Home » Modeling » EMF » [CDO] Net4j old version of h2 Db used in plugin
[CDO] Net4j old version of h2 Db used in plugin [message #653702] Thu, 10 February 2011 18:28 Go to next message
David Wynter is currently offline David WynterFriend
Is there an official way of updating the version of the database driver
embedded as a plugin in Eclipse and used by Net4J? The current H2 driver
is V1.1.14, we use 1.3.46 currently and it does create problems as the
databases are incompatible formats.
I tried hacking the org.eclipse.net4j.db.h2_3.0.0.v20100626-0740 plugin
to accept V1.3.0 of the h3 plugin, and created a h2 plugin with that
version (org.h2-1.3.146.v201012120146.jar). But I get
java.lang.IllegalArgumentException: Unknown DB adapter: h2
Thx.
David
Re: [CDO] Net4j old version of h2 Db used in plugin [message #654164 is a reply to message #653702] Mon, 14 February 2011 13:05 Go to previous messageGo to next message
Victor Roldan Betancort is currently offline Victor Roldan BetancortFriend
Hi David,
The most common way is to get it from Orbit, but right now it includes
1.1.117. Alternatively, and due to license incompatibilities, we provide
some drivers in our sourceforge repository, but is not the case of the
H2 Driver.
http://net4j.sourceforge.net/update/
So Im afraid you'll have to create your own H2 bundle :(
Thats odd. Have you checked if the bundle org.eclipse.net4j.db.h2 is
indeed loaded properly by equinox?
I created https://bugs.eclipse.org/bugs/show_bug.cgi?id=337106 to
increase version ranges, to make it possible to include newer h2
versions. However, I just realized you are using 3.0.0... maybe we can
also patch 3.0.0 before SR2.
Víctor.
Re: [CDO] Net4j old version of h2 Db used in plugin [message #654183 is a reply to message #654164] Mon, 14 February 2011 13:48 Go to previous messageGo to next message
Created backport for 3.0.0
https://bugs.eclipse.org/bugs/show_bug.cgi?id=337118
Re: [CDO] Net4j old version of h2 Db used in plugin [message #654694 is a reply to message #654164] Wed, 16 February 2011 17:31 Go to previous messageGo to next message
I went to http://sourceforge.net/projects/net4j/ to see if I could look
at the HDBSQL setup and copy that to make my own H2 version. But there
are no files there at all. Any pointer son what I would need to do to
build a correct H2 1.3.nn bundle?
Thx.
David
On 14/02/11 13:05, Víctor Roldán Betancort wrote:
> Hi David,
> H2 Driver.
> Cheers,
> Víctor.
Re: [CDO] Net4j old version of h2 Db used in plugin [message #654697 is a reply to message #654164] Wed, 16 February 2011 17:56 Go to previous messageGo to next message
I also noticed something that looks a little strange. The current h2
1.1.17 has this entry in the MANIFEST.MF
Main-Class: org.h2.tools.Console
shouldn't this be
Main-Class: org.h2.tools.Server
Am I right in assuming that I have to create a bundle from scratch, i.e.
by changing the manifest bundles versions in my hacked jar MANIFEST.MF
and the class files to the later versions it changes the MANIFEST.SF
file signatures? Since I know nothing about this I might have to switch
to HSQLDB just to save time.
Thx.
David
> Hi David,
> H2 Driver.
> Cheers,
> Víctor.
Re: [CDO] Net4j old version of h2 Db used in plugin [message #654709 is a reply to message #654697] Wed, 16 February 2011 18:28 Go to previous messageGo to next message
Eike Stepper is currently offline Eike StepperFriend
Am 16.02.2011 18:56, schrieb David Wynter:
> I also noticed something that looks a little strange. The current h2 1.1.17 has this entry in the MANIFEST.MF
> shouldn't this be
I have no clue. This bundle is just redistributed from the Orbit project: http://www.eclipse.org/orbit/overview.php
> Am I right in assuming that I have to create a bundle from scratch, i.e. by changing the manifest bundles versions in my hacked jar MANIFEST.MF and the class files to the later versions it changes the MANIFEST.SF file signatures? Since I know nothing about this I might have to switch to HSQLDB just to save time.
There's a PDE new plugin wizard that creates a bundle from a plain java jar. Sometimes you can directly use the resulting bundle, sometimes you have to adjust the manifest entries. Usually it's good to add versions on the package exports, for example.
Cheers
/Eike
http://www.esc-net.de
> Thx.
> David
>> Hi David,
>> H2 Driver.
>> Cheers,
>> Víctor.
Re: [CDO] Net4j old version of h2 Db used in plugin [message #654710 is a reply to message #654697] Wed, 16 February 2011 18:50 Go to previous messageGo to next message
I found the feature.xml in the org.eclipse.net4j.db.h2_3.0.0.v20110215-1555
I checked out this morning and updated the 2nd plugin entry to point at
my new h2 plugin, using the new version I created. I also learn't how to
sign that h2 jar with my key and did that and pasted the signatures from
my DAVIDWYN.SF into the MANIFEST.MF file.
But it still will not load the H2 Adapter, don't know why yet.
Any pointers welcome.
Thx.
David
> shouldn't this be
> Thx.
> David
>> Hi David,
>> H2 Driver.
>> Cheers,
>> Víctor.
Re: [CDO] Net4j old version of h2 Db used in plugin [message #654719 is a reply to message #654710] Wed, 16 February 2011 19:06 Go to previous messageGo to next message
Found the reason, clearly my signing is not up to scratch
!MESSAGE Either the manifest file or the signature file has been
tampered in this jar:
/home/david/opt1/eclipse/plugins/org.h2-1.3.146.v20101231014 6.jar
This is why it does not load.
David
On 16/02/11 18:50, David Wynter wrote:
> Thx.
> David
>> shouldn't this be
>> Thx.
>> David
>>> Hi David,
>>>> driver
>>> H2 Driver.
>>> Cheers,
>>> Víctor.
