Re: Chinese fonts [message #653440 is a reply to message #653266] |
Wed, 09 February 2011 18:35 |
Srikanth,
Can you post the report? Does it contain fonts that you do not have
installed on linux?
Jason
On 2/9/2011 1:43 AM, srikanth wrote:
> Hello Everyone,
> I have a Simple RPt design which has a table and some rows and columns
> which are holding dynamic text.
> When I generate the pdf report in the windows environment,It renders the
> pdf perfectly.
> But,When I generate the pdf report in the Linux environment,
> Adobe is asking me to download traditional chinese fonts.
> Any suggestions will be really helpful..
> Regards,
> Srikanth
Re: Chinese fonts [message #653701 is a reply to message #653663] |
Thu, 10 February 2011 18:22 |
Srikanth,
The whole report did not come through. Can you email it to me at
jasonweathersby at windstream dot net? Where is it getting the dynamic
text from?
Jason
On 2/10/2011 10:52 AM, srikanth wrote:
> Hi Jason,
> The same report was working fine on linux sometime back.Now its causing
> problem..
> Below is the xml source of the rptdesign. I am populating the report
> fields using java beans.
> The BIRT version is 2.6.0.v20100617-7m9f77FT0z0-H04OvPZz0D4
> <report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.21"
> id="1">
> <property name="createdBy">Eclipse BIRT Designer Version 2.6.0.v20100531
> Build <2.6.0.v20100609-1613></property>
> <property name="units">in</property>
> <property name="iconFile">/templates/blank_report.gif</property>
> <property name="layoutPreference">fixed layout</property>
> <property name="bidiLayoutOrientation">ltr</property>
> <property name="imageDPI">96</property>
> <data-sources>
> <script-data-source name="DataSource" id="7"/>
> </data-sources>
> <data-sets>
> <script-data-set name="MainDataSet" id="8">
> <list-property name="resultSetHints">
> <structure>
> <property name="position">1</property>
> <property name="name">tableHeaderField1</property>
> <property name="dataType">string</property>
> </structure>
> <structure>
> <property name="position">2</property>
> <property name="name">tableHeaderField1Value</property>
> </structure>
> <structure>
> <property name="position">3</property>
> <property name="name">tableHeaderField2</property>
> </structure>
> <structure>
> <property name="position">4</property>
> <property name="name">tableHeaderField2Value</property>
> </structure>
> <structure>
> <property name="position">5</property>
> <property name="name">tableField1</property>
> </structure>
> <structure>
> <property name="position">6</property>
> <property name="name">tableField2</property>
> </structure>
> <structure>
> <property name="position">7</property>
> <property name="name">tableField3</property>
> </structure>
> <structure>
> <property name="position">8</property>
> <property name="name">tableField4</property>
> </structure>
> <structure>
> <property name="position">9</property>
> <property name="name">tableField5</property>
> </structure>
> <structure>
> <property name="position">10</property>
> <property name="name">tableField6</property>
> </structure>
> <structure>
> <property name="position">11</property>
> <property name="name">tableField7</property>
> </structure>
> <structure>
> <property name="position">12</property>
> <property name="name">tableField8</property>
> </structure>
> <structure>
> <property name="position">13</property>
> <property name="name">tableField9</property>
> </structure>
> <structure>
> <property name="position">14</property>
> <property name="name">tableField10</property>
> </structure>
> <structure>
> <property name="position">15</property>
> <property name="name">tableField11</property>
> </structure>
> <structure>
> <property name="position">16</property>
> <property name="name">tableField12</property>
> </structure>
> <structure>
> <property name="position">17</property>
> <property name="name">tableField13</property>
> </structure>
> <structure>
> <property name="position">18</property>
> <property name="name">tableField14</property>
> </structure>
> <structure>
> <property name="position">19</property>
> <property name="name">tableField1Value</property>
> </structure>
> <structure>
> <property name="position">20</property>
> <property name="name">tableField2Value</property>
> </structure>
> <structure>
> <property name="position">21</property>
> <property name="name">tableField3Value</property>
> </structure>
> <structure>
> <property name="position">22</property>
> <property name="name">tableField4Value</property>
> </structure>
> <structure>
> <property name="position">23</property>
> <property name="name">tableField5Value</property>
> </structure>
> <structure>
> <property name="position">24</property>
> <property name="name">tableField6Value</property>
> </structure>
> <structure>
> <property name="position">25</property>
> <property name="name">tableField7Value</property>
> </structure>
> <structure>
> <property name="position">26</property>
> <property name="name">tableField8Value</property>
> </structure>
> <structure>
> <property name="position">27</property>
> <property name="name">tableField9Value</property>
> </structure>
> <structure>
> <property name="position">28</property>
> <property name="name">tableField10Value</property>
> </structure>
> <structure>
