Home » Archived » BIRT » how to configure where BIRT cache is located
Re: how to configure where BIRT cache is located [message #653202 is a reply to message #653193] |
Tue, 08 February 2011 20:51 |
John,
Currently this comes from either the engine config or the system property:
System.getProperty( "java.io.tmpdir" );
If using the api just do
EngineConfig config = new EngineConfig();
config.setTempDir("yourlocation");
If using the viewer set the system property above on the app server
startup or put script like this in a report's before factory (if its
changed once it will affect all other reports ran afterwards):
reportContext.getReportRunnable().getEngine().getConfig().se tTempDir( "yourlocation");
Jason
On 2/8/2011 2:16 PM, John Yotka wrote:
> we are using BIRT 2.2.1 due to Java 1.4 considerations, is there a way
> to configure where the "BirtDataTemp..." directories are created?
> presently, by default, they are showing up in "/tmp" directory, but we
> would like to locate then in a application specific area, somewhere
> under "${birt home}" preferably.
Re: how to configure where BIRT cache is located [message #653491 is a reply to message #653202] |
Wed, 09 February 2011 22:40 |
John Yotka Messages: 144 Registered: July 2009 |
On 2/8/2011 1:51 PM, Jason Weathersby wrote:
> John,
> Jason
Thanks for the info, I'm trying to test, so first I wanted to validate
where the "BirtDataTemp..." folders where getting created on my test
system, before I implement the change. Now I can't seem to get the
folders to be created. I've run several reports and no instances of the
folders has shown up, but I have found old ones on my test system.
Under what conditions do these folders get created (again we are using
version 2.2.1)? Thanks again for your help.
Re: how to configure where BIRT cache is located [message #653693 is a reply to message #653202] |
Thu, 10 February 2011 17:24 |
> John,
> Jason
Jason,
We are not using the API so I've implemented this in a report script and
am getting an error, here is what I put into the "before factory" script:
reportContext.getReportRunnable().getEngine().getConfig().se tTempDir( "C:\birt\tmp");
and this is the error:
Caused by: org.mozilla.javascript.EcmaError: TypeError: getEngine is not
a function. (<inline>#1)
Is getEngine() not available in 2.2.1 or is it misspelled, or ...?
Re: how to configure where BIRT cache is located [message #653700 is a reply to message #653693] |
Thu, 10 February 2011 18:20 |
Try:
reportContext.getReportRunnable().getReportEngine().getConfi g().setTempDir( "c:/test");
Jason
>> John,
>> property:
>> Jason
> Jason,
Re: how to configure where BIRT cache is located [message #653726 is a reply to message #653700] |
Thu, 10 February 2011 20:25 |
On 2/10/2011 11:20 AM, Jason Weathersby wrote:
> Try:
> Jason
>>> John,
>>> property:
>>> Jason
>> Jason,
Jason, thanks that resolved the error. Now in my testing I don't seem
to be generating the "BirtDataTemp..." folders, I've run several reports
and no instances of the folders has shown up. I have old ones on my test
system. Under what conditions do these folders get created (again we are
using version 2.2.1)? Thanks again for your help.
Re: how to configure where BIRT cache is located [message #653728 is a reply to message #653726] |
Thu, 10 February 2011 20:34 |
I believe these happen when you have large datasets that are cached to disk.
Jason
>> Try:
>> Jason
>>>> John,
>>>> property:
>>>> Jason
>>> Jason,
>>> script:
> Jason, thanks that resolved the error. Now in my testing I don't seem to
Re: how to configure where BIRT cache is located [message #726783 is a reply to message #726686] |
Mon, 19 September 2011 14:49 |
Are you running the reports with the Viewer or the RE API? If no temp
dir is set in the EngineConfig class the default system property
java.io.tmpdir is used.
Jason
On 9/19/2011 5:27 AM, CJ48 wrote:
> I am new to birt. My application generates flat text files, and these
> flat text files are used by birt to generate excel files. But while
> generating these excel files some temporary files are created in my
> system's default Temp folder. I have created an environment variable
> MY_TEMP and I have given it's value as 'D:\my_temp_dir'. I want birt to
> use this temp location instead of the default location, Thanx in advance.
Current Time: Thu Apr 25 11:11:26 GMT 2024
Powered by FUDForum. Page generated in 0.03917 seconds