Re: [CDO] Net4j old version of h2 Db used in plugin [message #654720 is a reply to message #654719] Wed, 16 February 2011 19:14 Go to previous messageGo to next message
Looks like I am stymied. This is from the Eclipse page on signing jars
"A critical part of the security behind signing is that the private keys
used to produce the signatures are held in a secure location and never
transmitted or accessible via a network. To accomplish this, the signing
must be done on a secure machine that has access to the private key. The
Eclipse Foundation has set up a machine with a signing script. The build
will upload content to be signed to this machine, and a script is run to
perform the signing. Access to this machine will be given to trusted
parties that want to perform signing.
At the time of writing, persons who want to get jar signing privilege
need to be committers, and apply for that privilege with the Webmaster.
Project leads are required to authorize the request. Special permissions
will be granted to the committer's UNIX login on the jar signing machine."
HSQLDB here I come. The problem here is I imported a large model into my
H2 CDO repo, then opened it with H2 V1.3.46 (the later version) which
automatically converted the version to the post V1.1 format, now
unreadable by V1.1.17, so now screwed.
For some reason the Eclipse support is in the dark ages, which is
surprising given how good H2 is. I haven't used HSQLDB in years now.
David
On 16/02/11 19:06, David Wynter wrote:
> David
>> Hi,
>> Thx.
>> David
>>> shouldn't this be
>>> Thx.
>>> David
>>>> Hi David,
>>>>> driver
>>>>> driver
>>>> provide
>>>> H2 Driver.
>>>>> plugin
>>>> Cheers,
>>>> Víctor.
Re: [CDO] Net4j old version of h2 Db used in plugin [message #654727 is a reply to message #654720] Wed, 16 February 2011 20:17 Go to previous messageGo to next message
Am 16.02.2011 20:14, schrieb David Wynter:
> "A critical part of the security behind signing is that the private keys used to produce the signatures are held in a secure location and never transmitted or accessible via a network. To accomplish this, the signing must be done on a secure machine that has access to the private key. The Eclipse Foundation has set up a machine with a signing script. The build will upload content to be signed to this machine, and a script is run to perform the signing. Access to this machine will be given to trusted parties that want to perform signing.
> At the time of writing, persons who want to get jar signing privilege need to be committers, and apply for that privilege with the Webmaster. Project leads are required to authorize the request. Special permissions will be granted to the committer's UNIX login on the jar signing machine."
I'm not sure why you need to sign your own bundles. You may have good reasons. But I have no clue how all that works. I'm happy that Buckinster does all that for us ;-)
> HSQLDB here I come. The problem here is I imported a large model into my H2 CDO repo, then opened it with H2 V1.3.46 (the later version) which automatically converted the version to the post V1.1 format, now unreadable by V1.1.17, so now screwed.
> For some reason the Eclipse support is in the dark ages, which is surprising given how good H2 is.
Yes, we definitely recommend H2. Unfortunately we have no resources to keep up to date with all the new versions of the many different backend/database types we tend to support. The main blocker for us is that we're required to go through a legal review for each concrete version of each third party component, even if we don't ship that component but just refer to it, even if other Eclipse projects have already used it. I leave it to you to judge about this process, but I can certainly not change it ;-(
Me neither.
Cheers
/Eike
> David
>> Hi,
>> David
>>> Hi,
>>> Thx.
>>> David
>>>> shouldn't this be
>>>> Thx.
>>>> David
>>>>> Hi David,
>>>>>> driver
>>>>>> driver
>>>>> provide
>>>>> H2 Driver.
>>>>>> plugin
>>>>> Cheers,
>>>>> Víctor.
Re: [CDO] Net4j old version of h2 Db used in plugin [message #654835 is a reply to message #654727] Thu, 17 February 2011 10:46 Go to previous messageGo to next message
The problem for H2 users is that as of V1.2.120 the file format for the
database changed. There is an automatic conversion to the new format if
you include an additional jar on the classpath, once an old version is
converted there is no going back. I made that mistake, wanting to see
the data the CDO stored.
I tried stripping out all the signing information from the new h2 jar I
created, it still does not load, so there is some magic going on that is
not obvious. Now trying to import an old model I had in xml format into
Derby. Will then have to reenter the changes since then. To give you an
idea the xmi file is over 10K lines long... Which is why I persisted for
so long in trying to recvoer.
Thx for your help. I know more, but clearly not enough to create a new
plugin to do the job.
David
> Me neither.
> Cheers
> /Eike
> http://thegordian.blogspot.com
> http://twitter.com/eikestepper
>> David
>>> Hi,
>>> David
>>>> Hi,
>>>> how to
>>>> from
>>>> Thx.
>>>> David
>>>>> shouldn't this be
>>>>> i.e.
>>>>> switch
>>>>> Thx.
>>>>> David
>>>>>> Hi David,
>>>>>>> driver
>>>>>>> driver
>>>>>>> as the
>>>>>> includes
>>>>>> provide
>>>>>> the
>>>>>> H2 Driver.
>>>>>>> plugin
>>>>>> can
>>>>>> Cheers,
>>>>>> Víctor.
Re: [CDO] Net4j old version of h2 Db used in plugin [message #654836 is a reply to message #654835] Thu, 17 February 2011 11:15 Go to previous messageGo to next message
Am 17.02.2011 11:46, schrieb David Wynter:
> The problem for H2 users is that as of V1.2.120 the file format for the database changed. There is an automatic conversion to the new format if you include an additional jar on the classpath, once an old version is converted there is no going back. I made that mistake, wanting to see the data the CDO stored.
> I tried stripping out all the signing information from the new h2 jar I created, it still does not load, so there is some magic going on that is not obvious. Now trying to import an old model I had in xml format into Derby. Will then have to reenter the changes since then. To give you an idea the xmi file is over 10K lines long... Which is why I persisted for so long in trying to recvoer.
> Thx for your help. I know more, but clearly not enough to create a new plugin to do the job.
Maybe the new repository export/import functionality can help you. It's backend-agnositc and also available through the OSGi console.
