Home » Eclipse Projects » Eclipse 4 » e4 pretty buggy -- how to help?
Re: e4 pretty buggy -- how to help? [message #652753 is a reply to message #652729] |
Sun, 06 February 2011 11:19 |
Thomas Schindl Messages: 6651 Registered: July 2009 |
Hi Karl,
Please report any problems you find!
Am 05.02.11 23:35, schrieb karl.weber99@googlemail.com:
> Hi, I downloaded Eclipse 4.1M5 today and started to play a little bit
> around with it.
> My environment is openSUSE 11.3 64bit with KDE4 -- default theme.
> Unfortunately e4 (4.1M5) seems to be quite buggy. I could help by
> writing bug reports but I do not want to flood you with reports about
> errors you already know. Furthermore, some dumps only occur because I am
> doing things the wrong way -- either because I do not find documentation
> or because the documentation I am reading is already outdated....
> Do you have any ideas?
> Problems I noticed so far:
> The UI does not look nice in my environment, which seems to be related
> to the KDE4-theme I am using. I have similar problems with eclipse 3.6.
> For certain other themes these problems do not appear (with eclipse 3.6,
> I didn't check that for e4).
What does this mean? Does it not integrate into the L&F?
> The rest only happens with e4:
> The UI is not redrawn properly. If I play around with the parts in the
> IDE, the tabs and or menus are sometimes not drawn.
Please file a bug. So that we can reproduce.
> Some changes are not synchronized properly to other files (e.g. from
> product -> plugin.xml). I have to close a file and open it again.
That's strange because this something happening on the lower level
because we are reusing the PDE code unmodified.
> Help does not work in the e4xmi editor. Example: I have to add addons
Help?
> for a main menu and a toolbar to work. If I add an addon and press find
> for the class URI, I do not find the eclipse addons. I could insert them
> only with a text editor.
The find is only searching inside your plug-in (currently not even the
classpath).
> Copy and past does not work in various editors (with Crtl+C and Ctrl+V).
> Sometimes it works with the context menu.
That's a known problem. See
https://bugs.eclipse.org/bugs/show_bug.cgi?id=321019
There are a lot things in the Model-Tooling that needs work but
apparently I'm not having enough spare time :-(
I can only hope that I can find the time to work on this but I can't
guarantee.
> The contacts example dumps -- it does not even start up.
That's unexpected? Can you file a bug and attach a stack?
> The photo example dumps also, but it does start up...
Tom
Re: e4 pretty buggy -- how to help? [message #653995 is a reply to message #652753] |
Sat, 12 February 2011 17:31 |
Karl Weber Messages: 63 Registered: September 2010 |
Member |
Tom Schindl wrote on Sun, 06 February 2011 06:19 |
Am 05.02.11 23:35, schrieb karl.weber99:
Yes, but I do not know, whether it is the fault of the gtk-style or of eclipse.
I am using KDE4 with the oxygen style and with the gtk-style oxygen-molecule for gtk-applications. Part of the phenomenon can be seen in the screenshots I added to the bug report https://bugs.eclipse.org/bugs/show_bug.cgi?id=333965, e.g. https://bugs.eclipse.org/bugs/attachment.cgi?id=188480. As you can see, the toolbar buttons are displayed as grey squares with the icons printed on them. The toolbar buttons do not assume the background color, they are always grey, also, e.g. in the headers of forms, where the background color should be something like blue. Furthermore, when I use css-styling, the background color of the toolbar buttons is not affected.
This depends on the gtk-style I am using. For a handfull of gtk-styles the effect is as described, for other styles, the buttons assume the background color as expected.
Although this might point to the gtk-styles as cause, I am not sure about that, since I can observe this effect only with eclipse, not with any other gtk-application I am using.
As mentioned, this problem can be observed with eclipse 3.6 and 4.1M5.
Another problem is the border of text fields in eclipse forms. If they are multiline, they have borders with one black line, I think one pixel wide. One-line textfields have two black border lines of different size for certain gtk-styles, which does not look nice.
Do you have any idea?
Current Time: Thu Apr 25 16:46:41 GMT 2024
Powered by FUDForum. Page generated in 0.03893 seconds
