Home » Eclipse Projects » Remote Application Platform (RAP) » SWT Text
SWT Text [message #652545] |
Fri, 04 February 2011 13:51 |
Edin Edin Messages: 101 Registered: January 2010 |
i have a SWT.MULTIPLE, SWT:WRAP, SWT.V_SCROLL Text with huge String Widget, which i want to be searched for a substring.
The search is done with indexof. Now i want to select the found string, to present it to the user. I tried with text.setselection with start index and endindex, but nothing seems to happens. i can only select the whole text with sellectall method. Onther thing i would like to do is to move scrollbar of the text to the position where the substring is found, any idea how to realise this? Is actually Text widget useful for such tasks, or is there some other widgets for searching on Strings better?
Thnx
Edit:
setting focus on Text before i call the setselection method makes the selection be visible, however, the positon is wrong. the indexof method returns i.e. 230, but setting the selection of the text to 230, 230+lenghtofstring doesnt select the the searched string: its about 10 charakters later on in the mainstring. problem of moving the textfield scrolls is still there.
any hints?
[Updated on: Fri, 04 February 2011 14:12] Report message to a moderator
Re: SWT Text [message #652590 is a reply to message #652545] |
Fri, 04 February 2011 16:14 |
Ivan Furnadjiev Messages: 2426 Registered: July 2009 Location: Sofia, Bulgaria |
to visualize the selection you have to focus the Text widget. For example:
text.setSelection( 5, 10 );
text.setFocus();
Currently, it's not possible to scroll the Text widget programmatically,
because Text#setTopIndex method is not implemented in RAP. See bug:
316265: [Text] getTopIndex() and setTopIndex() are not implemented
https://bugs.eclipse.org/bugs/show_bug.cgi?id=316265
If I remember correctly, you can achieve what you want with the
read-only prototype of StyledText from the sendbox
(org.eclipse.rap/sandbox/org.eclipse.rwt.widgets.styledtext) . There is a
demo in the sandbox too
(org.eclipse.rap/sandbox/org.eclipse.rwt.widgets.styledtext. demo).
HTH,
Ivan
On 2/4/2011 3:51 PM, ededagic wrote:
> Hello,
> Thnx
Re: SWT Text [message #652857 is a reply to message #652831] |
Mon, 07 February 2011 11:20 |
Hi Edin,
I think that setSelection select a range of text and scroll to make it
visible. Use the demo bundle, set "huge" text and play with it -
selection, range and other functionality.
HTH,
Ivan
On 2/7/2011 11:22 AM, ededagic wrote:
> Hi, Ivan
> Thx for your reply.
> Can you tell me which method to use to let styledText instace to
> scroll. i Make a new StyleRange each time i found a new occurance of
> the searching string. It marks then the found string wenn i use
> styledTexxt.setRange, but nothing happens with scroll bar.There is
> also no settopindex method there.
> At the moment, If there are more than one place where the string is
> found, all of the occurances remains. Should i remove them shomehow
> before i search for new occurance of the string. Because for me it
> looks better the old search results stay inside.
> Thnx, Edin
Current Time: Wed Apr 24 16:54:34 GMT 2024
Powered by FUDForum. Page generated in 0.03288 seconds