Cheers
/Eike
Re: [CDO] Net4j old version of h2 Db used in plugin [message #654852 is a reply to message #654836] Thu, 17 February 2011 12:26 Go to previous messageGo to next message
Yes, I had preivous;ly done that successfully, you helped me in another
thread, I think it took 8 attempts with a eclipse restart each time to
get success. But this time I have no such luck. Here are my steps
I use CDO Session view of my IDE, the view is shipped with
org.eclipse.emf.cdo.ui plug-in. The steps are:
1. Establish a connection to a CDO server
2. Import my model into the Registry
3. Open a transaction
4. Create a resource
5. Commit
6. Go to the resource editor by double clicking the created resource.
7. In the context menu select Import Roots and import my
content.xml document.
8. Commit the transaction.
At step 8 I get this:
org.eclipse.net4j.signal.RemoteException:
org.eclipse.emf.common.util.WrappedException:
java.lang.ClassNotFoundException: edmmodel.EdmmodelPackage
at
org.eclipse.emf.ecore.plugin.RegistryReader$EPackageDescript or.getEPackage(RegistryReader.java:279)
at
org.eclipse.emf.ecore.impl.EPackageRegistryImpl.getEPackage( EPackageRegistryImpl.java:133)
at
org.eclipse.emf.cdo.internal.common.model.CDOPackageUnitImpl .loadPackageFromGlobalRegistry(CDOPackageUnitImpl.java:378)
Not sure what I am missing here. I restart Eclipse and the CDO Server
each attempt and start with a new Resource each time. I get consistent
results. It look slike to me that my EMF project where I developed this
model needs somehow to be on the CDO Explorer's classpath?
thx.
David
>> Hi,
> Cheers
> /Eike
Re: [CDO] Net4j old version of h2 Db used in plugin [message #654853 is a reply to message #654852] Thu, 17 February 2011 12:39 Go to previous messageGo to next message
Something else I noticed about CDO Explorer. When importing the Roots I
get 4 of these every single time, in the .log file
!ENTRY org.eclipse.ui 4 0 2011-02-17 12:37:43.732
!MESSAGE Unhandled event loop exception
!STACK 0
org.eclipse.swt.SWTException: Failed to execute runnable
(java.util.ConcurrentModificationException)
at org.eclipse.swt.SWT.error(SWT.java:4083)
at org.eclipse.swt.SWT.error(SWT.java:3998)
at
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:137)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3515)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3164)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2640)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2604)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:24 38)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:671)
at
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:664)
at
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:115)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:196)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:369)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:57)
at
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:616)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 619)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
at org.eclipse.equinox.launcher.Main.main(Main.java:1383)
Caused by: java.util.ConcurrentModificationException
at
org.eclipse.emf.common.util.AbstractEList$EIterator.checkMod Count(AbstractEList.java:762)
at
org.eclipse.emf.common.util.AbstractEList$EIterator.doNext(A bstractEList.java:710)
at
org.eclipse.emf.common.util.AbstractEList$EIterator.next(Abs tractEList.java:696)
at
org.eclipse.emf.edit.provider.ItemProviderAdapter.getChildre n(ItemProviderAdapter.java:340)
at
org.eclipse.emf.edit.provider.ItemProviderAdapter.getElement s(ItemProviderAdapter.java:310)
at
org.eclipse.emf.edit.ui.provider.AdapterFactoryContentProvid er.getElements(AdapterFactoryContentProvider.java:160)
at
org.eclipse.jface.viewers.StructuredViewer.getRawChildren(St ructuredViewer.java:989)
at
org.eclipse.jface.viewers.ColumnViewer.getRawChildren(Column Viewer.java:703)
at
org.eclipse.jface.viewers.AbstractTreeViewer.getRawChildren( AbstractTreeViewer.java:1332)
at org.eclipse.jface.viewers.TreeViewer.getRawChildren(TreeView er.java:391)
at
org.eclipse.jface.viewers.StructuredViewer.getFilteredChildr en(StructuredViewer.java:896)
at
org.eclipse.jface.viewers.AbstractTreeViewer.getSortedChildr en(AbstractTreeViewer.java:601)
at
org.eclipse.jface.viewers.AbstractTreeViewer.updateChildren( AbstractTreeViewer.java:2581)
at
org.eclipse.jface.viewers.AbstractTreeViewer.internalRefresh Struct(AbstractTreeViewer.java:1867)
at
org.eclipse.jface.viewers.TreeViewer.internalRefreshStruct(T reeViewer.java:721)
at
org.eclipse.jface.viewers.AbstractTreeViewer.internalRefresh (AbstractTreeViewer.java:1842)
at
org.eclipse.jface.viewers.AbstractTreeViewer.internalRefresh (AbstractTreeViewer.java:1799)
at
org.eclipse.jface.viewers.StructuredViewer$8.run(StructuredV iewer.java:1514)
at
org.eclipse.jface.viewers.StructuredViewer.preservingSelecti on(StructuredViewer.java:1422)
at
org.eclipse.jface.viewers.TreeViewer.preservingSelection(Tre eViewer.java:403)
at
org.eclipse.jface.viewers.StructuredViewer.preservingSelecti on(StructuredViewer.java:1383)
at
org.eclipse.jface.viewers.StructuredViewer.refresh(Structure dViewer.java:1512)
at org.eclipse.jface.viewers.ColumnViewer.refresh(ColumnViewer. java:548)
at
org.eclipse.emf.edit.ui.provider.AdapterFactoryContentProvid er$ViewerRefresh.refresh(AdapterFactoryContentProvider.java: 495)
at
org.eclipse.emf.edit.ui.provider.AdapterFactoryContentProvid er$ViewerRefresh.run(AdapterFactoryContentProvider.java:463)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
at
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:134)
... 23 more
David
> 5. Commit
> 7. In the context menu select Import Roots and import my content.xml
> document.
> at
> at
> at
> thx.
> David
>>> Hi,
>> Cheers
>> /Eike
Re: [CDO] Net4j old version of h2 Db used in plugin [message #654870 is a reply to message #654852] Thu, 17 February 2011 13:24 Go to previous messageGo to next message
Hi David,
With generic repository export/import I was referring to the new server-side mechanism that is available either through server side API (look for uses of CDOServerExporter and CDOServerImporter) or via the OSGi console of the server.