> <property name="position">29</property>
> <property name="name">tableField11Value</property>
> </structure>
> <structure>
> <property name="position">30</property>
> <property name="name">tableField12Value</property>
> </structure>
> <structure>
> <property name="position">31</property>
> <property name="name">tableField13Value</property>
> </structure>
> <structure>
> <property name="position">32</property>
> <property name="name">tableField14Value</property>
> </structure>
> <structure>
> <property name="position">33</property>
> <property name="name">title</property>
> </structure>
> <structure>
> <property name="position">34</property>
> <property name="name">titleValue</property>
> </structure>
> <structure>
> <property name="position">35</property>
> <property name="name">document</property>
> </structure>
> <structure>
> <property name="position">36</property>
> <property name="name">documentValue</property>
> </structure>
> <structure>
> <property name="position">37</property>
> <property name="name">location</property>
> </structure>
> <structure>
> <property name="position">38</property>
> <property name="name">locationValue</property>
> </structure>
> <structure>
> <property name="position">39</property>
> <property name="name">authors</property>
> </structure>
> <structure>
> <property name="position">40</property>
> <property name="name">authorsValue</property>
> </structure>
> <structure>
> <property name="position">41</property>
> <property name="name">grades</property>
> </structure>
> <structure>
> <property name="position">42</property>
> <property name="name">gradesValue</property>
> </structure>
> <structure>
> <property name="position">43</property>
> <property name="name">subjects</property>
> </structure>
> <structure>
> <property name="position">44</property>
> <property name="name">subjectsValue</property>
> </structure>
> <structure>
> <property name="position">45</property>
> <property name="name">courses</property>
> </structure>
> <structure>
> <property name="position">46</property>
> <property name="name">coursesValue</property>
> </structure>
> <structure>
> <property name="position">47</property>
> <property name="name">type</property>
> </structure>
> <structure>
> <property name="position">48</property>
> <property name="name">typeValue</property>
> </structure>
> <structure>
> <property name="position">49</property>
> <property name="name">dateModifiedValue</property>
> </structure>
> <structure>
> <property name="position">50</property>
> <property name="name">headerTitle</property>
> </structure>
> <structure>
> <property name="position">51</property>
> <property name="name">headerAuthor</property>
> </structure>
> <structure>
> <property name="position">52</property>
> <property name="name">formattedAuthorsValue</property>
> </structure>
> <structure>
> <property name="position">53</property>
> <property name="name">attachment</property>
> </structure>
> <structure>
> <property name="position">54</property>
> <property name="name">attachmentValue</property>
> </structure>
> <structure>
> <property name="position">55</property>
> <property name="name">formattedAuthors</property>
> </structure>
> <structure>
> <property name="position">56</property>
> <property name="name">notes</property>
> </structure>
> <structure>
> <property name="position">57</property>
> <property name="name">notesValue</property>
> </structure>
> <structure>
> <property name="position">58</property>
> <property name="name">docField1</property>
> </structure>
> <structure>
> <property name="position">59</property>
> <property name="name">docField1Value</property>
> </structure>
> <structure>
> <property name="position">60</property>
> <property name="name">docField2</property>
> </structure>
> <structure>
> <property name="position">61</property>
> <property name="name">docField2Value</property>
> </structure>
> <structure>
> <property name="position">62</property>
> <property name="name">docField3</property>
> </structure>
> <structure>
> <property name="position">63</property>
> <property name="name">docField3Value</property>
> </structure>
> <structure>
> <property name="position">64</property>
> <property name="name">lastmodifiedValue</property>
> </structure>
> <structure>
> <property name="position">65</property>
> <property name="name">type_in_header</property>
> </structure>
> <structure>
> <property name="position">66</property>
> <property name="name">type_in_headerValue</property>
> </structure>
> </list-property>
> <list-property name="columnHints">
> <structure>
> <property name="columnName">tableHeaderField1</property>
> <text-property name="displayName">tableHeaderField1</text-property>
> </structure>
> <structure>
> <property name="columnName">tableHeaderField1Value</property>
> <text-property name="displayName">tableHeaderField1Value</text-property>
> </structure>
> <structure>
> <property name="columnName">tableHeaderField2</property>
> <text-property name="displayName">tableHeaderField2</text-property>
> </structure>
> <structure>
> <property name="columnName">tableHeaderField2Value</property>
> <text-property name="displayName">tableHeaderField2Value</text-property>
> </structure>
> <structure>
> <property name="columnName">tableField1</property>
