Home » Eclipse Projects » EGit / JGit » Git and version qualifiers
Git and version qualifiers [message #654350] Tue, 15 February 2011 10:44 Go to next message
Maxime Jeanmart is currently offline Maxime JeanmartFriend
Member
P2 normally asks the following version format "major.minor.service.qualifier" for plug-ins, though it's not really mandatory. What I think is mandatory is to have the version number be monotonically increasing. The usual pattern is to include the source control id in the qualifier. Unfortunately, git uses hash codes as ids, which doesn't ensure that the number increases with versions.
So how does it work for plug-in versions stored using git? I noticed that eGit and JGit plug-ins don't use the qualifier at the end of the version number: Should we do just that, forget about the qualifier?
Maxime
Re: Git and version qualifiers [message #654367 is a reply to message #654350] Tue, 15 February 2011 12:23 Go to previous messageGo to next message
Paul Webster is currently offline Paul WebsterFriend
egit and jgit do use the qualifier, at least for the nightlies. I guess
just not for the release. That means technically the nightly plugin is
"greater" than the released plugin.
But I didn't have any trouble updating from a nightly to the release, I
guess it doesn't matter so much.
But in e4 we use git repos and map files with PDE build and the Git
fetch factory, and it produces plugins with the traditional increasing
qualifier.
PW
Paul Webster
http://wiki.eclipse.org/Platform_Expression_Framework
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Re: Git and version qualifiers [message #654406 is a reply to message #654367] Tue, 15 February 2011 15:44 Go to previous messageGo to next message
Chris Aniszczyk is currently offline Chris AniszczykFriend
I always recommend using the qualifier. The reason EGit and JGit drop the qualifier for releases is due to Maven and P2 versioning differences.
So essentially, we'll have nightly builds...
0.11.0.qualifier
When we release, we'll do a 0.11.1, tag and move on to 0.11.2.qualifier... if we need to release again, we'll do a 0.11.3 and 0.11.4.qualifier... and so on.
Hope that makes a bit sense.
Re: Git and version qualifiers [message #654511 is a reply to message #654406] Wed, 16 February 2011 07:17 Go to previous message
Member
I think it makes sense indeed. Since the qualifier starts with the date, the nightly build always produces a higher qualifier, whatever the id after the date.
I guess we just have to take care if we do more than a build a day for some reasons, which should not happen too often.
Previous Topic:Show Annotation
Next Topic:ANT Support?
Current Time: Sun Dec 04 16:36:26 GMT 2022
Powered by FUDForum. Page generated in 0.02127 seconds