Cheers
/Eike
Am 17.02.2011 13:26, schrieb David Wynter:
> Yes, I had preivous;ly done that successfully, you helped me in another thread, I think it took 8 attempts with a eclipse restart each time to get success. But this time I have no such luck. Here are my steps
> I use CDO Session view of my IDE, the view is shipped with org.eclipse.emf.cdo.ui plug-in. The steps are:
> 5. Commit
> 7. In the context menu select Import Roots and import my content.xml document.
> org.eclipse.net4j.signal.RemoteException: org.eclipse.emf.common.util.WrappedException: java.lang.ClassNotFoundException: edmmodel.EdmmodelPackage
> at org.eclipse.emf.ecore.plugin.RegistryReader$EPackageDescript or.getEPackage(RegistryReader.java:279)
> at org.eclipse.emf.ecore.impl.EPackageRegistryImpl.getEPackage( EPackageRegistryImpl.java:133)
> at org.eclipse.emf.cdo.internal.common.model.CDOPackageUnitImpl .loadPackageFromGlobalRegistry(CDOPackageUnitImpl.java:378)
> Not sure what I am missing here. I restart Eclipse and the CDO Server each attempt and start with a new Resource each time. I get consistent results. It look slike to me that my EMF project where I developed this model needs somehow to be on the CDO Explorer's classpath?
> thx.
> David
>>> Hi,
>> Cheers
>> /Eike
Re: [CDO] Net4j old version of h2 Db used in plugin [message #654871 is a reply to message #654853] Thu, 17 February 2011 13:26 Go to previous messageGo to next message
I've never seen that before. Please file a bugzilla with exact steps how I can reproduce that (have you tried the same thing with the example model we're shipping?). I'm busy with a customer work at the moment, so please don't expect me to jump onto this bug immediately ;-)
Cheers
/Eike
Am 17.02.2011 13:39, schrieb David Wynter:
> Something else I noticed about CDO Explorer. When importing the Roots I get 4 of these every single time, in the .log file
> !STACK 0
> org.eclipse.swt.SWTException: Failed to execute runnable (java.util.ConcurrentModificationException)
> at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:137)
> at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
> at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:664)
> at org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:115)
> at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:196)
> at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
> at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
> at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:369)
> at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
> at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:57)
> at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:43)
> at org.eclipse.emf.common.util.AbstractEList$EIterator.checkMod Count(AbstractEList.java:762)
> at org.eclipse.emf.common.util.AbstractEList$EIterator.doNext(A bstractEList.java:710)
> at org.eclipse.emf.common.util.AbstractEList$EIterator.next(Abs tractEList.java:696)
> at org.eclipse.emf.edit.provider.ItemProviderAdapter.getChildre n(ItemProviderAdapter.java:340)
> at org.eclipse.emf.edit.provider.ItemProviderAdapter.getElement s(ItemProviderAdapter.java:310)
> at org.eclipse.emf.edit.ui.provider.AdapterFactoryContentProvid er.getElements(AdapterFactoryContentProvider.java:160)
> at org.eclipse.jface.viewers.StructuredViewer.getRawChildren(St ructuredViewer.java:989)
> at org.eclipse.jface.viewers.ColumnViewer.getRawChildren(Column Viewer.java:703)
> at org.eclipse.jface.viewers.AbstractTreeViewer.getRawChildren( AbstractTreeViewer.java:1332)
> at org.eclipse.jface.viewers.StructuredViewer.getFilteredChildr en(StructuredViewer.java:896)
> at org.eclipse.jface.viewers.AbstractTreeViewer.getSortedChildr en(AbstractTreeViewer.java:601)
> at org.eclipse.jface.viewers.AbstractTreeViewer.updateChildren( AbstractTreeViewer.java:2581)
> at org.eclipse.jface.viewers.AbstractTreeViewer.internalRefresh Struct(AbstractTreeViewer.java:1867)
> at org.eclipse.jface.viewers.TreeViewer.internalRefreshStruct(T reeViewer.java:721)
> at org.eclipse.jface.viewers.AbstractTreeViewer.internalRefresh (AbstractTreeViewer.java:1842)
> at org.eclipse.jface.viewers.AbstractTreeViewer.internalRefresh (AbstractTreeViewer.java:1799)
> at org.eclipse.jface.viewers.StructuredViewer$8.run(StructuredV iewer.java:1514)
> at org.eclipse.jface.viewers.StructuredViewer.preservingSelecti on(StructuredViewer.java:1422)
> at org.eclipse.jface.viewers.TreeViewer.preservingSelection(Tre eViewer.java:403)
> at org.eclipse.jface.viewers.StructuredViewer.preservingSelecti on(StructuredViewer.java:1383)
> at org.eclipse.jface.viewers.StructuredViewer.refresh(Structure dViewer.java:1512)
> at org.eclipse.emf.edit.ui.provider.AdapterFactoryContentProvid er$ViewerRefresh.refresh(AdapterFactoryContentProvider.java: 495)
> at org.eclipse.emf.edit.ui.provider.AdapterFactoryContentProvid er$ViewerRefresh.run(AdapterFactoryContentProvider.java:463)
> at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:134)
> ... 23 more
> David
>> 5. Commit
>> document.
>> at
>> at
>> at
>> thx.
>> David
>>>> Hi,
>>> Cheers
>>> /Eike
Re: [CDO] Net4j old version of h2 Db used in plugin [message #655230 is a reply to message #654871] Fri, 18 February 2011 17:24 Go to previous messageGo to next message
I went looking for the example model you said was shipping, I looked in
org.eclipse.emf.cdo.examples.* jar files
and in
org.eclipse.emf.cdo.test.* jar files and could not find a paired xmi
file with it's ecore file.
Where is the example you mention?
Thx.
David
> Cheers
> /Eike
>> !STACK 0
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> ... 23 more
>> David
>>> 5. Commit
>>> document.
>>> at
>>> at
>>> at
>>> thx.
>>> David
>>>>> Hi,
>>>> Cheers
>>>> /Eike
Re: [CDO] Net4j old version of h2 Db used in plugin [message #655231 is a reply to message #655230] Fri, 18 February 2011 17:48 Go to previous messageGo to next message
Am 18.02.2011 18:24, schrieb David Wynter:
> and in
> org.eclipse.emf.cdo.test.* jar files and could not find a paired xmi file with it's ecore file.