> <text-property name="displayName">tableField1</text-property>
> </structure>
> <structure>
> <property name="columnName">tableField2</property>
> <text-property name="displayName">tableField2</text-property>
> </structure>
> <structure>
> <property name="columnName">tableField3</property>
> <text-property name="displayName">tableField3</text-property>
> </structure>
> <structure>
> <property name="columnName">tableField4</property>
> <text-property name="displayName">tableField4</text-property>
> </structure>
> <structure>
> <property name="columnName">tableField5</property>
> <text-property name="displayName">tableField5</text-property>
> </structure>
> <structure>
> <property name="columnName">tableField6</property>
> <text-property name="displayName">tableField6</text-property>
> </structure>
> <structure>
> <property name="columnName">tableField7</property>
> <text-property name="displayName">tableField7</text-property>
> </structure>
> <structure>
> <property name="columnName">tableField8</property>
> <text-property name="displayName">tableField8</text-property>
> </structure>
> <structure>
> <property name="columnName">tableField9</property>
> <text-property name="displayName">tableField9</text-property>
> </structure>
> <structure>
> <property name="columnName">tableField10</property>
> <text-property name="displayName">tableField10</text-property>
> </structure>
> <structure>
> <property name="columnName">tableField11</property>
> <text-property name="displayName">tableField11</text-property>
> </structure>
> <structure>
> <property name="columnName">tableField12</property>
> <text-property name="displayName">tableField12</text-property>
> </structure>
> <structure>
> <property name="columnName">tableField13</property>
> <text-property name="displayName">tableField13</text-property>
> </structure>
> <structure>
> <property name="columnName">tableField14</property>
> <text-property name="displayName">tableField14</text-property>
> </structure>
> <structure>
> <property name="columnName">tableField1Value</property>
> <text-property name="displayName">tableField1Value</text-property>
> </structure>
> <structure>
> <property name="columnName">tableField2Value</property>
> <text-property name="displayName">tableField2Value</text-property>
> </structure>
> <structure>
> <property name="columnName">tableField3Value</property>
> <text-property name="displayName">tableField3Value</text-property>
> </structure>
> <structure>
> <property name="columnName">tableField4Value</property>
> <text-property name="displayName">tableField4Value</text-property>
> </structure>
> <structure>
> <property name="columnName">tableField5Value</property>
> <text-property name="displayName">tableField5Value</text-property>
> </structure>
> <structure>
> <property name="columnName">tableField6Value</property>
> <text-property name="displayName">tableField6Value</text-property>
> </structure>
> <structure>
> <property name="columnName">tableField7Value</property>
> <text-property name="displayName">tableField7Value</text-property>
> </structure>
> <structure>
> <property name="columnName">tableField8Value</property>
> <text-property name="displayName">tableField8Value</text-property>
> </structure>
> <structure>
> <property name="columnName">tableField9Value</property>
> <text-property name="displayName">tableField9Value</text-property>
> </structure>
> <structure>
> <property name="columnName">tableField10Value</property>
> <text-property name="displayName">tableField10Value</text-property>
> </structure>
> <structure>
> <property name="columnName">tableField11Value</property>
> <text-property name="displayName">tableField11Value</text-property>
> </structure>
> <structure>
> <property name="columnName">tableField12Value</property>
> <text-property name="displayName">tableField12Value</text-property>
> </structure>
> <structure>
> <property name="columnName">tableField13Value</property>
> <text-property name="displayName">tableField13Value</text-property>
> </structure>
> <structure>
> <property name="columnName">tableField14Value</property>
> <text-property name="displayName">tableField14Value</text-property>
> </structure>
> <structure>
> <property name="columnName">title</property>
> <text-property name="displayName">title</text-property>
> </structure>
> <structure>
> <property name="columnName">titleValue</property>
> <text-property name="displayName">titleValue</text-property>
> </structure>
> <structure>
> <property name="columnName">document</property>
> <text-property name="displayName">document</text-property>
> </structure>
> <structure>
> <property name="columnName">documentValue</property>
> <text-property name="displayName">documentValue</text-property>
> </structure>
> <structure>
> <property name="columnName">location</property>
> <text-property name="displayName">location</text-property>
> </structure>
> <structure>
> <property name="columnName">locationValue</property>
> <text-property name="displayName">locationValue</text-property>
> </structure>
> <structure>
> <property name="columnName">authors</property>
> <text-property name="displayName">authors</text-property>
> </structure>
> <structure>
> <property name="columnName">authorsValue</property>
> <text-property name="displayName">authorsValue</text-property>
