Home » Eclipse Projects » Remote Application Platform (RAP) » Keybinding's scheme
Keybinding's scheme [message #653715] |
Thu, 10 February 2011 19:38 |
I'm trying the new keybinding feature and it works fine when I use the org.eclipse.ui.defaultAcceleratorConfiguration scheme, but this scheme produces conflicts with some keys like this:
!MESSAGE Keybinding conflicts occurred. They may interfere with normal accelerator operation.
!SUBENTRY 1 org.eclipse.jface 2 0 2011-02-10 13:22:55.982
!MESSAGE A conflict occurred for F2:
Binding(F2,
ParameterizedCommand(Command(50200,F2, , Category(ui.controllers.category,category,Tool Bar commands,true), ,,,true),null),
org.eclipse.ui.defaultAcceleratorConfiguration,
org.eclipse.ui.contexts.window,,,system)
Binding(F2,
ParameterizedCommand(Command(org.eclipse.ui.edit.rename,Rena me,Rename the selected item,
Category(org.eclipse.ui.category.file,File,null,true),,,,tru e),null),
So I tried to define my own scheme:
<scheme name="key scheme" description="Application's shortcuts" id="scheme.id" />
But I have read that in order to use my own scheme I have to register it in the plugin_customization.ini file, and I did.
But it seems that the application is not reading this file. In RCP the plugin_customization.in file is configured in the products extension point, but this extension point doesn't exist in RAP.
Is there another way to register the scheme?
Re: Keybinding's scheme [message #653905 is a reply to message #653715] |
Fri, 11 February 2011 18:57 |
I found a way to activate the shceme through the code:
BindingService service = (BindingService)configurer.getWindow().getWorkbench().getSer vice(IBindingService.class);
Scheme s = service.getScheme("scheme.id");
manager.setActiveScheme(s);
With this code the conflicts do not appear, and I also realized there is no need of the plugin_customization.ini since the scheme is registered with the declaration of it in the plugin.xml, but no activated.
I don't know if it is the best way to activate the scheme, does anyone has a better idea for this?
Current Time: Thu Apr 25 15:38:32 GMT 2024
Powered by FUDForum. Page generated in 0.03781 seconds