I'm not sure, what a paired xmi file is supposed to be. I was talking about the org.eclipse.emf.cdo.examples.company model plugin.
Cheers
/Eike
> Thx.
> David
>> Cheers
>> /Eike
>>> !STACK 0
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> ... 23 more
>>> David
>>>> 5. Commit
>>>> document.
>>>> at
>>>> at
>>>> at
>>>> thx.
>>>> David
>>>>>> Hi,
>>>>> Cheers
>>>>> /Eike
Re: [CDO] Net4j old version of h2 Db used in plugin [message #655251 is a reply to message #655231] Fri, 18 February 2011 19:35 Go to previous messageGo to next message
It is a file with data content that matches the ecore model. When you
import your model into the registry you then load a resource that has
data that matches that model. It would have been nice to do that with a
model different to ours to see if my problem was model specific.
I sent my Derby Db to a collegue and he successfully imported the xml
that contained my model data. He then sent me the Derby Db and I used
that for my Repo. It get the same error when I open that resource, so by
a different route I proved that it is not the model. I then realised the
only difference is that I updated to the snapshot CDO 3.0 from the 15th
February (to get the Net4j plugin that accepted V1.3 off H2), his was
the 3.0 release.
I have now tried the release version 3.0 of CDO and still get the same
exception. I have lost 2 days work, but have no choice but to trace CDO
now to see what is wrong. It makes no logical sense that it should be
trying to load a class that it would never have access to, this class is
similar to the generated class from the genmodel file, but not the same,
as the package name is missing - edmmodel.EdmmodelPackage
Thx.
David
>> Hi,
>> and in
> Cheers
> /Eike
>> Thx.
>> David
>>> Cheers
>>> /Eike
>>>> !STACK 0
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> ... 23 more
>>>> David
>>>>> another
>>>>> 5. Commit
>>>>> document.
>>>>> at
>>>>> at
>>>>> at
>>>>> this
>>>>> thx.
>>>>> David
>>>>>>> Hi,
>>>>>>> old
>>>>>>> jar
>>>>>>> a new
>>>>>> It's
>>>>>> Cheers
>>>>>> /Eike
Re: [CDO] Net4j old version of h2 Db used in plugin [message #655252 is a reply to message #655251] Fri, 18 February 2011 19:38 Go to previous messageGo to next message
Here is the full stack trace when I try to view that Resource in the
repo in the Resource editor
!ENTRY org.eclipse.net4j 4 0 2011-02-18 19:30:46.654
!MESSAGE java.lang.ClassNotFoundException: edmmodel.EdmmodelPackage
!STACK 0
at
at
at
at
org.eclipse.emf.cdo.internal.common.model.CDOPackageUnitImpl .loadPackagesFromGlobalRegistry(CDOPackageUnitImpl.java:366)
at
org.eclipse.emf.cdo.internal.common.model.CDOPackageUnitImpl .load(CDOPackageUnitImpl.java:236)
at
org.eclipse.emf.cdo.internal.common.model.CDOPackageInfoImpl .getEPackage(CDOPackageInfoImpl.java:133)
at
org.eclipse.emf.cdo.internal.common.model.CDOPackageInfoImpl .getEPackage(CDOPackageInfoImpl.java:120)
at
org.eclipse.emf.cdo.internal.common.model.CDOPackageRegistry Impl$MetaInstanceMapperImpl.lookupMetaInstance(CDOPackageReg istryImpl.java:612)
at
org.eclipse.emf.cdo.server.internal.db.MetaDataManager.getMe taInstance(MetaDataManager.java:83)
at
org.eclipse.emf.cdo.server.internal.db.mapping.horizontal.Ob jectTypeCache.getObjectType(ObjectTypeCache.java:108)
at
org.eclipse.emf.cdo.server.internal.db.mapping.horizontal.Ab stractHorizontalMappingStrategy.readObjectType(AbstractHoriz ontalMappingStrategy.java:71)
at
org.eclipse.emf.cdo.server.internal.db.DBStoreAccessor.readO bjectType(DBStoreAccessor.java:158)
at
org.eclipse.emf.cdo.server.internal.db.DBStoreAccessor.getOb jectType(DBStoreAccessor.java:175)
at
org.eclipse.emf.cdo.server.internal.db.DBStoreAccessor.readR evision(DBStoreAccessor.java:200)
at
org.eclipse.emf.cdo.internal.server.Repository.loadRevisions (Repository.java:418)
at
org.eclipse.emf.cdo.internal.common.revision.CDORevisionMana gerImpl.loadRevisions(CDORevisionManagerImpl.java:365)
at
org.eclipse.emf.cdo.internal.common.revision.CDORevisionMana gerImpl.getRevisions(CDORevisionManagerImpl.java:268)
at
org.eclipse.emf.cdo.internal.common.revision.CDORevisionMana gerImpl.getRevision(CDORevisionManagerImpl.java:250)
at
org.eclipse.emf.cdo.spi.common.revision.RevisionInfo.execute (RevisionInfo.java:132)
at
org.eclipse.emf.cdo.server.internal.net4j.protocol.LoadRevis ionsIndication.responding(LoadRevisionsIndication.java:169)
at
org.eclipse.emf.cdo.server.internal.net4j.protocol.CDOServer Indication.responding(CDOServerIndication.java:126)
at
org.eclipse.net4j.signal.IndicationWithResponse.doExtendedOu tput(IndicationWithResponse.java:96)
at org.eclipse.net4j.signal.Signal.doOutput(Signal.java:285)
at
org.eclipse.net4j.signal.IndicationWithResponse.execute(Indi cationWithResponse.java:65)
at
org.eclipse.emf.cdo.server.internal.net4j.protocol.CDOReadIn dication.execute(CDOReadIndication.java:36)
at org.eclipse.net4j.signal.Signal.runSync(Signal.java:240)
at org.eclipse.net4j.signal.Signal.run(Signal.java:146)
at
java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Threa dPoolExecutor.java:886)
at
java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoo lExecutor.java:908)
at java.lang.Thread.run(Thread.java:662)
Caused by: java.lang.ClassNotFoundException: edmmodel.EdmmodelPackage
at
org.eclipse.osgi.internal.loader.BundleLoader.findClassInter nal(BundleLoader.java:506)
at
org.eclipse.osgi.internal.loader.BundleLoader.findClass(Bund leLoader.java:422)
at
org.eclipse.osgi.internal.loader.BundleLoader.findClass(Bund leLoader.java:410)
at
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:107)
at java.lang.ClassLoader.loadClass(ClassLoader.java:248)
at
org.eclipse.osgi.internal.loader.BundleLoader.loadClass(Bund leLoader.java:338)
at
org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:232)
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.load Class(AbstractBundle.java:1197)
at
org.eclipse.emf.ecore.plugin.RegistryReader$EPackageDescript or.getEPackage(RegistryReader.java:272)
... 29 more
David
On 18/02/11 19:35, David Wynter wrote:
> the 3.0 release.
