Home » Eclipse Projects » Remote Application Platform (RAP) » No standard icons (e.g. Twisties, Menu items etc) following deployment
No standard icons (e.g. Twisties, Menu items etc) following deployment [message #653548] Thu, 10 February 2011 08:47 Go to next message
Paul Ramsden is currently offline Paul RamsdenFriend
Member
I have deployed my simple RAP app to a WebSphere server (WAS) using the WAR Product feature. The app has no extra branding and I start it using the 'rap' servlet.
No icons of any kind (including standard images on comboboxes etc) are shown when the app runs on the WAS but are shown when running in the test environment.
Is a plug-in missing? Do I need to add something in my plug-in build settings?
Paul
[Updated on: Thu, 10 February 2011 11:03]
Report message to a moderator
Re: No icons following deployment [message #653589 is a reply to message #653548] Thu, 10 February 2011 10:52 Go to previous messageGo to next message
Rüdiger Herrmann is currently offline Rüdiger HerrmannFriend
Paul,
the FAQ covers a couple of pitfalls related to deployment. Most likely
you forgot to update the build.properties [1].
HTH
Rüdiger
[1]
http://wiki.eclipse.org/RAP/FAQ#I_cannot_access_resource.2Fi mage_after_deploying_as_a_WAR
> the 'rap' servlet.
> No icons are shown when the app runs on the WAS but are shown when
> settings?
> Thanks
> Paul
Re: No icons following deployment [message #653594 is a reply to message #653589] Thu, 10 February 2011 11:09 Go to previous messageGo to next message
Member
Rüdiger,
thanks for the reply.
I guess I wasn't explicit enough, but the images I'm missing include those I would regard as built-in e.g. the triangle on a combo box or the 'x' on a view tab.
I also don't see my own images e.g. those on menu items. I selected the images folder in the 'Binary build' section but they can't be found on the deploy server.
Paul
Re: No icons following deployment [message #653721 is a reply to message #653594] Thu, 10 February 2011 20:08 Go to previous messageGo to next message
On 10.02.2011 12:09, paulr wrote:
> Rüdiger,
> 'x' on a view tab.
> the deploy server.
If you 'look into' the deployed bundles, do they contain the images?
> Paul
Re: No icons following deployment [message #653784 is a reply to message #653721] Fri, 11 February 2011 07:52 Go to previous messageGo to next message
Member
Rüdiger,
In the WAR on the WebSphere server I can unzip my JAR and see the images I added to my project. I don't know where the 'standard' images are kept. I tried a few likely candidates (rap.ui etc) but couldn't find anything.
I have not applied any custom branding or layout and am using the standard.
Paul
Re: No icons following deployment [message #653821 is a reply to message #653784] Fri, 11 February 2011 12:24 Go to previous messageGo to next message
On 11.02.2011 08:52, paulr wrote:
> Rüdiger,
> anything.
For now, let's assume that the RAP images are there too. BTW, did you
build the RAP bundles from source or did you use those from the target
platform?
Can you find the image files in the servlet engines working directory?
If you run on Tomcat it would be
/<tomcat-install>/work/Catalina/localhost/<web-app-name> /eclipse/workspace/.metadata/.plugins/org.eclipse.rap.ui/con text/rwt-resources
Did you try to run the WAR in another environment, e.g. a plain servlet
engine?
Can you ensure that the images are actually requested by the client and
the requests point to the right places? I.e. use the developer tools of
the browser of your choice to track the requests.
> Paul
Re: No icons following deployment [message #653827 is a reply to message #653821] Fri, 11 February 2011 13:09 Go to previous messageGo to next message
Member
Rudiger,
the requests look like
http://srvxyz/webapps/rap/rwt-resources/resource/widget/rap/ ctabfolder/close.gif
http://srvxyz/webapps/rap/rwt-resources/resource/static/imag e/dotted_white.gif
and return a 404 (my context root is /webapps/rap)
I located the WAS working directory here
WASROOT\AppServer\profiles\AppSrv\temp\SRVxyz\RAP_Test\FairM anagement_war\FairManagement.war\eclipse\workspace\.metadata \.plugins\org.eclipse.rap.ui\context\rwt-resources
For example the dotted_white.gif is here
WASROOT\AppServer\profiles\AppSrv\temp\SRVxyz\RAP_Test\FairM anagement_war\FairManagement.war\eclipse\workspace\.metadata \.plugins\org.eclipse.rap.ui\context\rwt-resources\resource\ static\image
which does look similar to the failed request.
No, I havn't tried to run this on any other server except the built-in Jetty and WAS.
I did not build from source. I downloaded the Helios RAP release in early Jan 2011
Paul
Re: No icons following deployment [message #653879 is a reply to message #653827] Fri, 11 February 2011 16:58 Go to previous messageGo to next message
Paul,
I would deploy the WAR on a different, plain servlet engine, just to be
sure that WebSphere isn't the reason why.
I remeber that someone else reported the same problem on this newsgroup.
It might be a year or more ago. If you take some time to search the
newsgroup archive [1] you will certainly find the post.
HTH
Rüdiger
[1] http://www.eclipse.org/forums/index.php?t=thread&frm_id= 34
[2] http://dev.eclipse.org/mhonarc/lists/rap-dev/threads.html
On 11.02.2011 14:09, paulr wrote:
> Rudiger,
> Jetty and WAS.
> early Jan 2011
> Paul
Re: No icons following deployment [message #654102 is a reply to message #653879] Mon, 14 February 2011 08:30 Go to previous messageGo to next message
Member
Rüdiger,
thanks for your help.
I have just tried the app on Tomcat and get the same problem. So it is not a WebSphere-specific problem which I guess is good.
You mentioned that there might have been a similar post over a year ago. Was that related to deploying to websphere or related to not finding static resources? I have searched but not found anything helpful yet.
Paul
Re: No icons following deployment [message #654113 is a reply to message #654102] Mon, 14 February 2011 09:29 Go to previous message
Member
It now works Smile
I noticed that there was an exception in the logs. Something to do with Jetty and an Address already in use bind error. I was surprised that Jetty would be active on the Tomcat server so I checked my plugin dependencies. In the end I removed all the dependencies and added the 'Required plugins'. That seemed to cure the problem. After redeploying, there were no Jetty exceptions and I get the images which were missing.
Hope this helps someone else.
Previous Topic:Table-Font - strikethrough, LOGFONT
Next Topic:File Drag & Drop from Desktop
Current Time: Fri Dec 03 20:12:43 GMT 2021
Powered by FUDForum. Page generated in 0.02622 seconds
