Home » Modeling » M2T (model-to-text transformation) » Availability of Accleo version 3.1.x via update site
Availability of Accleo version 3.1.x via update site [message #654344] Tue, 15 February 2011 10:16 Go to next message
dieppi is currently offline dieppiFriend
when will version 3.1.x availabile via update site?
Best regards
Maik
Re: Availability of Accleo version 3.1.x via update site [message #654356 is a reply to message #654344] Tue, 15 February 2011 11:12 Go to previous messageGo to next message
Stephane Bouchet is currently offline Stephane BouchetFriend
Hi Maik,
currently, only the milestones versions are available ( 3.1.0M5 and
previous ) . they can be acceded via :
http://download.eclipse.org/modeling/m2t/acceleo/updates/mil estones/3.1
In june, the released version will be accessible here :
http://download.eclipse.org/modeling/m2t/acceleo/updates/rel eases/3.1
Le 15/02/2011 11:16, Maik a écrit :
> Best regards
> Maik
Stéphane Bouchet, OBEO
Re: Availability of Accleo version 3.1.x via update site [message #654434 is a reply to message #654356] Tue, 15 February 2011 18:30 Go to previous messageGo to next message
Hi Stéphane,
thanks for quick answer. Wink What are the differences between version 3.0.x and 3.1.x? Are there general changes or performance improvements and bugfixing?
Best regards
Maik
[Updated on: Tue, 15 February 2011 18:31]
Report message to a moderator
Re: Availability of Accleo version 3.1.x via update site [message #654537 is a reply to message #654344] Wed, 16 February 2011 09:12 Go to previous messageGo to next message
Stephane Begaudeau is currently offline Stephane BegaudeauFriend
Acceleo 3.1 already includes several new features that you can see here:
http://sbegaudeau.tumblr.com/post/961722949/user-interface-i mprovements-in-acceleo-3-1
The roadmap for Acceleo 3.1 contains performance improvements and bug fixing of course but also new features like improved support for output languages of the generation, better integration for Ant and Maven etc.
Stéphane Bégaudeau, Obeo.
Twitter: @sbegaudeau
Acceleo wiki: http://wiki.eclipse.org/Acceleo
Blogs: http://stephanebegaudeau.tumblr.com & http://sbegaudeau.tumblr.com
Re: Availability of Accleo version 3.1.x via update site [message #654567 is a reply to message #654537] Wed, 16 February 2011 10:44 Go to previous messageGo to next message
Hi Stéphane,
what means better integration for ant and maven?
Best regards
Maik
Re: Availability of Accleo version 3.1.x via update site [message #654582 is a reply to message #654344] Wed, 16 February 2011 12:01 Go to previous messageGo to next message
Being able to launch the Acceleo compiler and the Acceleo generation from Ant and Maven easily in stand alone mode (without any dependencies with Eclipse).
Re: Availability of Accleo version 3.1.x via update site [message #655094 is a reply to message #654582] Fri, 18 February 2011 10:05 Go to previous messageGo to next message
Hi Stéphane,
sounds good. I'am already use acceleo with maven and ant. i wrote my own maven plugin for calling acceleo for UML metamodels. It works fine and is very quickly.
Best regards
Maik
Re: Availability of Accleo version 3.1.x via update site [message #689407 is a reply to message #655094] Mon, 27 June 2011 15:30 Go to previous messageGo to next message
Hi Stéphane,
i saw that Acceleo version 3.1 is out. Are there some maven or ant improvements? If yes could you describe the improvements?
Do i need the lpg.runtime.java in Acceleo 3.1 dependency for calling Acceleo compiler and generator outside Eclipse?
Best regards
Maik
[Updated on: Mon, 27 June 2011 15:30]
Re: Availability of Accleo version 3.1.x via update site [message #689894 is a reply to message #689407] Tue, 28 June 2011 14:48 Go to previous messageGo to next message
lpg.runtime.java is needed by OCL and Acceleo needs OCL so yes.
If you want to use Acceleo with Maven or Ant, you can use those links:
1- A blog post from me showing a step by step guide to build an Acceleo generator with maven: here
2- An open source UML to Java generator that I've created. It contains all the necessary files to build it with maven (download the source, then "mvn clean package" and you have a nice update site ready to go). You can have a look, fork it and even contribute to it if you want: here
3- The Acceleo 3.1 user guide on the Obeo Network with the documentation dedicated to the integration of Acceleo in an Ant or Maven based workflow: here
You can find lots of information about Acceleo on my blogs here, there and on twitter. The Obeo Network also contains resources for Acceleo like the Best Practices guide and countless of videos of all the features of Acceleo.
Finally, you can find all the new features of Acceleo 3.1 in this blog post.
By the way, those looking to get the latest release of Acceleo should use the Acceleo 3.1 update site: http://download.eclipse.org/modeling/m2t/acceleo/updates/releases/3.1
Stephane Begaudeau, Obeo
Blog: http://stephanebegaudeau.tumblr.com
Acceleo Documentation: http://docs.obeonetwork.com/acceleo
[Updated on: Tue, 28 June 2011 15:08]
Re: Availability of Accleo version 3.1.x via update site [message #690238 is a reply to message #689894] Wed, 29 June 2011 08:52 Go to previous messageGo to next message
Hi Stephane,
thanks for your quick answer. My questions regards to the most interesting feature of acceleo. Running outside of eclipse as standalone maven or ant task. I use Acceleo 3.0.x with an own developed maven task. Is the ant task enhanced in Acceleo 3.1 or includes Acceleo 3.1 an additional maven task to start a generation outside of eclipse as part of build or pom file?
Best regards
Maik
Re: Availability of Accleo version 3.1.x via update site [message #690882 is a reply to message #690238] Thu, 30 June 2011 11:27 Go to previous message
In order to start a generation from Ant, Acceleo delivers Ant tasks in the "tasks" folder of your Acceleo project. If you are using maven, you can also directly call the Java launcher class generated with a main template, you just have to get the dependencies of Acceleo in the classpath and then call the main method. In order to test your generator, you can try to run it with the "Java Application" runner in the run configuration.
Previous Topic:[XPand/MWE] MWE runs quite slow, since upgrade to latest version of Xpand/Xtext
Next Topic:workflow.mwe resource refresh
Current Time: Fri May 20 21:05:07 GMT 2022
Powered by FUDForum. Page generated in 0.02828 seconds
