 is a reply to message #654433] |
Sun, 20 February 2011 17:32 |
Hi Marco,
Something wrong in the preference page that is opened by the rcpcolibri
action?
Wim
> I started to have this error that i cannot trace back to my app (i use
"org.eclipse.nebula.widgets" NumberFormatter, that woked pretty well in
previous versions of Eclipse).
> This error does not seem affect anything crucial...
> Thanks.
> !ENTRY org.eclipse.ui 4 0 2011-02-15 18:14:42.716
> !MESSAGE Unhandled event loop exception
> !STACK 0
> java.lang.StringIndexOutOfBoundsException: String index out of range: -1
> at java.lang.String.substring(Unknown Source)
> at org.eclipse.jface.internal.databinding.swt.SWTVetoableValueD
ecorator$1.handleEvent(SWTVetoableValueDecorator.java:38)
> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
> at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
> at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1077)
> at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1062)
> at org.eclipse.swt.widgets.Text.verifyText(Text.java:2066)
> at org.eclipse.swt.widgets.Text.sendKeyEvent(Text.java:1517)
> at org.eclipse.swt.widgets.Widget.sendKeyEvent(Widget.java:1099 )
> at org.eclipse.swt.widgets.Widget.wmChar(Widget.java:1508)
> at org.eclipse.swt.widgets.Control.WM_CHAR(Control.java:4268)
> at org.eclipse.swt.widgets.Text.WM_CHAR(Text.java:2175)
> at org.eclipse.swt.widgets.Control.windowProc(Control.java:4160 )
> at org.eclipse.swt.widgets.Text.windowProc(Text.java:2170)
> at org.eclipse.swt.widgets.Display.windowProc(Display.java:4873 )
> at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
> at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:24 59)
> at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3655)
> at org.eclipse.jface.window.Window.runEventLoop(Window.java:825 )
> at org.eclipse.jface.window.Window.open(Window.java:801)
> at rcpcolibri.ui.workbench.actions.OpenPreferencePageAction.run
(OpenPreferencePageAction.java:90)
> at org.eclipse.jface.action.Action.runWithEvent(Action.java:498 )
> at org.eclipse.jface.action.ActionContributionItem.handleWidget
Selection(ActionContributionItem.java:584)
> at org.eclipse.jface.action.ActionContributionItem.access$2(Act
ionContributionItem.java:501)
> at org.eclipse.jface.action.ActionContributionItem$6.handleEven
t(ActionContributionItem.java:452)
> at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:4066)
> at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3657)
> at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2640)
> at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2604)
> at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:24 38)
> at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:671)
> at org.eclipse.core.databinding.observable.Realm.runWithDefault
(Realm.java:332)
> at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work
bench.java:664)
> at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:149)
> at rcpcolibri.Application.start(Application.java:56)
> at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips
eAppHandle.java:196)
> at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher
runApplication(EclipseAppLauncher.java:110)
start(EclipseAppLauncher.java:79)
> at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS
tarter.java:369)
tarter.java:179)
> at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 619)
> at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
> at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
> at org.eclipse.equinox.launcher.Main.main(Main.java:1383)
Re: Helios: Unhandled event loop exception [message #665745 is a reply to message #665648] |
Fri, 15 April 2011 17:25 |
Marco Lopes Messages: 61 Registered: September 2010 |
Member |
Yves Schubert wrote on Fri, 15 April 2011 07:12 | Hello!
I am having the same problem.
I use the Nebula NumberFormatter with databinding and get the same exception when:
- Select all text in the textbox and press DEL or entering a small number
- Go to the end of the string and press BACKSPACE
However, all data is consistent and the exception does not affect the logic of my code.
Though, it is not very nice
I found a documented bug at
https://bugs.eclipse.org/bugs/show_bug.cgi?id=318782
that describes the same errornous behavior. They say that it is fixed, but i don't really think so?
My Eclipse Version:
Version: Helios Service Release 2
Build id: 20110301-1815
Exactly my problem.
Still not fixed on the latest Eclipse release: Indigo M6a (Build id: 20110319-2305)
Using Windows XP SP3. I will test also in Ubuntu and OS X.
[Updated on: Fri, 15 April 2011 17:26] Report message to a moderator
FUDForum. Page generated in 0.02514 seconds
