Home » Eclipse Projects » Remote Application Platform (RAP) » A new update of qooxdoo, or use another framework?(What use to have the support?)
A new update of qooxdoo, or use another framework? [message #654231] Mon, 14 February 2011 17:02 Go to next message
Luis Carlos Moreira da Costa is currently offline Luis Carlos Moreira da CostaFriend
Member
I was talking with the staff of qooxdoo, and he told me the following:
Also, RAP still uses a legacy qooxdoo version 0.7.x, which (from our
point of view) is outdated, and no longer supported by us. AFAIK there
are no plans on the RAP side to update to a newer qooxdoo version. As
you asked in your other mail: yes, qooxdoo already does already - and
will so even more - support modern HTML5 features.
I wonder if Eclipse RAP will update the qooxdoo, or will use another framework?
Luís Carlos Moreira da Costa
Eclipse RAP, RCP, eRCP, GMF, OSGi, Scala, Haskell, D (Digital Mars), Qt, Spring and Pentaho
Regional Communities/Brazil
http://wiki.eclipse.org/Regional_Communities/Brazil
Eclipse RAP, RCP, eRCP, GEF, EMF, GMF, OSGI, Spring-DM and Pentaho Developer
Re: A new update of qooxdoo, or use another framework? [message #654241 is a reply to message #654231] Mon, 14 February 2011 17:29 Go to previous messageGo to next message
Ivan Furnadjiev is currently offline Ivan FurnadjievFriend
Hi Luis,
the answer is here:
http://www.eclipse.org/forums/index.php?t=msg&goto=64696 5
Best,
Ivan
> framework?
> Cheers,
Re: A new update of qooxdoo, or use another framework? [message #654246 is a reply to message #654241] Mon, 14 February 2011 17:42 Go to previous message
Member
Previous Topic:Deploy on hosted server leads to AccessControlException
Next Topic:RAP + JASIG-CAS/SSO?
Current Time: Tue Nov 30 22:56:47 GMT 2021
Powered by FUDForum. Page generated in 0.02657 seconds