> Thx.
> David
>>> Hi,
>>> and in
>> Cheers
>> /Eike
Re: [CDO] Net4j old version of h2 Db used in plugin [message #655305 is a reply to message #655251] Sat, 19 February 2011 05:39 Go to previous messageGo to next message
Am 18.02.2011 20:35, schrieb David Wynter:
> It is a file with data content that matches the ecore model. When you import your model into the registry you then load a resource that has data that matches that model. It would have been nice to do that with a model different to ours to see if my problem was model specific.
I don't see why you can't create any instance of your choice from one of our example models. Why should we provide example instances while it is so easy to create them with EMF? I guess that we have a major misunderstanding here ;-)
> I sent my Derby Db to a collegue and he successfully imported the xml that contained my model data. He then sent me the Derby Db and I used that for my Repo. It get the same error when I open that resource, so by a different route I proved that it is not the model. I then realised the only difference is that I updated to the snapshot CDO 3.0 from the 15th February (to get the Net4j plugin that accepted V1.3 off H2), his was the 3.0 release.
Internally our Helios SR2 version is of course a little different from the original Helios release because we fixed a number of bugs in maintenance. Still it may be the case that not all bugs that have been identified and fixed in HEAD have also been backported to maintenance. Have you already tried a 4.0 build?
> I have now tried the release version 3.0 of CDO and still get the same exception. I have lost 2 days work, but have no choice but to trace CDO now to see what is wrong. It makes no logical sense that it should be trying to load a class that it would never have access to, this class is similar to the generated class from the genmodel file, but not the same, as the package name is missing - edmmodel.EdmmodelPackage
The stacktrace in your newer post sugests that you have a package registry issue on the server. I'm not yet sure how that's related to the ConcurrentModificationException in your UI. Some questions:
1. Are your models generated? Have you followed http://wiki.eclipse.org/CDO/Preparing_EMF_Models ?
2. Does your model consist of multiple GenModels? Are they interrelated?
3. Do you have nested EPackages? Are they interrelated?
4. Do all packages have proper nsURIs? Do they match the nsURIs in your plugin.xml?
5. Does your model instance include "meta references" (references to EModelElements)?
Cheers
/Eike
> Thx.
> David
>>> Hi,
>>> and in
>> Cheers
>> /Eike
>>> Thx.
>>> David
>>>> Cheers
>>>> /Eike
>>>>> !STACK 0
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> ... 23 more
>>>>> David
>>>>>> another
>>>>>> 5. Commit
>>>>>> document.
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> this
>>>>>> thx.
>>>>>> David
>>>>>>>> Hi,
>>>>>>>> old
>>>>>>>> jar
>>>>>>>> a new
>>>>>>> It's
>>>>>>> Cheers
>>>>>>> /Eike
Re: [CDO] Net4j old version of h2 Db used in plugin [message #655322 is a reply to message #655305] Sat, 19 February 2011 12:22 Go to previous messageGo to next message
Yes, it was a major misunderstanding, takes a while to get a grip on all
this new stuff. I found the problem. I have a separate project in my
workspace with a ecore of the same name that is a cut down version of
the one I am attempting to load, trying to do the right thing in cutting
down the complexity for someone that only needs part of the model.
When I break on line 272 of RegistryReader.class I see that
element.getDeclaringExtension().getContributor().getName()
returns the name of this partial model. I probably accidently loaded
that into the registry. I tried renaming that partial model ecore, but
it appears that once you have imported a model into the registry with
the CDO Explorer there is no way of removing it.
I later found that it scans my workspace and it registers the first
ecore of that same name it comes to, and that is not the right one. I
removed the project from my workspace to be sure. It now works.
It uses "-dev
file:/home/david/workspace/.metadata/.plugins/org.eclipse.pd e.core/CDO_Client/dev.properties "
to list the packages it registers. So I could have renamed my partial
model ecore to a different package and edited this file to make sure it
got the right ecore.
Also the UI thread exception appears harmless and is unrelated to the
issue I have with loading resources, just a bit of a red herring.
Strictly I have to wait for CDO 4.0 to be a release version before using
it. This I assume will be the next Eclipse release?
Thx for your help. In the end a mistake on my part then and obscure
consequence of that mistake lost me a lot of time.
David
>> Hi,
> plugin.xml?
> EModelElements)?
> Cheers
> /Eike
>> Thx.
>> David
>>>> Hi,
>>>> and in
>>> Cheers
>>> /Eike
>>>> Thx.
>>>> David
>>>>> steps how
>>>>> moment, so
>>>>> Cheers
>>>>> /Eike
>>>>>> !STACK 0
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> ... 23 more
>>>>>> David
>>>>>>> another
>>>>>>> time to
>>>>>>> 5. Commit
>>>>>>> resource.
>>>>>>> document.
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> Server
>>>>>>> consistent
>>>>>>> this
>>>>>>> thx.
>>>>>>> David
>>>>>>>>> Hi,
>>>>>>>>> for
>>>>>>>>> old
>>>>>>>>> jar
>>>>>>>>> xml
>>>>>>>>> then.
