Home » Archived » Buckminster » Resolve: Update plugins already present
Resolve: Update plugins already present [message #653565] Thu, 10 February 2011 09:24 Go to next message
Hi there,
I used a component query to resolve a target platform which I then set
as active target platform in my IDE. The query references a few bundles
from p2 repositories.
Let's say buckminster used bundle A in version 1.0.0 from a p2 repo. Now
someone created A 1.1.0 and published the new version to the same p2
repo. If I run the query again, buckminster does not do anything because
A is already present in the target platform. Is there a way to tell him
to update bundles if there is a newer version available? Or can I only
make this work if some other bundle explicitly requires A >=1.1.0?
Daniel
Re: Resolve: Update plugins already present [message #653578 is a reply to message #653565] Thu, 10 February 2011 10:16 Go to previous messageGo to next message
On 2011-02-10 10:24, Daniel Weber wrote:
> Hi there,
> I used a component query to resolve a target platform which I then set as active target platform in my IDE. The query
> references a few bundles from p2 repositories.
> Let's say buckminster used bundle A in version 1.0.0 from a p2 repo. Now someone created A 1.1.0 and published the new
> version to the same p2 repo. If I run the query again, buckminster does not do anything because A is already present in
> the target platform. Is there a way to tell him to update bundles if there is a newer version available? Or can I only
Add an advisor node in your CQUERY that matches everything (use pattern ".*"). Click on Resolution Scope and uncheck
"Target Platform". That will force Buckminster to consult the RMAP even if satisfying bundles exists in the TP.
In XML, the added element looks like this:
<cq:advisorNode namePattern=".*" useMaterialization="false" useTargetPlatform="false"/>
If you have more advisor nodes then you must add this one last and uncheck "Target Platform" in all of them.
- thomas
Re: Resolve: Update plugins already present [message #653605 is a reply to message #653578] Thu, 10 February 2011 11:38 Go to previous messageGo to next message
Hi Thomas,
thanks for your quick reply :)
> ".*"). Click on Resolution Scope and uncheck "Target Platform". That
> exists in the TP.
This does the trick, great! So when resolving dependencies buckminster
now ignores dependencies, but when actually materializing them it will
not re-download and install components which are up-to-date, correct?
Daniel
Re: Resolve: Update plugins already present [message #653648 is a reply to message #653605] Thu, 10 February 2011 14:15 Go to previous messageGo to next message
On 2011-02-10 12:38, Daniel Weber wrote:
> This does the trick, great! So when resolving dependencies buckminster now ignores dependencies, but when actually
> materializing them it will not re-download and install components which are up-to-date, correct?
No, Buckminster doesn't ignore dependencies. It just ignores the target platform while resolving them.
- thomas
Re: Resolve: Update plugins already present [message #653664 is a reply to message #653648] Thu, 10 February 2011 15:36 Go to previous message
That's not what I wrote but what I meant ;)
Thanks a lot,
Daniel
Previous Topic:Dependency resolution - too broad?
Next Topic:buckmminster and custom build callback
Current Time: Sun Feb 09 06:14:26 GMT 2025
Powered by FUDForum. Page generated in 0.03309 seconds