> </structure>
> <structure>
> <property name="columnName">grades</property>
> <text-property name="displayName">grades</text-property>
> </structure>
> <structure>
> <property name="columnName">gradesValue</property>
> <text-property name="displayName">gradesValue</text-property>
> </structure>
> <structure>
> <property name="columnName">subjects</property>
> <text-property name="displayName">subjects</text-property>
> </structure>
> <structure>
> <property name="columnName">subjectsValue</property>
> <text-property name="displayName">subjectsValue</text-property>
> </structure>
> <structure>
> <property name="columnName">courses</property>
> <text-property name="displayName">courses</text-property>
> </structure>
> <structure>
> <property name="columnName">coursesValue</property>
> <text-property name="displayName">coursesValue</text-property>
> </structure>
> <structure>
> <property name="columnName">type</property>
> <text-property name="displayName">type</text-property>
> </structure>
> <structure>
> <property name="columnName">typeValue</property>
> <text-property name="displayName">typeValue</text-property>
> </structure>
> <structure>
> <property name="columnName">dateModifiedValue</property>
> <text-property name="displayName">dateModifiedValue</text-property>
> </structure>
> <structure>
> <property name="columnName">headerTitle</property>
> <text-property name="displayName">headerTitle</text-property>
> </structure>
> <structure>
> <property name="columnName">headerAuthor</property>
> <text-property name="displayName">headerAuthor</text-property>
> </structure>
> <structure>
> <property name="columnName">formattedAuthorsValue</property>
> <text-property name="displayName">formattedAuthorsValue</text-property>
> </structure>
> <structure>
> <property name="columnName">attachment</property>
> <text-property name="displayName">attachment</text-property>
> </structure>
> <structure>
> <property name="columnName">attachmentValue</property>
> <text-property name="displayName">attachmentValue</text-property>
> </structure>
> <structure>
> <property name="columnName">formattedAuthors</property>
> <text-property name="displayName">formattedAuthors</text-property>
> </structure>
> <structure>
> <property name="columnName">notes</property>
> <text-property name="displayName">notes</text-property>
> </structure>
> <structure>
> <property name="columnName">notesValue</property>
> <text-property name="displayName">notesValue</text-property>
> </structure>
> <structure>
> <property name="columnName">docField1</property>
> <text-property name="displayName">docField1</text-property>
> </structure>
> <structure>
> <property name="columnName">docField1Value</property>
> <text-property name="displayName">docField1Value</text-property>
> </structure>
> <structure>
> <property name="columnName">docField2</property>
> <text-property name="displayName">docField2</text-property>
> </structure>
> <structure>
> <property name="columnName">docField2Value</property>
> <text-property name="displayName">docField2Value</text-property>
> </structure>
> <structure>
> <property name="columnName">docField3</property>
> <text-property name="displayName">docField3</text-property>
> </structure>
> <structure>
> <property name="columnName">docField3Value</property>
> <text-property name="displayName">docField3Value</text-property>
> </structure>
> <structure>
> <property name="columnName">lastmodifiedValue</property>
> <text-property name="displayName">lastmodifiedValue</text-property>
> </structure>
> <structure>
> <property name="columnName">type_in_header</property>
> <text-property name="displayName">type_in_header</text-property>
> </structure>
> <structure>
> <property name="columnName">type_in_headerValue</property>
> <text-property name="displayName">type_in_headerValue</text-property>
> </structure>
> </list-property>
> <structure name="cachedMetaData">
> <list-property name="resultSet">
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> <proper
Re: Chinese fonts [message #653772 is a reply to message #653701] |
Fri, 11 February 2011 05:50 |
srikanth Mising name Messages: 38 Registered: July 2010 |
Member |
Hi Jason,
I have mailed the rptdesign to
jasonweathersby@windstream.net
I am populating the dynamic text from java beans that I am getting from a java class which I am calling the dataset called "MainDataSet" script.
I had faced the similar issue where the adobe asked me download the Chinese fonts but that was because the data had mathematical characters like "<,>" and that issue was reproducible in both Windows and Linux environment and I had fixed the issue by changing the font type from San-serif to Arial in the rptDesign.
Srikanth
[Updated on: Fri, 11 February 2011 05:53] Report message to a moderator
Re: Chinese fonts [message #653869 is a reply to message #653772] |
Fri, 11 February 2011 16:08 |
Srikanth,
I looked over the design and did not see anything obvious. I assume it
is something in the data. Can you log a bug for this?
Jason
On 2/11/2011 12:51 AM, srikanth wrote:
> Hi Jason,
> I have mailed the rptdesign to mailto:jasonweathersby@windstream.net
> I am populating the dynamic text from java beans from I am getting from
> Regards,
> Srikanth
FUDForum. Page generated in 0.03858 seconds
