Home » Archived » Test and Performance Tools Platform (TPTP) » Problems running testsuite containing testsuites from other projects(Errors running tests from a project with a testsuite that references testsuites from other projects)
Problems running testsuite containing testsuites from other projects [message #652846] Mon, 07 February 2011 10:55 Go to next message
Barry Dow is currently offline Barry DowFriend
We are converting all our existing JUnit and JUnit Plugin tests to TPTP Junit and TPTP JUnit Plugin tests. We I run the test suites in their individual projects I get all passes. Next I create a testsuite that references all the test suites from all other projects - this is where I am seeing errors - tests that pass fine previously now have Null pointer exceptions, ClassCastExceptions, etc. This is not for all tests - the vast majority are fine - however a few are failing and I can't work out why.
Has anyone else seen this at all?
Thanks - Barry
Re: Problems running testsuite containing testsuites from other projects [message #657740 is a reply to message #652846] Thu, 03 March 2011 19:09 Go to previous message
Torsten Stolpmann is currently offline Torsten StolpmannFriend
Member
Guessing wildly, I would say that you are running into class-loader issues using this approach.
Hope this helps,
Torsten
Previous Topic:URL Recorder and PHP Projekt
Next Topic:Drilling down to methods in a library ?
Current Time: Thu Aug 05 22:29:23 GMT 2021
Powered by FUDForum. Page generated in 0.05904 seconds