>>>>>>>>> Which is
>>>>>>>>> a new
>>>>>>>> It's
>>>>>>>> Cheers
>>>>>>>> /Eike
Re: [CDO] Net4j old version of h2 Db used in plugin [message #655323 is a reply to message #655322] Sat, 19 February 2011 12:41 Go to previous messageGo to next message
Am 19.02.2011 13:22, schrieb David Wynter:
> Yes, it was a major misunderstanding, takes a while to get a grip on all this new stuff. I found the problem. I have a separate project in my workspace with a ecore of the same name that is a cut down version of the one I am attempting to load, trying to do the right thing in cutting down the complexity for someone that only needs part of the model.
> returns the name of this partial model. I probably accidently loaded that into the registry. I tried renaming that partial model ecore, but it appears that once you have imported a model into the registry with the CDO Explorer there is no way of removing it.
What exactly do you mean by CDOExplorer? Our CNF integration?
"it" == something in CDO? That would be new to me (also a new feeling for me :P )
> and it registers the first ecore of that same name it comes to, and that is not the right one. I removed the project from my workspace to be sure. It now works.
> It uses "-dev file:/home/david/workspace/.metadata/.plugins/org.eclipse.pd e.core/CDO_Client/dev.properties " to list the packages it registers. So I could have renamed my partial model ecore to a different package and edited this file to make sure it got the right ecore.
> Also the UI thread exception appears harmless and is unrelated to the issue I have with loading resources, just a bit of a red herring.
> Strictly I have to wait for CDO 4.0 to be a release version before using it. This I assume will be the next Eclipse release?
Yes, CDO 4.0 will be final together with Indigo in June.
> Thx for your help. In the end a mistake on my part then and obscure consequence of that mistake lost me a lot of time.
Good that you solved it!
Cheers
/Eike
> David
>>> Hi,
>> plugin.xml?
>> EModelElements)?
>> Cheers
>> /Eike
>>> Thx.
>>> David
>>>>> Hi,
>>>>> and in
>>>> Cheers
>>>> /Eike
>>>>> Thx.
>>>>> David
>>>>>> steps how
>>>>>> moment, so
>>>>>> Cheers
>>>>>> /Eike
>>>>>>> !STACK 0
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> ... 23 more
>>>>>>> David
>>>>>>>> another
>>>>>>>> time to
>>>>>>>> 5. Commit
>>>>>>>> resource.
>>>>>>>> document.
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> Server
>>>>>>>> consistent
>>>>>>>> this
>>>>>>>> thx.
>>>>>>>> David
>>>>>>>>>> Hi,
>>>>>>>>>> for
>>>>>>>>>> old
>>>>>>>>>> jar
>>>>>>>>>> xml
>>>>>>>>>> then.
>>>>>>>>>> Which is
>>>>>>>>>> a new
>>>>>>>>> It's
>>>>>>>>> Cheers
>>>>>>>>> /Eike
Re: [CDO] Net4j old version of h2 Db used in plugin [message #655331 is a reply to message #655323] Sat, 19 February 2011 13:43 Go to previous messageGo to next message
>> Hi,
>> model.
Actually that is a misnomer, it is actually the
org.eclipse.emf.cdo.server.product in a Debug config that loads the
models in registry, here is the console message when I launch it
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=en_GB
Framework arguments: -product org.eclipse.emf.cdo.server.product
Command-line arguments: -product org.eclipse.emf.cdo.server.product
-data /home/david/workspace/com.example.mdwmui/cdo -dev
-os linux -ws gtk -arch x86_64 -consoleLog
> for me :P )
The dev.properties file in that command line above contains entries for
all the projects that have ecore models in my workspace with a timestamp
that matches when I run the Debug task for starting my CDO repo at the
top, like so
#Sat Feb 19 12:12:05 GMT 2011
Algo=bin
org.eclipse.emf.cdo.examples.hibernate.client=bin
So I assumed it, "org.eclipse.emf.cdo.server.product", was scanning the
workspace and building that file.
David
>> It uses "-dev
> Cheers
> /Eike
>> David
>>>> Hi,
>>> plugin.xml?
>>> EModelElements)?
>>> Cheers
>>> /Eike
>>>> Thx.
>>>> David
>>>>>> Hi,
>>>>>> looked in
>>>>>> and in
>>>>> Cheers
>>>>> /Eike
>>>>>> Thx.
>>>>>> David
>>>>>>> steps how
>>>>>>> moment, so
>>>>>>> Cheers
>>>>>>> /Eike
>>>>>>>> Roots
>>>>>>>> !STACK 0
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> ... 23 more
>>>>>>>> David
>>>>>>>>> another
>>>>>>>>> time to
>>>>>>>>> 5. Commit
>>>>>>>>> resource.
>>>>>>>>> content.xml
>>>>>>>>> document.
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> Server
>>>>>>>>> consistent
>>>>>>>>> this
>>>>>>>>> thx.
>>>>>>>>> David
>>>>>>>>>>> Hi,
>>>>>>>>>>> for
>>>>>>>>>>> new
>>>>>>>>>>> once an
>>>>>>>>>>> old
>>>>>>>>>>> mistake,
>>>>>>>>>>> new h2
>>>>>>>>>>> jar
>>>>>>>>>>> going on
>>>>>>>>>>> xml
>>>>>>>>>>> then.
>>>>>>>>>>> Which is
>>>>>>>>>>> a new
>>>>>>>>>> you.
>>>>>>>>>> It's
>>>>>>>>>> Cheers
>>>>>>>>>> /Eike
Re: [CDO] Net4j old version of h2 Db used in plugin [message #655339 is a reply to message #655331] Sat, 19 February 2011 14:31 Go to previous messageGo to next message
Am 19.02.2011 14:43, schrieb David Wynter:
>>> Hi,
>>> model.
> Actually that is a misnomer, it is actually the org.eclipse.emf.cdo.server.product in a Debug config that loads the models in registry, here is the console message when I launch it
> Command-line arguments: -product org.eclipse.emf.cdo.server.product -data /home/david/workspace/com.example.mdwmui/cdo -dev file:/home/david/workspace/.metadata/.plugins/org.eclipse.pd e.core/CDO_Client/dev.properties -os linux -ws gtk -arch x86_64 -consoleLog
>> for me :P )
> The dev.properties file in that command line above contains entries for all the projects that have ecore models in my workspace with a timestamp that matches when I run the Debug task for starting my CDO repo at the top, like so
> Algo=bin
> So I assumed it, "org.eclipse.emf.cdo.server.product", was scanning the workspace and building that file.
