Home » Modeling » Graphiti » Send to Front or Back(Supported for Shapes, but not for Connections ?)
Send to Front or Back [message #654274] Mon, 14 February 2011 20:51 Go to next message
Jos Warmer is currently offline Jos WarmerFriend
The method Graphiti.getPeService().sendToFront allows one to send a shape to the front, there is also a method to send a shape to the back. I have a Connection that I need to send to the back, but cannot find a method to do this. What would b the best way to achieve this ?
Jos
Re: Send to Front or Back [message #654326 is a reply to message #654274] Tue, 15 February 2011 08:13 Go to previous messageGo to next message
Michael Wenz is currently offline Michael WenzFriend
Graphiti renders all connections onto one specific layer in the diagram,
that's the reason why there is no send to back/front for them.
Michael
Re: Send to Front or Back [message #654826 is a reply to message #654326] Thu, 17 February 2011 10:26 Go to previous messageGo to next message
You seem to be right, even when I call sendToFront() for a shape, it still is behind the connections.
This does mean (at least for my case) that connections are always in front of the shapes. Is there a way to make the connection layer be under the shapes layers, such that all connections are underneath the shapes.
Jos
Re: Send to Front or Back [message #655754 is a reply to message #654826] Tue, 22 February 2011 14:41 Go to previous message
Tim Kaiser is currently offline Tim KaiserFriend
Hi Jos,
have a look at
ScalableRootEditPartAnimated
There exists a field
connectionLayerOnTop
which defaults to true.
Currently there is no API to change the value.
(To try it, you might use the debugger (change value...) or reflection)
You might open a bugzilla request for introducing API to change the value
of the field.
Best, Tim
Previous Topic:Interacting With A Connection
Next Topic:Graphiti API
Current Time: Thu Jan 28 00:07:58 GMT 2021
Powered by FUDForum. Page generated in 0.01882 seconds
