Home » Eclipse Projects » Remote Application Platform (RAP) » PhaseListener after phase 'PROCESS_ACTION'
PhaseListener after phase 'PROCESS_ACTION' [message #653326] Wed, 09 February 2011 11:52 Go to next message
Hussein Kobeisi is currently offline Hussein KobeisiFriend
Member
hey ppl,
i have this error when i try to switch from one view to another :
2011-02-09 12:46:24.004:WARN:/:ERROR: Could not execute PhaseListener after phase 'PROCESS_ACTION'.
java.lang.ClassCastException: org.eclipse.swt.layout.GridData cannot be cast to org.eclipse.swt.layout.FillData
at org.eclipse.swt.layout.FillLayout.flushCache(FillLayout.java :164)
at org.eclipse.swt.widgets.Composite.changed(Composite.java:602 )
at org.eclipse.swt.internal.graphics.TextSizeDeterminationHandl er$1.doVisit(TextSizeDeterminationHandler.java:86)
any ideas what this can be?
another Problem : i defined an OSGI in a Plugin in Order to register and getServiceReference from the BundleContext.. the Bundles are activated i checked the console but no services are registered i always get null... java.lang.NullPointerException: A null service reference is not allowed.
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.g etService(BundleContextImpl.java:660)
am i doing something wrong?
thx for your replies,
regards,
Hussein
Re: PhaseListener after phase 'PROCESS_ACTION' [message #653344 is a reply to message #653326] Wed, 09 February 2011 13:13 Go to previous messageGo to next message
Ralf Sternberg is currently offline Ralf SternbergFriend
Hi Hussein,
here's the answer to your problem:
http://dev.eclipse.org/newslists/news.eclipse.technology.rap /msg04293.html
Regards, Ralf
Ralf Sternberg
Twitter: @ralfstx
Re: PhaseListener after phase 'PROCESS_ACTION' [message #653783 is a reply to message #653326] Fri, 11 February 2011 07:40 Go to previous messageGo to next message
Member
thx Ralf,
what about this ?
any ideas?
regards, Hussein
Re: PhaseListener after phase 'PROCESS_ACTION' [message #656397 is a reply to message #653326] Fri, 25 February 2011 12:50 Go to previous messageGo to next message
Member
hi Ralf,
can you explain a little how to solve the Problem...
i found the bug in my Code!! is there a way other than :
button.setLayoutData( new GridData() ); // BAD !!!
to setLayoutData...
thx for your help ..
Hussein
Re: PhaseListener after phase 'PROCESS_ACTION' [message #656529 is a reply to message #656397] Sat, 26 February 2011 11:08 Go to previous message
Hi Hussein,
the type of the layout data attached to a control must correspond to the
type of the layout of its parent. As an example, if you have a Composite
that has a RowLayout, you can only attach layout data of type RowData to
its children. If one of the children has, for example, a GridData
attached, you will get a ClassCastException.
Regards, Ralf
Ralf Sternberg
Twitter: @ralfstx
Previous Topic:Understanding the RWT SettingStore
Next Topic:Table-Font - strikethrough, LOGFONT
Current Time: Sun Dec 05 03:09:18 GMT 2021
Powered by FUDForum. Page generated in 0.01921 seconds