I'm still clueless. AFAIK CDO does not scan the workspace or build properties files.
Cheers
/Eike
> David
>>> It uses "-dev
>> Cheers
>> /Eike
>>> David
>>>>> Hi,
>>>> plugin.xml?
>>>> EModelElements)?
>>>> Cheers
>>>> /Eike
>>>>> Thx.
>>>>> David
>>>>>>> Hi,
>>>>>>> looked in
>>>>>>> and in
>>>>>> Cheers
>>>>>> /Eike
>>>>>>> Thx.
>>>>>>> David
>>>>>>>> steps how
>>>>>>>> moment, so
>>>>>>>> Cheers
>>>>>>>> /Eike
>>>>>>>>> Roots
>>>>>>>>> !STACK 0
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> ... 23 more
>>>>>>>>> David
>>>>>>>>>> another
>>>>>>>>>> time to
>>>>>>>>>> 5. Commit
>>>>>>>>>> resource.
>>>>>>>>>> content.xml
>>>>>>>>>> document.
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> Server
>>>>>>>>>> consistent
>>>>>>>>>> this
>>>>>>>>>> thx.
>>>>>>>>>> David
>>>>>>>>>>>> Hi,
>>>>>>>>>>>> for
>>>>>>>>>>>> new
>>>>>>>>>>>> once an
>>>>>>>>>>>> old
>>>>>>>>>>>> mistake,
>>>>>>>>>>>> new h2
>>>>>>>>>>>> jar
>>>>>>>>>>>> going on
>>>>>>>>>>>> xml
>>>>>>>>>>>> then.
>>>>>>>>>>>> Which is
>>>>>>>>>>>> a new
>>>>>>>>>>> you.
>>>>>>>>>>> It's
>>>>>>>>>>> Cheers
>>>>>>>>>>> /Eike
Re: [CDO] Net4j old version of h2 Db used in plugin [message #655993 is a reply to message #655339] Wed, 23 February 2011 16:40 Go to previous messageGo to next message
Hi Eike,
Took me a while to get back to this. But I got sick of moving the
project that causes this issue in and out of the workplace.
Here is a summary. If I have a particular project in my workspace
(com.example.nrl.parser) that used to have an ecore model of the same
name as the one I have loaded into the CDO registry it tries to read it
from that project, even though it no longer has a model component. The
offending line of code is here (ln 273 RegistryReader.class for CDO
Client 3.0.1v20100911-0901)
Class<?> javaClass =
Platform.getBundle(element.getDeclaringExtension().getContri butor().getName()).loadClass(element.getAttribute(attributeN ame));
This
returns
"com.example.nrl.parser"
instead of
"com.example.edmmodel" where the model actually resides, this project is
also shown in the Registry Import dialog when I start from a new repo,
but it still tries to load the wrong one in the RegistryReader.
The only reference I can find to this directory is in dev.properties
held by the PDE config under the
workspace/.metadata/plugins.org.eclipse.pde.core
The contents look like this
#Wed Feb 23 16:12:50 GMT 2011
org.eclipse.datatools.modelbase.sql=bin
org.eclipse.datatools.enablement.mysql=bin
org.eclipse.datatools.modelbase.sql.edit=bin
com.example.mdwmui.system=bin
@ignoredot@=true
com.example.nrl.parser=bin
This may be a total red herring, I just thought maybe the RegistryReader
or other class in that stack uses the PDE to find the ecore file?
I have to actually move that com.example.nrl.parser directory from the
workspace to get CDO to 'find' the right EPackage in com.example.edmmodel
The workings of how it gets the "com.example.nrl.parser" as the
contributor are not clear to me.
Thx.
David
>>>> Hi,
>>>> model.
>>> for me :P )
>> Algo=bin
> properties files.
> Cheers
> /Eike
Re: [CDO] Net4j old version of h2 Db used in plugin [message #656001 is a reply to message #655993] Wed, 23 February 2011 16:51 Go to previous message
Hi David,
I apologize but I have no clue what's all this about. RegistryReader is not a CDO class.
Cheers
/Eike
Am 23.02.2011 17:40, schrieb David Wynter:
> Hi Eike,
> Took me a while to get back to this. But I got sick of moving the project that causes this issue in and out of the workplace.
> Here is a summary. If I have a particular project in my workspace (com.example.nrl.parser) that used to have an ecore model of the same name as the one I have loaded into the CDO registry it tries to read it from that project, even though it no longer has a model component. The offending line of code is here (ln 273 RegistryReader.class for CDO Client 3.0.1v20100911-0901)
> Class<?> javaClass = Platform.getBundle(element.getDeclaringExtension().getContri butor().getName()).loadClass(element.getAttribute(attributeN ame));
> This
> returns
> instead of
> "com.example.edmmodel" where the model actually resides, this project is also shown in the Registry Import dialog when I start from a new repo, but it still tries to load the wrong one in the RegistryReader.
> The only reference I can find to this directory is in dev.properties held by the PDE config under the workspace/.metadata/plugins.org.eclipse.pde.core
> @ignoredot@=true
> This may be a total red herring, I just thought maybe the RegistryReader or other class in that stack uses the PDE to find the ecore file?
> I have to actually move that com.example.nrl.parser directory from the workspace to get CDO to 'find' the right EPackage in com.example.edmmodel
> The workings of how it gets the "com.example.nrl.parser" as the contributor are not clear to me.
> Thx.
> David
>>>>> Hi,
>>>>> model.
>>>> for me :P )
>>> Algo=bin
>> properties files.
>> Cheers
>> /Eike
Previous Topic:[CDO] TimeoutRuntime Exception while opening a session
Next Topic:[CDO] synchronize model changes with backend
Current Time: Fri Jul 10 13:56:11 GMT 2020
Powered by FUDForum. Page generated in 0.03788 seconds
